Question about Radio Shack 3 in 1 Universal Remote
I need the code for my sanyo TV, I also need a code for my sansui DVD player
    Top Expert:
  • Radio Shack Master
  • 75,591 Answers
Codes for Sanyo TV are: 0049 0097 0110 0004 0268 0012 0108 0180
Posted on Oct 27, 2012
3 Suggested Answers
  • 62 Answers
SOURCE: code for tv and dvd
Please refer to the support files and PDF manual here:
http://support.radioshack.com/support_video/52292.htm
p.s. I recommend that you save or print the PDF file in case Radio Shack takes it off the web.
Posted on Nov 13, 2008
  • 159 Answers
SOURCE: need code for Sansui TV
sansui: 1929, 1911, 1904
or use the general programming tool:
SEARCHING FOR YOUR CODE
If your device does not respond to the remote after
trying all codes listed for your brand, or if your
brand is not listed, try searching for your code. For
example, to search for a code for your TV:
1. Press TV once.
2. Press and hold P until the red LED blinks
twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power.
The remote sends IR codes from its library to
the selected device, starting with the most
popular code first.
5. If the TV responds, go to step 6. If the TV
does not respond, press CH+. The remote will
try the next code. Continue until the TV
responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps
1 to 6, substituting the appropriate device
key.
Posted on Apr 14, 2009
I have a sansui flat with build in DVD but don't have a remote the DVD will load but when push play it says operation not possible with disk what is this do I just need a univ.remote
First, check which input you have the TV set on. There may be an Input button on the side of the TV. (On the SLEDVD197, the button just below the DVD Eject button.) Just press Input and use the Channel Up/Down arrows to navigate the menu to change to the DVD. Press Input again to Enter the selected option.
With the TV in DVD mode, try pressing Play again. If you still have the error, check the region code for the disc. The "Operation not permitted" messages is usually that something on the disc is locked. Frequently, it's the result of using a different region code disc than the DVD player knows how to interpret. Try a different DVD.
If your TV doesn't have the Input button on the TV, you absolutely need a universal remote. However, you will want one that can match the TV/DVD button, the Input/Select button and the Menu button. Usually this requires a higher end remote; you also need a remote that was programmed at least 6 months after Sansui released the TV. If you do have the Input button on the TV, a universal remote may make using the TV easier.
I hope this helps.
Apr 13, 2015 | Sansui Televison & Video
How do I operate the dvd player with a TV or competitor DVD remote
Well you can maybe try and set it up on your setting screen it might take a while but it's worth a try
Feb 01, 2014 | Sansui VRDVD4005 DVD Player/VCR
I have a sanyo remote and a sansui tv how do i program the tv
Hello
I don't have a code for Sansui TV to be programmed with Sanyo remote control But hava a philips Universal remote model which can be programmed for Sanyo TV and has its codes.
Remote Model ===> Philips CL 034 Universal Remote Controller.
Codes
0115 0632
And herealong with I sends some universal remote codes, that you can check it for.
Four Digit Universal remote code for Sansui TV are
0135 0310
Three digit universal remote code for Sansui TV are
135/ 136
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Nov 25, 2010 | Sansui Televison & Video
What is the remote control code for bronsonic lcd tv for apex 1200 dvd player
Broksonic are:10180, 10463 other brands sharing 10180 are: Clarion, Contec, Curtis, Craig, Daytron, Emerson, ITT Nokia, Memorex
Other sharing 10463 are: KTV, Durabrand, Dynex, Electrohome, Emerson, sansui, Sanyo, TVS, Zenith.
Now for Apex DVD:30533, 30672, 30830, 31061 (this are for my remote, you going to have to match brands with your book)
other DVD brands sharing 30533: Sony, Shinsonic, Kloss
for 30672: JNC, Kendo, Nevir, Olidata, Matsui, Proceed, Proline, Roadstar.
For 30830: no match
For 31061:Koss, Polaroid,
Dec 03, 2009 | Televison & Video
Need code for sansui tv/vcr combo
Sansui 0000, 0240, 0479 (for TV use 0463)
GIve these codes a go
Hope this helps you out.
Cheers Little Dish Fitter
Oct 10, 2009 | Sansui VRDVD4005 DVD Player/VCR
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
I have a connect-it remote control and i need a code for a sanyo tv can u help plz
hello not sure what your remote model number is but i have instructions for the ER-440 and the codes given for the sanyo tv are as follows...
0141, ...0601, ...0981...1111,...1691,...2091,...0151,...0801,...1021,...1291,...1741,...2251
,...2551,...04011,...0821,...1101,...1351,2051
Hope this helps
happy new year.
Dec 22, 2008 | Jensen JER-422 Universal Remote Control
Radio Shack 3 in 1 Universal Remote Logo
63 people viewed this question
Top Radio Shack Televison & Video Experts
xxxxxx xxx
S. Gontko
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
