Question about Jenn-Air 24 in. JDB2150AWP Built-in Dishwasher
Dishwasher is noisey when the pump is starts to pump water around
I own a Jenn Air JDB-5 dishwasher and it is bout 2 years old. The dishwasher has worked flawlessly until now. The unit will fill with water normally and the noise starts as the first cycle starts. It is a growly, hissing noise. I drained the water off and all the dishes where loaded properly and the arms where able to move freely. do you have any suggestions to the repair of this problem?
  • bcent95 Jan 03, 2009
    I have a feeling that is exactly what it is. There was a piece of plastic that broke above the dishwasher earlier today. It may have sucked that into the food grinder. It sounds like it will be an easy fix if that is what is causing the noise. Thanks so much and good luck to me.
  • 311 Answers
Yes somthing /pice of somthing has gotten into the works;usually its a chunk of glass or small pice of eazy way to fix.youl have to drain and go from the top down.[removing wash impeller pump cover and keep going down each time taking parts off and looking for some small hard afraid youl end up going all the way down to the chopper/food grinder.leave the screws in the parts you take off so wont get mixed up.take your time.ive done it hundreds off times i know you can pull it off , can do you can let it run like that thru some loads to see if will grind up or clean its self out.knowing what i know i would have no problem trying that on my dish washer.and have done it a few times.hope that helps God bless,tom
Posted on Jan 03, 2009
Just did the job myself. It was pretty easy, taking about 30 minutes once got the tools and dishwasher racks out. You'll need 2 different TORX (star screwdrivers) and a pair of pliers. A cordless drill with clutch will make it much faster, just set if to a low torque since you're putting screws into plastic.
I had a few small bits of ceramic in my food chopper, which is the metal blade/screen below the center pump.
Posted on May 16, 2010
Where can I get a parts manual for a Jenn air JDB-5
Try , they have all the diagrams for upper , lower and middle racks , and doors also , I ordered some rollers for a jenn air dishwasher last week and they delivered the part very fast and that was regular shipping, also the best price around , some other web site had it for 50 bucks + taxes and I paid 38 bucks + taxes and s&h! good luck.
Jul 08, 2014 | Jenn-Air Dishwashers
Dishwasher installed correctly? One year old jenn air dishwasher leaves brown **** and water film on plastic components inside, rinse agent used regularly
you must contact to jENN-aIR FOR get customer support, about the material recommend. About some agent used, or if some bad design material from factory.
God bless you
May 09, 2012 | Jenn-Air Dishwashers
Adjust door tension on jdb-5 jenn air dishwasher, door too heavy
There are springs on both sides of the door, likely one has snapped. You can get at the spring without removing the machine, sometimes, by pulling the bottom panels...
Jul 02, 2011 | Dishwashers
My Jenn- Air dishwasher (2 years old) used to clean great but now it is leaving a white film on the dishes and there is often residue left in the glasses as if it is rinsing with the dirty water. I can't...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
Nov 20, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Dishwasher displaying L# what do I do??
press start and light will not come on and start
jenn-air dishwasher jdb-5
Nov 14, 2010 | Jenn-Air JDB1095AW Built-in Dishwasher
Water not draining from diswasher
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Nov 03, 2009 | Jenn-Air 24 in. JDB1100AW Built-in...
Jenn-air JDB-2100aws dishwasher not drying properly
1. If you do not use Jet-dry liquid in detergent dispenser left side compartment, the drying result for dishes will be very poor.
2. You should check the heating element for continuity(conections for heating element under bottom panel of d/w).
Dec 15, 2008 | Jenn-Air Dishwashers
Jenn-Air 24 in. JDB2150AWP Built-in Dishwasher Logo
715 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
