Question about Sony Cyber-shot DSC-W30 Digital Camera
No picture viewing on the screen
The message appear on the screen torn the camera off then on repeatedly.
  • 1 more comment
  • Anonymous Oct 16, 2008
    compiuter sed tonr on the camera
  • Anonymous Oct 22, 2008
    I also cannot get any view when I take a photo just a black screen. I can scroll back and look at pictures I took prior to this problem occuring.
  • ezr23angl Oct 24, 2008
    My camera has had this problem before and when it was under warranty i would send it and it would get fixed but now its not and it's expensive to get it fixed. is this a common problem. is there anyway i can fix it on my own?
    Genius:
  • 2,985 Answers
This is a fundamental failure. If it is under warrenty reurn it. If not contact makers web site tech.help Alo look here http://www.fixya.com/support/p472667-sony_cyber_shot_dsc_w30_digital_camera
Posted on May 18, 2007
SOURCE:
Camera screen is black no image appears to view to take a picture??
Time for a new camera perhaps ? Sreen is faulty, most likely and fixing may be too expensive.
Sep 11, 2014 | Kodak EasyShare MD853 Digital Camera
How do I remove hgistogram from right hand side of screen which appears when viewing pictures taken
Did you try to press the info button several times? Whatch what happens on the screen, because the camera will cycle through several views.
It is in the manual, under Changing the image information display.
May 13, 2014 | Olympus SZ-10 Digital Camera - Silver
When taking a picture a message pops up that says "cannot be written to SD card"
Checks to make:-
1) Is there an SD card in your camera?
2) Is the SD card compatible with your camera?
3) Is the SD card write protected (Check notch top left hand corner of card)
4) Is the SD card full or nearly full?
5) Are you trying to write a file type (.raw) which is bigger than the capacity of the card or the remaining capacity on the card.
Nov 01, 2011 | GE X500 Digital Camera
The lenses were stuck and on the screen it says "lens error".I do not know how it happened. We were just taking photos and when we are about to view them, it vibrated then turned itself off.
This message appears when the lens performs some unexpected operation.If the same message appears after you turn power back on please check that if there is something which blocks the motorized movement of the lens.If so clean it with cotton swabs or soft cloth.After cleaning power off and on again repeatedly two three times.
Jun 04, 2011 | Casio Exilim Zoom EXZ33 Digital Camera
Screen does not display image
make the "live view"/"viewing screen" first enable by locating it in your menu or your settings. then after that you can go back from taking picture by using the viewing screen
in regards of viewing the pictures taken, press the display button. keep pressing until the viewing screen appears
Apr 30, 2010 | Canon PowerShot G9 Digital Camera
Write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Dec 14, 2008 | Olympus MJU 400 Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
LCD screen black, no viewed image displayed.
Hold down the display button for a few seconds...
It worked on my Caplio R7 which was doing this all weekend...
hope this helps
Jul 31, 2008 | Ricoh Caplio R30 Digital Camera
DOWNLOADING TO PC
Hi during dowloading pictures need the camera knob to display or where you can view pictures and video. connect usb the detection will view on screen and follow screen instruction.
Jan 20, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Message on LCD screen
'No Picture' usually means just that. There are no images in the memory. So go take some pictures. Check you have the control to the picture taking mode and not the Viewing mode Give the manual a good read.
Jul 06, 2007 | Pentax EI-100 Digital Camera
Sony Cyber-shot DSC-W30 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
