Question about Sharp XE-A102 Cash Register
Reprogramming initial settings - Sharp XE-A102 Cash Register
  • Sharp Expert
  • 592 Answers
Next to the paper roll there are small 3 batteries, remove them and wait for 2 mins and then insert them back
Posted on May 16, 2014
Need barcode list for SG303
if you don't have the device application software download it from your cd driver that come with your device and locate the setting of the scanner in the configuration area you will find where you can initialization
Jan 14, 2014 | Manhattan Computers & Internet
Mitsubishi WD 52525 - Blue Screen RBGHV or YPrPb
Try unplugging the TV set from the wall for at least an hour or so.
Aug 23, 2007 | Mitsubishi WD-52525 52" Rear Projection...
I have a wd 52825 and accidentally hit the system reset button with a stiff brush...now the green light won't stop blinking and won't power up...what are my options?
I found this on the web .... might help ... dont know but it might be worth a try....also removeing the bulb and checxk it
Front Buttons Do Not Work Cause 1
This model is equipped with a keyboard lock feature. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds.
Locks up when Device Button Pressed Cause 1
1. Initialize settings by pressing "menu, 2, 4, 7, 0, enter" after settings have been initialized press the system reset button on the front once the LED stops blinking, reprogram the netcommand and tuner settings.
2. Initial and reset does not resolve suspect the DM PCB part # 934C116001 .
Oct 31, 2010 | Mitsubishi WD-52825 52" Rear Projection...
I have a pro 97 hand held cant get it out of clone mode
Your scanner is designed to automatically enter CLONE mode when a cloning cable is attached, and to exit CLONE mode when the cable is disconnected. If you do not currently have a cable connected, you will need to INITIALIZE your scanner to return it to normal operation. NOTE: Initializing the scanner will erase/delete all programmed data and return the scanner to its original factory settings. Before starting this procedure, be sure that you have a record of all programming information so that you can reprogram your scanner.
To INITIALIZE the PRO-97:
1. Turn the scanner OFF.
2. Turn the scanner ON. "Multi-system Trunking Scanner" appears.
3. Press the 0 (zero) key while "Multi-system Trunking Scanner" appears.
4. Press the 1 (one) key.
5. Press the ENT key. "Initializing please stand by" appears on the display for about five seconds.
Do not turn the scanner OFF until the initialization process is complete. When it is complete "M000" will appear on the top line of the display, and "Bank 0 Ch 00" will appear on the third line of the display.
Once the process is complete you can begin to reprogram the scanner.
Bill B
Listening in since the 60's
Oct 06, 2010 | Radio Shack Pro-97 Handheld Scanner
Cd player is not reading cds what can i do to repair it.
Subject: Radio With Six Disc CD Changer Does Not Recognize Loaded CD And Displays An "INITIALIZING" Message, CD Will Not Play, CD Cannot Be Ejected, Or Disc Icon Does Not Illuminate (Reprogram Radio)
Models:
2005-2006 Chevrolet Avalanche, Suburban, Tahoe
2005-2007 Chevrolet Colorado, Express, Silverado Classic, TrailBlazer
2005-2006 GMC Yukon, Yukon XL
2005-2007 GMC Canyon, Envoy, Savana, Sierra Classic
2005-2006 HUMMER H2 with Six Disc CD Changer Equipped Audio System (RPO UC6)
Condition
Some customers may comment on any of the following conditions:
• The CD loaded in the radio will not play.
• The CD loaded in the radio will not eject.
• The disc icon on the radio will not illuminate.
• The radio displays an "INITIALIZING" message for approximately 30 seconds after vehicle start up.
Important: Do not attempt to play CDs with paper labels on them in this CD player. The labels may warp or wrinkle and jam the CD player mechanism. Refer to the Compact Disc Care and Cleaning procedure (Document ID# 1656123) in SI for more information.
Technicians are to reprogram the radio with new operating software using the following procedure:
1. If the radio has a CD(s)2008 General will be necessary to reset the radio and remove them
before the radio is reprogrammed. Remove and reinstall the radio fuse to reset the radio and then eject the CD(s). If cycling the power to the radio does not allow the CD(s) to be removed, the radio may have another failure that will not be corrected by the reprogramming procedure that follows. Refer to the Diagnostic Starting Point - Entertainment procedure in SI to begin your diagnosis of this failure to eject CDs concern before reprogramming the radio.
2. Reprogram the radio using the Service Programming System (SPS) with the latest software available on TIS2WEB. Refer to the SPS procedures and the Radio Programming and Set procedure in SI for more information. As always make sure your Tech 2® is updated with the latest software version.
3. Verify proper operation of the radio and make sure that all CDs can be ejected.
Hope helps (remember to rate this).
Oct 03, 2010 | 2005 Chevrolet Trailblazer Ext
Samsung shr 1040
try resetting the system and reprogramming.
if that does not work you may need to have it repaired.
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
value will return to the initial
default value.
•Default Password is ‘4321’ .
mj
Sep 18, 2008 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
Samsung SHR-1040 DVR
try resetting the system and reprogramming if that does not work you may nee to find a factory authorized repair facility in your area.
Mode Key + CH 2
default value.
mj
Feb 10, 2008 | Samsung 4 Channel Dvr
HDMI Input problem
Initialize settings by pressing "menu, 1, 2, 3, enter" after settings have been initialized press the system reset button on the front once the LED stops blinking, reprogram the tuner settings
Dec 08, 2007 | Mitsubishi WD-62327 62" Rear Projection...
No digital inputs on the menu
Initialize settings by pressing "menu, 2, 4, 7, 0 enter" after settings have been initialized press the system reset button on the front once the LED stops blinking, reprogram the netcommand and tuner settings. 2. (Initialization and reset does not help) Suspect the DM PCB part # 934C116002
Dec 06, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Picture and sounds turns off and on by itself
1. Initialize settings by pressing "menu, 1, 2, 3, enter" after settings have been initialized press the system reset button on the front once the LED stops blinking, reprogram the tuner settings
Mar 03, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Sharp XE-A102 Cash Register Logo
81 people viewed this question
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
