Economite e20 pilot contiuously goes out
Pilot goes out frequently
My pilot light goes out quite frequently can the flamepilot lightBE adjusted, if so how?
Some heater models can be adjusted. If you follow the pilot tubing from the pilot down to the control (gas valve), some have a small screw next to it. Remove the cap and adjust the screw counter-clockwise to decrease the pilot flame or clockwise to increase it.
Mar 17, 2015 | Heating & Cooling
Pilot light on my rheem water heater goes out frequently, model # 22v50f1,about 4-5 years old
There are many reasons why pilot light can go out, from bad thermocouple to low air supply to dirty combustion parts, clogged orifice, low gas pressure, etc.
Copy following link and read information available for troubleshooting pilot outage.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pilot
Jul 25, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot light frequently just goes out
If yours has an ODS pilot light, dust can get into the safety portion causing it to shut down thinking the oxygen is too low in the room. I use rust buster to flush the pilot without harming it. It has a long spout on it and that makes it easy to reach inside the heater.
More Here
Feb 05, 2011 | Dyna-Glo (PPH16-LP) Utility Heater
All of the lights contiuously flash and will not brew. I have reset the machine, unplugged and re-plugged the machine, dumped rinsed and refilled the water resivoir. Still nothing good and no coffee. I...
All of the lights contiuously flash and will not brew. I have reset the machine, unplugged and re-plugged the machine,All of the lights contiuously flash and will not brew. I have reset the machine, unplugged and re-plugged the machine, dumped rinsed and refilled the water resivoir. Still nothing good and no coffee. I have since put the machine away and have stopped trying to use it. Any help that you might be able to give would be greatly appreciated. Thank you Tandie Grant
Oct 26, 2010 | Braun Tassimo Espresso Machine/Coffee...
I have the radio code for 2003 Honda Pilot but don't know how to enter it with a number higher than 6 on the preset buttons.
here is the Honda site this should help Tim:
http://automobiles.honda.com/information/frequently-asked-questions.aspx
Oct 16, 2010 | 2003 Honda Pilot
My pilot won't stay on i've tried several times.
Your problem is easy and frequent. The pilot light should heat up the thermouple which in return by the heat will keep the valve on for pilot light first and the burner light.
So either the pilot light is not reaching the thermocouple - this only if someone moves the pilot light
Or the thermocouple became weak and can hold the gas valve open - so replace the thermocouple with new one.
There is a very small possibility that the gas valve is faulty but you should replace the thermocouple in any case which is very cheap first and is the most possible cause.
Oct 06, 2010 | Pitco Frialator PIT40SN Deep Fryer
Pilot light goes out frequently. Model # RMI 80NGT
Hi try cleaning the pilot light could have some dirt in it or its the thermocouple
Jan 17, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
Pilot light on water heater goes out frequently and thermocouple has been replaced 3-4 times. Richmond 30 gal, gas, model 5V30T. Thank you
Check the following:
See if your heater has a pilot gas adjustment valve. It should be on the gas control valve somewhere. Not all heaters have these. It will be a screw on the valve that can be turned.
Make sure the thermocouple sensing bulb is squarely in the pilot flame and also check that the fitting where the other end of the thermocouple connects to the main gas valve is tight.
Check the pilot gas orifice (where the pilot gas comes out) for carbon build up - you may need to remove the pilot gas line and thermocouple assembly to get to this. This problem is pretty common.
Check the gas pressure to the heater. Run the hot water in the dwelling until the hot water heater starts. Check the flame on the main burner and see what color it is - it should be blue with possibly some yellow-tipped flames. If not, there could be a problem with the gas pressure at the heater or venting. If the heater has a gas pressure regulator, it may be out of adjustment or defective.
Finally, and this isn't very common, the pilot light can be extinguished if there is a draft problem, usually associated with an issue with the flue pipe venting system for the heater or another nearby gas consuming appliance.
Dec 31, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Pilot goes out ocassionaly.
The pilot going out could just be caused by location. If it is near a door or other source of heavy breeze it will blow out. if it can not be relit or happens very frequently check the gas supply to the pilot tube, Pilot oraface and thermocouple
Oct 12, 2009 | Ace Hardware MN180HPA Wall Mounted Panel...
Too many E20 errors!
the first thing i would try is the pump..........if its not draining all the water out it will take longer to finish...........pump could be blocked......alst the hose from the pump........check both first.....
cheers
Aug 03, 2017 | Zanussi ZWD1680W Front Load Washer / Dryer
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
