Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washer lxr9245eq1 doesn't spin dry completely
Hi, my Whirlpool was off balance and became unlevel. I leveled it again (back legs popped back up). Since then, doesn't spin dry completely. I have to hand wring the clothes. Thank you.
  • 54 Answers
Try this... while in in spin turn your spin selector switch and listen if motor spins slower or faster.. at fast spin open your lid quick to see how fast its spinning.. check and make sure your drain line is cleared and the water flow out fast...and if its spinning too slow problem is in the gearbox area..
Posted on Jan 21, 2009
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a top loader and replaced the coupler, now the drum is unbalanced when spinning, how do I re balance it. The technician says its a simple job but will not tell me how
If you had the washer tilted back when you replaced the coupler, this may just be a simple matter of releveling the washer. Whirlpool top loaders have an auto-leveling mechanism on the back two feet of the washer. Periodically, you may need to check the level due to normal vibration and moving the appliance.. The following link explains how:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
If the washer is unlevel it can give the appearance of the drum being tilted. Try this and let me know if this helps you. If not, please post back and let me know.
May 03, 2011 | Whirlpool LSR5132PQ Top Load Washer
Why does the tub hit the liner on my whirlpool washer?
Sounds like it may be off balance. First tilt the rear of the washer onto the front legs a few inches (make sure the rear legs come off the ground if even just a few inches.) and then let the washer drop back on its rear legs. This is an auto level feature on many washers. Now use a level on the outer edges on the top of the washer and make sure it is level. Adjust the front feet as necessary. Also make sure you are evenly loading your washer so the tub does not "swing" into the side.
Mar 17, 2011 | Whirlpool Washing Machines
Spin vefy fast
A rapid spin cycle is actually a GOOD thing. This is an indication that the gearcase (transmission) and the drive motor are both running strong.
If the washer shudders during the spin cycle the first thing you need to do is check to ensure the washer is properly leveled. The following link explains:
The model Whirlpool top loader you have, has an auto-leveler mechanism on the back two legs that can become unlevel periodicailly. You should check the washer level from time to time when it is empty. You need to also make sure the washer is level in ALL directions (front-to-back and side-to-side).
Accidental unbalance problems that can occur from washing blankets, comforters, or heavy loads of towels can also cause the washer to become unlevel and shake. This can also contribute to the level mechanism becoming unbalanced.
Overloading the washer can also cause unbalance problems. Washing blankets or conforters can cause the load weight to shift to one side of the tub. This will result in a tub that shakes violently and bangs against the cabinet. You may have to redistribute the load weight when washing heavy items. This can also occur when washing loads of towels. This is NORMAL as some heavy items do not distribute the weight evenly.
Another problem (which is less common) that can contribute to wash unbalance problems is a weak floor under the washer. If the floor flexes (even the slightest) during the spin cycle, it can cause the washer to bounce or shake. Mobile homes or laundry rooms on the second floor of a home are notorious for having weaker floor structures. This washer has a 35 gallon tub capacity. Coupled with the weight of a wet load and the spinning action, this can put a lot of centrifugal force on a floor.
If you have any questions or concerns, please post back and let me know. I hope this information is helpful to you.
Apr 25, 2010 | Whirlpool LSR5132PQ Top Load Washer
How do I keep the front loader Duet Washer from knocking when its spinning a large (jeans) load?
you have to balance it out. You need to open the lid and move the cclothes. Do not overload washer. Underneath there are little legs. Put a level on top of washer and then start screwing the legs down or up to make the washer level.
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What causes Cabrio washer to get unbalanced in spin cycle?
Try making sure that your draining hose isnt jammed all the way down the hole. When you installed it the u shaped accessory was needed for the draining hose. Try pulling the draining hose out...curve the front and zip tying it to your cold water valve. This will allow it to drain properly and not get water push back into the drum causing it to be unlevel
Aug 02, 2009 | Whirlpool WTW6200S Top Load Washer
During the final spin cycle, our front loading whirlpool is making a really loud noise - it sounds like a train is going through the house. It is in the basement on a concrete floor.
If the washer is brand new, look on the back panel and make sure the 4 transportation bolts have been removed. The bolts should be roemoved completely - they are only necessary to protect the washer during transportation.
If the bolts are removed, adjust the front two legs to be 1/4 inch higher than the back two. That 1/4 inch will balance the washer during the spin cycle, perfectly.
Apr 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Tub gets off balance during spin cycle
also,shorten front legs,lean washer forward,and reset back legs.level.
Feb 17, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II Washer wont balance
Your basket drive is grabbing. the only way to stop that is to locate the clutch and the tube directly above it is your basket drive put a little white lithium up there. but not in the clutch. this will solve that problem. But if you do not know what you are looking for this will be difficult to locate.
Jan 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
802 people viewed this question
Dan Webster
Dan Webster
Sal De
