Question about Ruud Heating & Cooling
1987 ruud model uguh-075a-er pilot won't stay lit
Replaced thermocouple but pilot won't stay lit
  • 80 Answers
SOURCE: pilot light will not stay lit on model 465FX-R
It is possible that gas valve is bad, however, try replacing the pilot orifice located in the pilot assembly. If the flame is inadequate it will not generate the voltage required in the thermocouple. Pilot orifices are less than $10 and can be found at your local heating contractor's parts counter. Bring in the orifice to match.
Posted on Oct 03, 2009
SOURCE: 1990 Triple E mobile home
I've a similar problem and a new thermocouple solved it
J. N. Millet, Alberta
Posted on Jan 14, 2011
  • 1015 Answers
SOURCE: Pilot won't stay lit, replaced thermalcouple but
I would remove pilot light assembly and clean orifice and blow out gas line to pilot. Check to see that thermocouple is centered in pilot flame. It is possiblethat your gas valve is bad but it is also possible that you got a defective thermocouple. I would change the thermocouple again as they are much less expensive then the gas valves. The next time when you are sure you have the thernocouple mounted as close to the center of the pilot flame hold the pilot button down for several mins. If none of this works then you may have to change your gas valve.Thank you.
Posted on May 06, 2011
jturcotte
  • 8514 Answers
SOURCE: The pilot light on my
Hi, with a new thermocouple, the only other thing it can be is the valve. Replace the valve.
Posted on Sep 03, 2011
  • 125 Answers
SOURCE: water heater pilot light will not stay lit.
Hold the pilot button down for a full minute after it lights, then release. If this does not work then the thermocouple is not adjusted where the flame is heating it or you just have a faulty new thermocouple.
Posted on Sep 06, 2011
Pilot lite won't stay lit
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
Apr 14, 2013 | Heating & Cooling
Pilot won't stay lit...gaffers&sattler model B35
Hit the flame sensor next to the pilot with sandpaper. If it still doesn't work replace it.
Feb 26, 2013 | Heating & Cooling
Reliant 501 Natural Gas won't stay lit
Reliance water heater?
Thermocouple is good if the pilot stays lit continuously.
501 is older model. Unknown if this unit has FVIR protection and sealed combustion chamber or open air intake on front of unit.
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
With FVIR protection:
Get more fresh air to the unit.
Clean the flame arrestor screen.
Test and replace the thermocouple:
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Inspect and clean burner and combustion parts
Test gas pressure, bleed air out of gas line.
Replace gas control valve.
Test draft air by lighting match and see if smoke is pulled into the vent pipe at draft hood on top of tank.
Aug 20, 2012 | Water Heaters
Pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Sep 20, 2011 | Heating & Cooling
Water heater pilot light will not stay lit. changed the thermocouple, and still won't stay lit.
Sep 06, 2011 | Heating & Cooling
The pilot light on my propane furnace will not stay lit. I replaced the thermocouple, but it won't stay on. Any suggestions?
Sep 03, 2011 | Heating & Cooling
May 06, 2011 | Rheem Water Heaters
I have a readyheater model 65-85 the flame will not stay lit im thinking thermal couple is there a way to test this part? or could it be another problem?
If your pilot light will not stay lit when you release pilot light button then chances are that your thermocouple is bad. Make sure that the tip of thermocouple is directly in line with pilot light. Tip of thermocouple should be cherry red if it is properly placed. If pilot will not stay lit then replace it. If you aren't sure about placement of thermocouple you can heat thermocouple with a seperate heat source. If you do this and pilot light stays lit then reposition thermocouple in pilot flame. If it still won't keep pilot burning then replace thermocouple. Hope this helps. Thanks.
Nov 19, 2010 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
139 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
