Question about Avanti 308YWT Compact Refrigerator
Does not get cool
Motor hums and light is on but does not get cold
    New Friend:
Try add freon
Posted on Nov 23, 2013
Have a whirlpool washer that now hums when I turn the cycle on, no water just a hum
I had a similar problem - had to get a technician out - there was a valve at the back of the machine that allows the machine to fill. It had split (apparently its a common problem? there are separate valves for hot and cold water, so I'm not sure if using a different cycle choice (ie cold only), may let the machine fill?). 10 minute fix job
Jul 14, 2012 | Whirlpool Washing Machines
Even humming sound made when washer starts continous
Most likely a motor or solenoid has a loose coil or its magnetic field is vibrating a nearby piece of steel. If it hums all of the time except when the washer is filling, it is the timer or main motor. If it hums only when the washer is filling, it is one of the water valves (you can isolate by selecting hot or cold instead of warm for one of the cycles).
The timer motor is on the control panel right behind the cycle select knob. The main motor is under the tub. If the main motor is humming, it may be overloaded, but in that case, the humming should diminish as the motor gets up to speed.
Jan 27, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
My badger 5 garbage disposal just hums. There is no jam in the blades; they move freely in both directions. I've pressed the reset button and allowed the cold water to run. I've been working on it for 2...
When the motor goes bad, it begins to slow down until it stops.
That can happen suddenly, and now each time it hums, the motor is overheating and will never come back to life.
I wrote ez replacement step from days I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jan 16, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Need help with timer it is making a loud humming noise but it is still tirning yard lights on and off
If its a older model the timer motor is wearing and will hum. The cold weather will make it hum even louder
Dec 20, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
38CKC036 Air Conditioner: outside fan will not come on makes a humming noise...
If the humming is your compressor running (feel the large copper line going into the unit, it should feel cold aftter a few minutes of run time) then the fan motor or the capacitor or both need to be replaced, check for voltage to the fan motor when the unit is "humming" if it has voltage and will not start replace the fan motor and the capacitor. hope this helps.
May 18, 2010 | Carrier 38CKC036 Air Conditioner
Fridge light comes on & sound but not cold
The freezer fan motor may be bad. The main back panel in the freezer can be removed to check it out. Spin the motor wiht your finger to see if it tries to run. If it does then it is shot.
Go here for:
Whirlpool Refrigerator Parts
RepairClinic.com
appliance parts, help & more
Sep 21, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Hot motor
Replace the start relay and overload. Sea Breeze
Aug 03, 2009 | Magic Chef MCBR440 Compact Refrigerator
LG DLE5977W dryer has stopped and developed a motor hum. How can I fix it?
I am assuming that the hum indicates the motor is running but the drum is not turning.  Possibly a broken drum belt however the check filter warning is indicating low air flow so the blower wheel could be broken at the connection to the motor shaft.
Jun 01, 2009 | LG DLE5977 Electric Dryer
Avanti 308YWT Compact Refrigerator Logo
85 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
