Question about Craftsman 12 Tilt Head Band Saw Owner Manual 113247210
I need to replace the drive belt on a 12 inch craftman band saw
rowdy45176
  • 2176 Answers
SOURCE: I have a 12 inch Sears/Craftsman band saw. I got
that is where I would look first, you would need your model number and go to Searspartsdirect.com and type in your model number to find and order the replacement rubber tires and that should take care of your problem
Posted on Dec 17, 2009
  • 32 Answers
SOURCE: I have a craftman 12" band saw when to turn it on
It may be the start switch-that is one of the trouble shooting answers in the manual. (i.e motor not reaching speed)
Posted on Oct 24, 2010
  • 32 Answers
SOURCE: My 12 inch band saw
Tires need replaced- may have a few other problems. try this
-unplug the saw spin the saw by hand, does track down the middle of both tires? also look at your guides and backup bearings.
I would take off blade-back off all guides and bearings -clean off any build up on tires- replace blade. now spin wheel ( always spin with the blade going down) if its tracking good go ahead and adjust guides and bearings to specs and try again. most likely the back up bearings are out of adjustment. they should not spin unless you are feeding material and it seems like the bottom one may be your problem.
But never the less it sounds like new tires are needed.
  • 32 Answers
SOURCE: My band saw (craftsman 12" tilt head) stopped
Hello'
I have the exact same saw. It sounds like the key stock came out of the pulley attached to the lower wheel. I will give you a quick rundown.
-unplug saw
-you will have to lay the saw on its side so you can remove the motor and drive belt.
-there are 2 seperate pulleys , the one connected to the motor and the one connected to the bottom wheel.
-loosen motor nuts and remove motor, pay close attention when removing motor 3 of the 4 studs have sleeve like spacers.
-once motor and belt are out of the way check the pulley on the bottom wheel,my guess is that the key stock came out and the pulley spins freely.
-loosen set screw,replace keystock and tighten.
-NOTE the keystock may have came out of the motor pully instead,check.
Now this next part is real important.
-once you get it figured out and are ready to put everything back together the 2 pulleys must be perfectly lined up, use a flat ruler, using your eye will not work.line the drive pulley up with the lower pulley. ( the pulley on the motor has a shoulder on it so when it is pushed towards motor it will be set in the right spot) .
It is either the pulley on the motor or the wheel that has lost its keystock.
It should be a easy fix,Good luck
Posted on Nov 15, 2010
SOURCE: i just bought a used
Saw blades for the 113.243311 bandsaw are 80".
Posted on Apr 26, 2011
Drive belt slips off my 12" craftsman band saw
Try replacing the belt on your band saw. Check and verify the pulleys are the right size and properly aligned.
Sep 23, 2014 | Saws
How long is the saw blade on a 12inch band saw
The manual says that it will support blade widths from 1/8 inch to 1/2 inch. You can use 80" or 80 1/2" band saw blade. I got my band saw blade on sawblade.com . I like them .
Jun 06, 2014 | Craftsman 12 Inch Band Sawsander I2 X80...
There are several steps to follow in changing/replacing the drive belt. You need to loosen/remove the drive wheel so you can replace the belt on the saw. Then you need to check and make adjustments on the tension on the belt. But it would be best if you can check the operator's manual for the saw.
Nov 07, 2012 | Craftsman 12 Tilt Head Band Saw Owner...
I need a drive belt for a Delta bs100 band saw
Visit www.ereplacementparts.com. Search on your model number, they have a breakdown of your saw. You can order the belt from them or use to part number to search the internet to see if they are available elsewhere.
Feb 11, 2011 | Delta BS100 Shopmaster 9 Inch Bench Top...
Broken drive belt on ryobi band saw, need
Just go to a well equipped hardware or auto parts store. Take the old belt with you so they can find an exact replacement. Good luck!
Apr 26, 2010 | Ryobi 9 in. Benchtop Band Saw
Will Delta Belt fit Mastercraft Band Saw
If you still have the old belt, take it to a well equipped hardware or auto parts store for a replacement. If the previous belt is missing, you will need to measure the pulley 'V' width at the top of the 'V', the center to center measurement of the two shafts, and the outer diameters of the two pulleys. Hope this helps!
Apr 15, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
Have a 10''band saw with 254mm blabe need to no the size of blade to replace / alum blade glide so i can replace montgomery ward 10''band saw belt drive
Your 10 inch saw takes a 59 inch blade, I think, it will say on the package if you buy from lowes or home depot, no matter what the thickness is, 1/8, 1/4, 3/8, You don't want to go any bigger than that. The belt for the drive is just a v-belt, measure the old one or get the number off it, or just measure the distance around the pulleys. Hope this helps.
Mar 01, 2010 | Saws
Craftsman 12 Tilt Head Band Saw Owner Manual 113247210 Logo
54 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
