Question about Myers Pump QP15
Not drawing water - Myers Pump QP15
  • 7,482 Answers
Hi fferrari450
You possibly have an airleak in the suction pipe or maybe the mechanical seal of the pump.
Check the discharge of the pump as close to the pump as possible and see if there is air in the stream of water being discharged.
Go to the following webpage and you can see the flow and pressure chart for this pump.
Please take time to rate me
Bud
http://www.lawnh2o.com/myers/myers_centrifugal.htm
Posted on Nov 02, 2012
Tip
F1 faults
F1 is a water leak error, it means water has filled the base of the unit and shorted across the filter board flood sensor (this how it is intended to function), now can be a number of different things, we will start with easy stuff, 1. to much detergent can bubble over the overflow hole in the draw and run into the base take note if there is excessive suds in the draw you should have only a thin layer on the surface of the water. 2. the lid that comes down when you close the draw to seal off the draw is being held up by something that is too high (you shouldn't put anything in that is taller than the handle of the cutlery basket) either that or the seal itself or the motors that pull the lid down are faulty, 3. you may have a leak through the heater plate seal (easy to check open the draw and look underneath it, on the bottom of the draw there will be a plastic cover protecting the coils and heater plate simply look at it to see if any water is pooled in it or if there is any dried soap or water. 4. if not any of these you will be looking for a leaking pipe or water hose. 5. and on the rare occasion your filter board itself may be corroded from water contact making it think it is permanently being touched by water
on Nov 22, 2011 | Fisher and Paykel Dishwashers
F& P bottom dishwasher draw won't drain. Top dish draw draining fine?
Excess water in
the DishDrawer
Drain hose(s) bent or
kinked.
Straighten the drain hose(s).
Blocked filters and/or drain
hose(s).
Clean the filter plate/drain filter. Unblock
the drain hose(s). Refer to the user manual
Aug 28, 2014 | Fisher and Paykel Dishwashers
Model WPRB9220C draws cold water when it's supposed to draw hot.
Your hot water inlet solenoid has failed and needs replacing.
Mar 11, 2012 | GE WPRB9220C Top Load Washer
My reliance natural gas water heater overheats causing scalding water to come out of my faucets. I have had authorized service companies come out three times to replace and retrofit different controls and...
Information below is for tank-type electric or gas heater only.
There is a condition called stacking.
This might apply to your water heater or not.
Having authorized service people to your house 3 times suggests more complicated mix of problems.
Stacking is caused when there are repeated short draws of hot water.
As you know, each time any hot water is drawn out of faucet, cold water immediately enters bottom of tank through the dip tube. The dip tube is connected to cold water inlet and runs to bottom of tank.
So all cold water enters bottom of tank close to the gas water heater thermostat.
See illustration of dip tube, that also shows copper thermostat sticking into tank that is connected to gas valve.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flushelectric
Let's say your water heater if fully heated and burner is off.
A short draw of hot water causes cold water to enter tank.
Another short draw. And then another short draw, each draw happens close to same time as other draws.
Water at top of tank is plenty hot, but bursts of cold water get near thermostat and cause thermostat to turn on burner.
Burner heats water and more hot water rises to top of tank. Water at top of tank becomes overheated each time stacking occurs.
Again, a stacking situation may not be the cause of your problem.
However, remember if single-handled faucet is opened straight upward, then that draws both hot and cold water. And cold water immediately enters tank.
Only when the single-handled faucet is lifted with the handle all the way to the right, does it draw only cold water. Even so, some single-handled faucets have bleed-over between hot and cold sides, so hot water is drawn anyway.
Another possibility is that the dip tube ends at or near thermostat, instead of going all the way to bottom of tank. The dip tube should go straight down from cold water inlet, but dip tubes are made of plastic, and some self-cleaning tanks have a curved dip tube or dip tube with perforations that create currents designed to stir sediments off bottom of tank (although this is not proven to be effective deterrent to sediment formation).
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 10, 2011 | RELIANCE ELECTRIC WATER HEATER
WATER IS POURING OUT THE DISPENSER DRAW OF MY WF000G
Normally if you take the soap slide draw out,you will see a hole underneath where the slide draw was. It normally blocks up with undesolved soap. Clear the channel then retry.Or sometimes water pressure is to high and then tends to splash internally causing water to drip out. Also make sure the slide draw is cleaned properly..
Sep 21, 2009 | Washing Machines
Water coming out of the powder draw when the draw is closed
Hi
The hose from the drawer into the tub is blocked or kinked, not allowing the water down quickly enough
Feb 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Karcher 620M not drawing water
my 620m has a problem when i press the switch on it has no pressure and the pump sounds like it is not kicking in .... plese help !!!
steve ..
Jan 08, 2008 | Washing Machines
Myers Pump QP15 Logo
174 people viewed this question
Top Myers Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Myers Plumbing Expert? Answer questions, earn points and help others
