Question about RTO AquaScape 4500 GPH Pump
Where to buy a 20' power cord for Aquascape Pro 4500 pump?
  • Dennis D Oct 29, 2012
    It is a submersible pump, it had to be water tight.
8 years in aquatics so I took the pump apart. It wasn't getting any air so I looked at the diaphragm, it's split. I just need to know where to get a new diaphragm cuz that is not a normal one I would get from an aquarium supply store. Could easily just unhook everything and hook up an aquarium pump from the outside, wouldn't look as pretty but it would get the air flowing. Just buy a few feet of airline tubing.
Posted on Jul 19, 2014
  • Valerie Gilbert Jul 19, 2014
    Dang, sorry this posted under the wrong Homedics thing, was supposed to be under the air
    pump p-12-3 which was what I googled and it sent me here. Doh!
    Problem Solver:
  • 6 Answers
Maybe try to just buy a 20' extension cord cut off the connecting end and hardwire into the unit.... ?
Posted on Oct 27, 2012
2 Suggested Answers
pippall
  • 1486 Answers
SOURCE: Aquascape 4500 pump trips breaker when plugged in
water getting into pump.Thats what is triping it.
Posted on Aug 01, 2009
My Aquascape 4500 pump immediately trips the GFI when I plug it into an outlet. This happens both when it is submerged and out of the water. The impeller is not obstructed.
The seal has failed allowing water into the sealed motor unit and it is now shorted to ground...in other words the unit is shot and needs to be replaced.
John
Apr 07, 2011 | RTO AquaScape 4500 GPH Pump
Impeller shaft broke at impeller. moytor started to make loud noise . removed end of pump to find impeller at bottom of housing.
i have the wsame problem. A new pump will run me 550 I dont think I could replace the impeller shaft
Oct 17, 2010 | RTO AquaScape 4500 GPH Pump
Pump runs for about 3 to 5 minutes and then cuts out the breaker. The outlet is good because I've checked it with other appliances.
You have checked that sure thing, but if you have that pump on a shared circuit that thing draws more amps than normal appliances or is competing with another appliance and popping the circuit. Try isolating the pump and also make sure the circuit can handle the amp load the pump is giving off. Hope this is helpful.. Good Luck!
Aug 20, 2010 | RTO AquaScape 4500 GPH Pump
I have a AquaScape 4500 GPH Pump it has worked fine. Today I spent all day cleaning out my pond. All I did was lift the pump out of the pond and spray the muck off it. After completly cleaning the pond and...
Where the wire goes into the pump there is a o ring thatis probably leaking and any sort of water the motor might be getting is tripping the breaker. You probably have it plugged into a gfi and it sense very low amounts of water, and trips, You can determine by plugging it into a regular outlet and it should work. But definently fix the oring at the point of entry on the pump
Apr 17, 2010 | RTO AquaScape 4500 GPH Pump
Shuts off intermittantly, impeller moves freely
Does it come back on after resting/cooling down. If does peobably kick out on heat overload and is resetting itself. If impeller is free spinning with NO roughness or side play in bearing probably too much head pressure,pumping too far or too small pipe wich will cause excessive pressure making pump work to hard
Apr 10, 2010 | RTO AquaScape 4500 GPH Pump
Jul 31, 2009 | RTO AquaScape 4500 GPH Pump
Rebuild kit for the Aquascape SFA3000 Pump???
I have had the same problem everyone else has had with these pumps. I did serious research on these pumps and came up with a rebuild kit some parts bought some I make. I did mine 2 years ago and still working like a champ and have done over 20 locally with no problems. If your pump is noisy or the impeller has fallen off (typical) due to water getting in the unit and causing the bearings to fail email me and I can rebuild your pump. The process is simple send me the pump I will look at it and see if it can be rebuilt at NO CHARGE if it can be rebuilt you will save over 60% of a new one. Don't spend $349 - $599 on a new one let me look at it for free if I can rebuild it great if not you will have to buy a new one. I am not a dealer for any pumps so you will not have to worry about me selling you a pump and if you want the old one back pay the shipping and it it all yours.
Jun 18, 2009 | Ultra Max Aquascape AquaBasin, Pond or...
Aquascape 4500 not working
Typical with these pumps, pumps I have rebuilt that have done the same thing what happens is the bearings get loos and cocks the armature that is why it won't spin. I did serious research on these pumps and came up with a rebuild kit some parts bought some I make. I did mine 2 years ago and still working like a champ and have done over 20 locally with no problems. If your pump is noisy or the impeller has fallen off (typical) due to water getting in the unit and causing the bearings to fail email me and I can rebuild your pump. The process is simple send me the pump I will look at it and see if it can be rebuilt at NO CHARGE if it can be rebuilt you will save over 60% of a new one. Don't spend $349 - $599 on a new one let me look at it for free if I can rebuild it great if not you will have to buy a new one. I am not a dealer for any pumps so you will not have to worry about me selling you a pump and if you want the old one back pay the shipping and it it all yours.
Apr 25, 2009 | RTO AquaScape 4500 GPH Pump
Aquascape 3000 Pond Pump
I have had similiar experiances with these. My most durable pumps are 1. Atlantic water Garden Tidal wave 2 pumps. - ( 1 pump repaired in the last few years out of hundreds sold) 2. Pondmaster - most models. The pondmaster (Danner Mfg. customer service is fantastic- no hassle problem resolution). The pumps get better every year and THREE year warranty.
Nov 08, 2008 | Garden
RTO AquaScape 4500 GPH Pump Logo
127 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
