This color strip is intermittent. It's a 50' Samsung led tv
It looks like the ribbon that is bonded to the panel is damaged. there are a couple of possibilities with that. its either burned or has become partially detached from its seating which can be countered by pressing on it. this happens over time due to warmth of the panel heating the tiny solder pins on the ribbon (this does require taking the tv apart, including the panel). if its burned, there is nothing you can do
Posted on Oct 29, 2012
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Most likely a bad connection--best case is a plug not seated or loose or even a bad connection on a board.
worst case is the same but inside the display panel (front screen) where it cannot be got at.
Posted on Oct 26, 2012
Either it was dropped hit or been moved around the house alot if it was ever hung once then it was probably hung wrong final started to crack after being taked down and its for a fact not fixable so sorry
2 Suggested Answers
RNS-Systems
  • 120 Answers
SOURCE: Samsung 50'' Plasma Turns off and on intermittently
This model is known for power board issues. You used to be able to get the repaired. its probably easier to buy a used one.
check ebay or www.RNS-Systems.com
Posted on Oct 16, 2009
Samsung LED TV problems
try first with the led strips noo need replacing t-con
Feb 27, 2017 | Samsung UN40ES6100 - 40" 6 Series...
I have a Samsung 32" LED tv model number UN32F5500FXZA. It has sound but no picture but passes the flash light test. I don't see any backlights. Any idea what the part is?
The backlights are located around the edge of screen inside the tv. Now this model is know to have LED failures. The LED strips are you backlights. The LED strips are powered by the power supply board but due to the fact that this model is know to have LED failures, I would recommend replacement of the LED strips, all of them, first. Samsung BN96 25300A Replacement LED Strips UN32F5000AF UN32F6300AF
This website currently doen't have the parts in stock for your tv however this will help you identify the parts and they even have some tutorials.
Feb 04, 2017 | Samsung Televison & Video
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
How do i fix a samsung lcd led tv burned out led backlights?
hi if its led backlit then there are strips of leds mounted within the screen assembly....each strip plugs in and you can test each strip by connecting 15-20v across each strip to see which does not light up...then replace that strip
Dec 30, 2015 | Samsung Televison & Video
Hello.... Samsung HL-P5063W Lamp LED blinks approximately 35 times followed by 1 long standby/temp light blink After this all 3 lights remain lit and flash....lamp/standby and timer makes a loud humming...
Sound like ur tv have two problems.The "lamp"LED light flashes,mean ur tv need a new projection bulb.The loud refrigerator sound,mean the tv colors wheel is dead,it spinning off of it axes motor.Hire a tv repairman to do this the colors wheel is hard change,because require take out many machanicals parts even to get to the colors wheel to change.The bulb is easy replaced,but he there pay him to put new one in.
May 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HLN5065W..no picture, TV won't stay on, 3 flahsing LEDs.
Lamp Fan, make sure all fans are running if they run for alittle while and stop Fan is defective.
May 01, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065 DLP TV - Turns on, have low quality picture
you have a bad color wheel replace it yourself its easy part is 95.00 plus s/h
May 26, 2009 | Samsung HLN5065W 50" Rear Projection...
Hlp5063w 50'' projected samsung lamp won't come back on ?
It could be the lamp but don't overlook the lamp door interlock switch. If the lamp door is not aligned properly, you may have intermittent shutdown or no start conditions. You can temporarily cross the interlock switch to confirm that this is the cause.
michtech
Feb 17, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
