Question about Philips 25’ High Speed Hdmi Cable 4x 1080p Swv3435s/17
I have a 47PFL6877 and bought a cable SW3432, and the cable doesnt work.hOw to configure it?
Trying to connect ethernet cable to router but the pc still wont get any internet access. does something have to be configured or should it work automatically?-jose
It should get an IP address automatically.
Is the router configured for internet ?
Is there a device thats already connected to the internet with this router ?
Feb 17, 2015 | Belkin Computers & Internet
Every time i plug in usb it doesnt work
Check the USB cable if it is a data cable or power cable.
Configure also in the main menu on the USB connectivity.
Hope that helps you.
Thanks for using FixYa!
Jul 15, 2011 | Nintendo DS Lite Console
If i disconect the ethernet cable from my laptop my wireless doesnt work at all
Maybe your laptop is configured to be the Internet server that is why every time you disconnect the Ethernet cable you lost connection. Your laptop is the one that gives connection to other computers.
Jul 14, 2010 | 2wire (1000-000057-000) Modem
I have a DI524 that was connected to my dsl modem before. Now I moved to a cable modem and connected the DI524 to the cable modem, but the wireless router doesnt work. help?
you have to confgure all the the setting in wireless configuration according to the cable connection then it will work.
Have a nice day and do not forget to rate please...!
Feb 02, 2010 | D-Link DI-524 4 Port Wireless-G Router -...
How do i hookup sata dvd drive
You should have been supplied a SATA cable if you have bought a new DVD drive. On your motherboard you will see 2 orange connectors just underneath where the older IDE grey cables plug in. Thesae are you 2 SATA connectors. They will be labeled as 0 and 1, if you are not using of these at moment connect to SATA 1 incase you decide to hook up a SATA HDD drive at some stage. Power cable just plugs in as usual. If PC doesnt recognise the drive you will need to go into the bios ( press DEL or F2 at startup) and it will be listed under something like drive configuration and just enable SATA there.
Jan 20, 2010 | MSI 661FM2-LSR Motherboard
My wii remote cursor works fine until i get to the main menu of the new game i bought. the cursor doesnt show up. i tried hitting the remote and "bull whipping" it but its still not working.
make sure your wii controller is properly configured, go to your wii system settings and make sure all the settings are correct and your controller is properly configured. Your proximity to tho sensor bar also plays a role in this, dont get too close :)
Jul 28, 2009 | Nintendo Wii Remote Controller
Doesnt connect
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix and use supportcall as your promo code for 1 free technical support. :-)
Jun 08, 2008 | Linksys WRT300N Wireless Router
Cant go wireless
I think the problem is not your laptop configuration. Can you check the setup configuration of the router it's maybe the wireless function is disable. Or try to reset the router to his default configuration. Press the reset bottom of the router for 15 second then try to connect your wireless connection if still not working setup again the router configuration.
thanks
Apr 15, 2008 | Belkin (F5D5231-4) Router
Philips 25’ High Speed Hdmi Cable 4x 1080p Swv3435s/17 Logo
41 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
