Question about Tissot T Touch T33158851 Watch
Can i get an extra link for my tissot 1853 (prs 200) bi metal,the strap is to tight, and will not adjust anymore.
I dont know how old the watch is but it is unmarked. Diver style watch, gold and silver appearance prs200 embossed on clasp, but just a tad to tight...
I need one link for my watch that was given by my daugther its tissot diamond t shape stainless steel case,mop dial
Posted on Jan 30, 2013
escapement
  • 2334 Answers
SOURCE: Shortening stainless band for 1st generation Tissot Le Locle
Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 04, 2009
HyeProfile
  • 35 Answers
SOURCE: tissot prs200
I also own a PRS200. The sub dial at the top left shows the minute count when you use the chronometer function. In chrono mode, the top right subdial shows the milliseconds, the second hand shows the seconds, and the top left subdial shows the minutes (up to 30 minutes).
Posted on Aug 05, 2009
  • 183 Answers
SOURCE: Tissot PRS 200 hour and mnute hands not advancing.
I may not be clear on the problem here but it sounds like you may only need a battery change. If the battery is not the problem you can ask that your watch by placed on a cyclonic to force the gear train and free up small particle(s) that might be holding it up. This will be the fastest and least expensive. There is the chance this may require a more complicated repair but this till give you a starting point.
I suggest going to a watchmaker/technician who is familiar with working on this brand and be able to seal the watch back to its water resistant rating. This will take having a pressure chamber on site.
Posted on Sep 25, 2009
  • 61 Answers
Your true actual time second hand is on one of your subdials. That big "second" hand is really your chronograph seconds timer. It should start and stop when you depress one of the plungers/ buttons on the side of your watch.
Again, that big hand does not need to be turning all the time (or ever if you never use your advanced stopwatch/ chronograph). The true seconds hand is very small on one of the smaller dials.
Good luck, I hope that's all it is
Posted on Oct 23, 2009
SOURCE: My tissot prs 200 30 minute counter wont reset to zero
http://www.youtube.com/watch?v=3bvJWgBRVI8&feature=related here is the best answer for you.
Posted on Jul 19, 2010
Nike triax
Tissot 1853 I don't know how to reset the time after I changed battery.Pleas held me
Oct 05, 2013 | Watches
Don't know how to remove the links on my prs200
mcdevito75 here, Best Bet look for a small watch repair shop in your area to save money on cost. You"d need a special tool called a link remover tool available on ebay but you can also wind up destroying the band, and a tissot band is expensive, let the shop remove the links.
Jun 23, 2010 | Tissot PRS 200 Wrist Watch
Hi everyone, does any one know wher i can get tissot bracelet link prs 516 model j562.662 Thanks.
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 18, 2010 | Tissot PRS 516 T91142651 Wrist Watch
Stopwatch timer hands constantly in operation and ordinary time keeping not working. unable to perform reset.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to Tissot watch manuals and that will help to reset the watch. Rate me, plz.
Feb 16, 2010 | Tissot PRS 200 Wrist Watch
Where to buy a strap
you get watch straps on ebay or you can go to watch menders or market or jewlers have them
Oct 03, 2009 | Tissot Prs516 T91141731 Watch
Sep 25, 2009 | Tissot PRS 200 Wrist Watch
Can you tell me what 50M water resistant really means in a Tissot watch that uses a crown to set the time? PRS 516 Quartz, Chronograph. So can I swim with it?... (never mind the leather strap) Will it...
hi its a bit of a grey area as some cheap watches boast 50m water resistant but as its a tissot you should be fine but id rather you went to tissots website to make sure, just as long as you dont go diving it should be fine, good luck
Aug 21, 2009 | Tissot PRS 516 T91.1.486.51 Wrist Watch
Tissot T Touch T33158851 Watch Logo
354 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Shehu Pro
Shehu Pro
Are you a Tissot Watch Expert? Answer questions, earn points and help others
