Question about Siemens WM14S794GB Front Load Washer
Siemens d12.52 f18
F18
Setting up a formula. I am comparing amounts for the last 3 years of raises and want to figure 5 different ones this year.Example of what I am trying to do. =(F6:F18*1.12%+F6:F18) Can this be done?
in excel ?
=sum(f6:f18)*0.012+sum(f6:f18)
if each row has to be individually * 0.012 add a column and put in this column each row cell * 0.012. example new column G then g6=f6+f6*0.012
a screen print of what you are trying to do would give a clearer indication of exactly what you want to achieve ?
Mar 26, 2017 | The Computers & Internet
Car won't start after cutting off?
that is a fuse for the power train control module. so the mudule is failing.
Dec 28, 2013 | 2003 Jaguar X-Type
F18 fuse keep on short circuiting
find what fuse 18 runs and check it for a dead short. If it is a fuel pump fuse check the fuel pump for seized or dead short.
Dec 28, 2013 | 2002 Jaguar X-Type
Siemens s14.36 f18 error message with slight burning smell. Cleaned pump but still get error message.
For Siemens washers 'F18' definitely states that there is a problem with the filter (which you don't mention, only 'pump')
Read through my guidance notes and check the state of the filter AND check that the pump is not jammed and actually working. It says how to do this near the end ;-0)
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 12, 2011 | Siemens Washing Machines
Error code F18
F18 error code means that the filter is blocked.
Look around for a propeller shaped part, it should be able to spin freely. If not, remove the debris so that it is unblocked.
Hope this helps (remember to rate and comment this answer).
May 14, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
Error message F18 what does that mean? i lost the manual... michael
F18 (usually!) means there's some issue with drainage. If the washer doesn't drain properly within a specific amount of time, you'll get the F18 error. A common fix is to remove the panel covering your drain and examine it for any sort of debris that may be obstructing it - plastic, lint, loose change, etc.
Mar 05, 2011 | Washing Machines
My washing maschine says F18. What does that mean?
If you let me know the Make of the machine, I can tell you exactly what F18 code is and what needs to be done to repair it.
Dec 31, 2010 | Washing Machines
E03 error code
Error Codes
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
Aug 09, 2010 | Siemens WTXD8300 Electric Dryer
Siemens WM14S794GB Front Load Washer Logo
224 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
