Boot priority order - Computers & Internet
    Problem Solver:
  • 8 Answers
If you are wondering how to change the boot priority order, you need to get into the BIOS. To do this you need to restart your computer and during the first few seconds of boot up, before the logo for your computer comes up, you need to press one the of function keys. Depending on the make of your computer it can range from f2 to f8. If you look carefully, on the bottom of the screen during boot up it should say something like "for setup press f2" or something. Or you can google the make of your computer and BIOS to find out which key. Once there its just like a settings screen and there should be an options for boot priority. You can usually change it from hard drive to external or optical. Hope this helps.
Posted on Oct 26, 2012
What is boot device priority and what order should it be?
"Boot device priority" refers to the order in which a computer looks for bootable media so it can load the operating system.
For most desktops and laptops these days, the boot order is usually the installed hard drive first, then a CD/DVD drive and a USB port. This order can vary by brand of computer.
Jul 23, 2015 | Computers & Internet
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
When goes to boot up the screen goes black
turn on your pc, press F2 or del. find the boot order, set your hard drive as your first boot priority order. press F10 and then save. hope this will help... good luck
Jun 14, 2012 | Systemax AOL Optimized PC (100607) PC...
It says reboot and select proper reboot device
Many new boards, you must set the hard drive priority before you set the boot order in the BIOS setup menu. Set your priority to the drive you want to boot from and the boot order to:
CDRom - 1st
Floppy - 2nd
Hard Drive - 3rd
*Don't forget to save before you exit.
Any doubts you can get in touch with a technician through
www.thebestpcdoctor.com
Toll Free: 877 407 9229
Sep 20, 2011 | HP Mini 1000 Netbook
I have hp compaq nx 9020 and I installed linux as my only os, but now I want to change my os to xp but bios says "no boot file name recived" how to fix this?
It seems as if you have some of your boot priorities out of skew, specifically having booting through your network connection as a higher priority. In order to fix this, you need to go into your bios settings and rearrange the boot settings so that booting from LAN is either disabled or not the top priority and making booting from CD or HDD the top priority.
May 23, 2011 | HP Computers & Internet
What is the booting priority order for aspire 3680
Usually it's preset to HDD/CD/Network. You can change the order in the system setup.
Mar 05, 2011 | Acer Aspire 3680 Laptop
I need the boot priority order for an acer aspire 5050?help please?
Restart the computer, and enter BIOS SETUP mode, and view/change the boot-priority order.
Sep 18, 2010 | Acer Aspire 5050-3242 Notebook
DELL latitude 100l, someone disabled all boot devices then set config / administrator password. Please help
Boot Priority on Dell Latitude 100L
  1. Turn On Your PC
    Have you ever noticed the messages that pop up on the screen as soon as you turn on your PC? These messages tell you a key combination you can press to enter "Setup" or the "BIOS." Watch your screen and see if you can read what keys to press.
  2. Press the Keys to Enter Setup Mode
    If you did not see a message telling you what keys to press, try tapping the following possibilities as you turn on the machine:
    • Esc
    • F2
    • F12
    • F10
    • F1
    After pressing Esc or other key, you will most likely see instructions telling you how to enter "Setup Mode". Follow those instructions.
    tip.gif On some computers, you must hold down the key before you press the power button to turn on the computer. For example, if you are converting a Toshiba laptop to a Linux Workstation, you must hold down the Esc key and then press the power button. The computer then asks you to press F1, and you can then set the "Boot Priority."
  3. Using the Arrow Keys, Choose the "Boot," "Boot Order," or "Boot Priority" Option
    The menu of choices you see will be different for different kinds of computers. Remember that the choice you want is the "Boot" order or "Boot Priority." On some computers, this is called the "Start Up Options" or "Start Up Sequences." You are going to change where the PC will look for boot information when it starts up. (CD-ROM, HARD DRIVE/HDD, LAN, FLOPPY, USB). If you wish to boot from your Hard drive, then select it as your First Priority.
  4. Using the instructions on the screen, save your settings and start up your PC. The PC must boot from the HDD. Regrds
Jul 01, 2010 | Dell Latitude 100L Notebook
Usb cd rom will not boot can i boot from sd card
yes you must change the boot order and activate the legacy USB support if exsisted
Jan 25, 2009 | Toshiba Portege R100 Tablet PC
Trying to get cd to boot from bios
just may the CDROM the top priority, then it may ask you to restart the computer, just let it restart then put the CD in.
Aug 04, 2008 | Computers & Internet
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
