Question about Kodak ESP Office 2150 All-in-one Printer
My kodak esp office 2150 will not send or receiv faxes
When i try to send fax. It starts to dial then straight to faxing buit it finishes. i tried to send myself a fax and did not get it, The phone rang but fax never picked up
SOURCE: My model Kodak 5500 printer/fax
I recently purchased an Easyshare Aio. I cannot send faxes, the line is always busy, sometimes with a fast busy signal. I can receive faxes. Any advice appreciated.
Posted on Aug 11, 2008
  • 96 Answers
SOURCE: Problems to SEND a fax
I'm not sure what you mean entirely but this could help.
Usually sending faxes are only a problem if:
You have the printer set up correctly. (Phone line must be in line 1) or your phone line digital, which the product does not support unless you have a filter.
Also, if by different dial tone you mean "distinctive ring," that also is not supported by the product.
Posted on Aug 21, 2008
SOURCE: fax machine error
I called Kodak support and had to upgrade firm software and reset all the settings to reflect whether I had an answering machine (yes) and call waiting (no). Also found it helpful sometimes to dial out using commas after the 1, to keep it from ringing busy.
Posted on Nov 04, 2008
  • 2692 Answers
SOURCE: HOW DO I SEND FAXES ON MY KODAK ESP 3 MULTIFUNCTION PRINTER
Download link for your model to download the manual from:
http://www.kodak.com/global/en/service/downloads/dln_ekn034524.jhtml?pq-path=9103/12666/12667
Posted on Feb 18, 2009
SOURCE: HOW DO A SEND A FAX FROM MY ESP 3 AIO?
It's a Printer/Scanner/Copier. Nothing about faxes.
The ESP3 does not have fax capabilities.
You would have to go three models up (5,7,9) to the ESP 9 to get fax capability.
Posted on Feb 22, 2009
Turn ringer off on the printer
I've been trying to figure this out myself, you'd think it would be really simple but it's not. This is how I finally did it (after constantly playing around with it) hope this works for you too! From the Main Menu on the Printer, go to "Fax Settings" then go to "Fax Speaker" and Select "Off" to turn off the Ringer on a Kodak ESP Office 2150 All in One Printer.
Jun 28, 2014 | Kodak ESP Office 2150 All-in-one Printer
The all-in-one printer fax will receive a fax with no problem, but will not send a fax. It will scan the document, dial the number and connect to the other fax machine. It says sending, after about
Line noise is one of the common causes for fax problems. You might want to have your line checked for any noise.
Also, you can try to lower down the fax send speed. To do that, on the control panel of your printer, press on Setup > Fax Setup > Dialing and Sending > Max Send Speed > 9600.
Nov 30, 2012 | Lexmark Interpret S405 Wireless All-in-One...
I have a esp office 6100 series all in one printer, it is connected to a fully functioning phone line - I have checked everything is working. Each time I try to send a fax I dial the number it dials 3 or...
most likely the fax is incorrectly set up as an extension in a multi-line system rather than a single "telephone". probably the fax injects digits such as a leading zero. the setup needs to be corrected.
May 27, 2011 | Office Equipment & Supplies
Can dial out and receive incoming calls but will
Are you connected to a VOIP line for your fax?
A VOIP line can come from a company like Vonage or your local cable co.
If so:
Unfortunatly, faxing over VOIP (Internet) is not always successful. You might want to talk to your VOIP provider if they have a solution.
If not:
Are you trying with the same fax to send and recieve? Some traditional fax machines have probles connecting to fax modems, which is what you have in an Office Jet.
Try having someone else send you a fax and try sending to another number. Otherwise, you might have a defective fax modem.
Nov 07, 2009 | HP Officejet 7210 All-In-One InkJet...
Cannot send faxes on my all in one hp office jet 5610
If the recipient side is ringing, then the problem is on their end. It sounds like the receiving fax is not set for auto-answering a fax call. A receiving fax machine should pick up and start to attempt the reception even if the fax number is dialed from a normal voice-only telephone; the receiving machine has no idea if the caller is a fax or a regular phone. It should pick up regardless and start to negiotiate the fax (that's the high-pitched whistling sound at the beginning of the call).
May 15, 2009 | HP Officejet 5610 All-In-One InkJet...
Feb 18, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Sending fax
If you sending the fax over the memory, fax can scann doc. while dialing, or in the same time, but if you sending directly (on-hook dial) fax is sending the document while beeing reeded.
You may try to check the phone lines, browse the documents before sending,clean the original document feed rollers,...
if fax sudenly stops and wrinkle the orig. documents there is problem in scanner area
Jan 16, 2009 | Canon FAX-JX200
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
fax using monitor dialing
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 07, 2008 | HP Officejet 4215v All-in-One Printer
Trouble sending fax from 1 machine when 2 fax machines are on the same line.
I am not an expert but I would suggest to simply diconnect the other one when sending cheeeeeeeeers
Feb 13, 2007 | Brother FAX-8070P Plain Paper Laser
Kodak ESP Office 2150 All-in-one Printer Logo
64 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
