Question about Maytag Refrigerators
Maytag refrigerator won't defrost mmf 2258 - Maytag Refrigerators
3 Suggested Answers
  • 6 Answers
SOURCE: Freezer is not keeping food frozen
the problem just might be honey bees they buzz alot and if the infestation is to out of control it may cause the fridge to thaw the quick fix is to find the queen and remove it the others will follow i might add you may need protective gear for such a heroic feat
Posted on Apr 03, 2010
  • 2290 Answers
SOURCE: MAYTAG MBR2256KES Is a defrost
with the model number you sent you don't have a timer you have a jazz board in your machine,it's a computer board located behind the touch pad where you set the temps in the fridge section and the timer isn't the same as the defrost thermostat.let me ask you this is the frost on the back inside wall of the freezer or on the ceiling and frozen water droplets on the packages,a common problem with bottom mount freezers is the door gets left open mostly from a food package in the way,you push the door in,it hits the package,it feels like the door closed but it's open and warm air gets in and freezes up the air ducts.if it's on the back wall you have a defrost problem,bad defrost thermostat,defrost heater or computer board.if it's a defrost problem remove the bottom kickplate and look for the tech sheet,it will tell you how to put the machine into defrost,i think you open the door,hold in the lite switch,press the down arrow three times on the fridge setting,let go of the lite switch,press down again and you'll see an s,prees down again and you're in defrost,shut the door,but check that on the tech sheet,listen in the freezer,the fan shouls shut down and if it did go into defrost you'll hear a crackling sound,if the compressor is still running most likely the board is bad,,i can help you out if it's a defrost problem but first let me know if it looks like the door was left open or the inside back panel is covered with like snow or frost.
Posted on Sep 24, 2011
Kenmore Trio Elite Refrigerator (Model 596.76583601) Won't Cool, Freezer is Fine
the coil needs to be defrosted or the defrost timer is bad also go to sears.com and you can download a manual :) hope i helped a bit
Sep 01, 2012 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Freezer works fine but top refridgerator won't cool
HI.TRY DEFROSTING IT ALL FIRST.IT MIGHT WORK.GOOD LUCK.ALI
Jun 25, 2012 | Maytag Refrigerators
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Maytag Refrigerator MFF2557HES - won't stop running, everything frozen... despite adjustment to temp setting What to do, please and thank you?
Possible that the thermostat or the control unit is faulty as it fails to cut off the compressor.In some cases the frost or ice formation can reduce the connection or wire contact of the thermostat and so the function will not work. You need to remove the freezer rear covers to confirm if the wires are intact and also if the thermostat is working along with the auto defrost timer.
Sep 19, 2011 | Maytag MFF2557HES Stainless Steel French...
MSD2356AD troubleshooting refrigerator won't cool frezer is ok
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Maytag Refrigerators
Appliance is running but won't get cold. Freezer won't freeze either
I'm Leo
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | Maytag MSD2756G Side by Side Refrigerator
What a mess. The instruction manual (really lacking in detail) does not have part numbers or model description. Excess moisture dripping in refirgeration portion of unit (top freezer; bottom...
Yes it could, you will have to check your defrost water drain, if its plugged defrost water won't go to condensate pan under unit, instead will make its way down to refrigerator section
Jun 29, 2011 | Maytag Refrigerators
Apr 03, 2010 | Maytag 22 cu. ft. Bottom Freezer...
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
