Question about Konica Minolta Genuine Di650 Di551 Di5510 Di7210 Copier 604a Toner 8937-801
Bizhub Di5510 I changed th3e toner bottle and now I get no toner any ideas
Hi. i have bizhub 350. my problem is the toner hopper is not spinning/rotating. hv already changed the developer,the toner replenishing box and the drum assy, whole unit. what seems to be my problem here....
Sir, the toner bottle motor assy. needs to be replaced. will take quite a bit of work to get to, recommended a service tech qualified on Biz hub 350. This series is well known for the toner bottle assy. fault as is the di3510 series prior to the Bizhub 200/300 series.
Mar 25, 2015 | Minolta bizhub 350 Black and White Copier
Konica minolta bizhub 600 not automatic toner feeding how can resetting
1. Remove the toner bottle then turn on the machine with out bottle inside of it. Let it go though its normal operations then when the machine asks for toner install the bottle.
Dec 18, 2014 | Konica Minolta Bizhub 600 750 Image...
How to reset error c2558 in bizhub 215
I have solution for this problem now. I tried alot to sought out this C2558 error in bizhub 215 & 195 but i got failed. But now i have a solution for this error after wasting my 2 days & searching data, youtube, website, manual, installation guide & more. Here is solution for this C2558 Error in Konica Minolta Bizhub 215 & 195 :-
Step-1. You need to change your developer(a packet pouch of developer), if you have not done yet. if you have already changed your developer then jump to step2. (Note - for installing & refilling devloper into the cartridge check other guide on youtube for how to re-fill developer.
Step-2. Be Carful there should be no Toner bottle. Don't get confused with tonner bottle & developer both are different. so remove tonner bottel from machine.
Step-3. switch Off & re - switch on the machine .
Step-4. when machine finish warming after that - Press UTILITY (tool) button. Then Enter service mode by pressing the buttons [Stop], [0] [0], [Stop], [0] [1]. (Note you should press this sequence in continous). The display shows the service mode.On the menu SERVICE WITH chioce press [OK].Use the buttons next to the display and select menu FUNCTION.
Step-5. Press [OK].
Step-6. Use the buttons next to the display and select the menu AUTO ADJUST TCR.
Step-7. Press [OK] and set ATDC. For about 2 min. the following message appears: TCR TCR AUTO ADJUST GAIN: ### where ### is the number
Step-8. Turn the machine off the main switch.
(finished if there is no error message , you can check print without tonner bottel. after that if there is no error message of c2258 then you can put bottle inside)
If the machine displays an error message C2557 or C2558, check whether you have correctly connected terminal, which is detached when removing the developer.
Installing the toner bottle :-
Step-1. Before using the toner Shake the toner bottle.
Step-2. Open the front door.
Step3. Insert the toner bottle into about halfway with the label (Tape) on top of the toner bottle, and then slowly Just remove the label from the toner bottle.
Step-4. Align the toner bottle to mark the arrow and push the bottle to the far end of the toner bottle.
-----GOOD LUCK-----
Aug 13, 2014 | Office Equipment & Supplies
Help me to reset error codes c0070 & cof32 on minolta bizhub 210
C-0070 is the toner bottle, remove it, power off the machine, then with the bottle out turn the machine on, let it go thought its routine when it ask for toner install it PROPERLY if the knub on the bottle dented damage in anyway replace do not use the damaged bottle. the C0F32 is the toner is not properly mixing in the the developer because it is not getting any toner see above, Might need to replace the developer also.
Jan 27, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Konica minolta bizhub Di5510 driver for windos 8
You can try konicaminolta web site drivers are free. But Di5510 I believe best you can do is XP or windows 95. But give the web site a try.
Sep 26, 2013 | Minolta bizhub 200 All-In-One Printer
Konica Bizhub 200 touch screen doesn't get past the Konica logo screen.
power off the machine and take toner bottle out. Then turn the machine without the toner bottle. let it run it should ask for the toner bottle to be replaced. Please wait is the machine is conducting house chores prior to READY TO COPY. one is to ensure toner in the developer unit is properly mixed. Also might check. Power on the machine while depressing the utiltiy/counter button hold down until you see trouble reset touch ok power off then wait 10 seconds and power on. if neither works get a tech out to look at iti
Mar 30, 2017 | Konica Minolta bizhub 200 Printer
SC23-03 minotlta di551
SC 23 -03 M2 Drum motor abnormality.Verify the drum drive transmission mechanism and the drum gears and collars,and the main motor drive transmission mechanism it is an mechanical blocated problem.
SC 23-01 M13 toner bottle motor
SC 23-02 M3 developing motor abnormality
Feb 13, 2013 | Konica Minolta Genuine Di650 Di551 Di5510...
Error code c2558 for konika bizhub 215
I have solution for this problem now. I tried alot to sought out this C2558 error in bizhub 215 & 195 but i got failed. But now i have a solution for this error after wasting my 2 days & searching data, youtube, website, manual, installation guide & more. Here is solution for this C2558 Error in Konica Minolta Bizhub 215 & 195 :- Step-1. You need to change your developer(a packet pouch of developer), if you have not done yet. if you have already changed your developer then jump to step2. (Note - for installing & refilling devloper into the cartridge check other guide on youtube for how to re-fill developer. Step-2. Be Carful there should be no Toner bottle. Don't get confused with tonner bottle & developer both are different. so remove tonner bottel from machine. Step-3. switch Off & re - switch on the machine . Step-4. when machine finish warming after that - Press UTILITY (tool) button. Then Enter service mode by pressing the buttons [Stop], [0] [0], [Stop], [0] [1]. (Note you should press this sequence in continous). The display shows the service mode.On the menu SERVICE WITH chioce press [OK].Use the buttons next to the display and select menu FUNCTION. Step-5. Press [OK]. Step-6. Use the buttons next to the display and select the menu AUTO ADJUST TCR. Step-7. Press [OK] and set ATDC. For about 2 min. the following message appears: TCR TCR AUTO ADJUST GAIN: ### where ### is the number Step-8. Turn the machine off the main switch. (finished if there is no error message , you can check print without tonner bottel. after that if there is no error message of c2258 then you can put bottle inside) If the machine displays an error message C2557 or C2558, check whether you have correctly connected terminal, which is detached when removing the developer. Installing the toner bottle :- Step-1. Before using the toner Shake the toner bottle. Step-2. Open the front door. Step3. Insert the toner bottle into about halfway with the label (Tape) on top of the toner bottle, and then slowly Just remove the label from the toner bottle. Step-4. Align the toner bottle to mark the arrow and push the bottle to the far end of the toner bottle. -----GOOD LUCK-----
Jan 15, 2013 | Konica Minolta bizhub C450P Laser Printer
What is a service code c2558 mean on my copier?
C2558: Abnormally high toner density detected black TCR sensor
Reinstall imaging unit
Reinstall toner cartridge
Change imaging unit/K
Change PRCB
Sep 28, 2010 | Konica Minolta Bizhub c203 Copier
Konica Minolta Genuine Di650 Di551 Di5510 Di7210 Copier 604a Toner 8937-801 Logo
89 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
