Question about Kyocera Mita KM-5035 Printer
5035 light copies - Kyocera Mita KM-5035 Printer
Hp lasserjet 5035 printing too light print
did yu try change catridge? if yes check your fuser unit.
Apr 25, 2016 | HP Laserjet 4200 4300 Duplexer-r73-5035
Kyocera Mita 5035
Go through the maintenance procedures in your manual. All cleaning should be done which probably includes roller cleaning but you should run it through all the procedures.
May 01, 2014 | Kyocera Mita KM-5035 Printer
I have a knoncera 5035 copier for classroom use (my own) Copies got very light & I replaced the toner (INK) but the copiers are still very light. It is not hooked up to print to just copy what do I do...
There are a few things to check
Is your paper fresh
Open the left hand side and check the transfer roller sometimes people break the retainers and loose the springs etcwhile removing paper jams
Oct 28, 2013 | Kyocera Copystar CS-5035 Copier
I replaced the toner (because copies were very light) They still are what do I do next?
adjust the intensity from your print quality menu/
if that doesnt work clean the glass, sensors and paper path
If that does not work then replace the drum unit.
Our Copystar CS-5035 Copier is not sending the copies to the finisher, instead they are coming out in the middle of the copier.
Press the * key and select Machine Defaults. Key in 6482, and scroll down to Select Copy Output Mode and press the Change # key. Select the desired output location.
If 6482 doesn't work use 5000
Jan 09, 2013 | Kyocera Copystar CS-5035 Copier
Copystar 5035 lite copies
Lite copies caused by developer unit, try to run mode 130 which will add toner to your developer, or try change the density of the copier, if non works, this means you have to change the developer unit.
Nov 04, 2011 | Kyocera Copystar CS-5035 Copier
KM 5035 cuts off top of copy image. Text is moved higher on page on copy vs original which cuts off the top of text on copy. Can't seem to figure out how to make it stop doing that. Happens the same...
Hello. Sometimes this can be caused by the duplexing mode being switched on. check the duplexing settings to rectify. Also if the paper position sensor is damaged this error can occur. this required a technician to replace.
I hope this helps Regards GM
May 27, 2011 | Kyocera Mita KM-5035 Printer
Copies are very light
check your transfer roller when removing the jam you broke the holder on the transfer roller and the contact spring fell out, no repair has to be replaced
Mar 26, 2009 | Kyocera Mita KM-5035 Printer
We have a Kyocera 5035 Copier and getting a message "Page tray is out of order"?? Any ideas on what to do?
if you go into copy mode punch in 1087 1087
press the green start button
punch in 906
press the green button
select the option on the touch screen
and wait until the machine reboots
this should fix any minor problems
Jan 24, 2009 | Kyocera Mita KM-5035 Printer
Kyocera Mita KM-5035 Printer Logo
27 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
