Question about Lexmark 4428-001 X2500 Inkjet Printer P/N: 4428-001 - Original
What ink cartridge for lexmark 4428-001
Need replacement cartridge number
SOURCE: Refill cartridge for lexmark X6570
please note that I am not an expert, in this field just an attorney and that is why I am putting my full disclaimer right here at the top---That i am not an expert but only speaking from experience.
Earlier this morning, I just pulled the cartridges to check the Lexmark print (X6570) cartridge numbers (41&42). When I typed these numbers in on inksell.com to retrieve the price and other information for these cartridges, they did not have any refill kits or anything of that nature for these specific cartridges.
To answer your question about why the printer is not detecting that your cartridge is full is probably because the cartridge has a chip in it that essentially disables it once the original manufacturer ink is empty. tHEY [Lexmark & Dell] do not want outside competition In other words, the printer manufacturers make the bulk of the money on selling new cartridges (for a fortune) . To make matters worse, they always seem to be half empty even though they are ‘brand-new’ ink cartridges The bottom line is that the faster you can go through a printer cartridge, they can sell many more of the cartridges that they are charging us a fortune for.
Needless to say, I am just going to go and get me another HP printer. My advice would be to check to see if ink-refill kits (see sites like inksell.com) are available for any future printers that u purchase.
Posted on Nov 08, 2008
SOURCE: ink problems lexmark x2500 printer
lexmark ran out of ink replaced cartridge. still saying i am out of ink and wont print anything
Posted on Dec 04, 2008
  • 81 Answers
SOURCE: lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Posted on Jan 03, 2009
rwandrew
  • 115 Answers
SOURCE: Lexmark x4850 ink levels won't reset with new cartridge
Hi...
Silly question, but I have done this myself. Have you removed the tape from the bottom of the cartridge?
Posted on Jan 25, 2009
Ajkill
  • 2035 Answers
SOURCE: lexmark x5490 Right /left cartridge incorrect
If you brought new cartridges and printer detecting it empty ,then you get it
replaced as the Lexmark cartridges comes with a 6 months warranty ..
Good luck....
Posted on Mar 26, 2009
I have a Lexmark 4420-001 printer/scanner and I do not know the ink cartridge model number.
Walmart and Amazon carry the ink. You may find authentic Lexmark cartridges, and possibly also re-manufactured cartridge for sale.
Lexmark No. 1 Ink Cartridge, 18C0781
Examples to show it for sale online - you may want to search using
http://www.google.com and enter the word 18C0781
https://www.amazon.com/Lexmark-018C0781E-LEX18C0781-18C0781-Ink/dp/B000A8RN3O
https://www.walmart.com/ip/Lexmark-No-1-Ink-Cartridge-18C0781/4404164
Lexmark No 1 Ink Cartridge 18C0781 Walmart com
Apr 10, 2018 | Lexmark Office Equipment & Supplies
Is it true that both my new Lexmark Prevail Pro 705 print heads quit printing in color is because I didn't use Lexmark OEM ink cartridges?
Some Lexmark cartridges have an RF chip mounted underneath the label on top. Most of these are set to self destruct on first use to prevent refilling. You probably need to risk the cost of a new cartridge to find out if it is a cartridge problem or a printer problem. Unfortunately you should not take out a cartridge or replace one while the machine is powered. The system also frequently registers an serial number on the cartridge and stores it to prevent "hot swapping" cartridges
Dec 11, 2017 | Lexmark Prevail Pro705 Wireless AIO...
Poor print quality
Make sure you are using genuine Lexmark cartridges. Lexmark products work best with original supplies. Lexmark does not recommend the use of refilled, re-manufactured, or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark.
Check your cartridge ink levels. From the printer operator panel, go to Maintenance > View Ink Levels. Replace the cartridge that has low ink level. If your ink levels are still substantial for printing and you are using genuine Lexmark supplies, please contact Lexmark Technical Support Center for further assistance.
Dec 28, 2011 | Lexmark X9350 All-In-One InkJet Printer
How to replace the ink cartridge
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
Lost my manual, need to change the ink cartridge, help
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
Does the lexmark x2500 need a special type of ink?
If you go into the office supplies store, there's usually a guidebook for each manufacturer of printer, and what cartridges it takes. Otherwise, you can look on the sides of the packages, and there will be a listing of the makes of printers it will work with. If you hadn't thrown it out, an ink cartridge recycling service would take the cartridge and replace it with a refilled one, with a discount in exchange for the empty.
Oct 22, 2009 | Lexmark X2500 All-In-One Printer
A4000 All in one compaq fax machine replacement ink cartridge
Lexmark 70 for the black ink cartridge
Lexmark 20 for the color ink cartridge
Mar 26, 2009 | Compaq A4000 All-In-One InkJet Printer
Message wrong cartridge on lexmark 7170 printer
for Lexmark x7170 ink cartridge is #32 and #33.
double check the number on the ink cartridge. and make sure to take the tape off the bottom of th eink cartridge before insert it in the cradle.
as far as the cleaning. there are contact pins in the ink cradle and on the bottom of the ink cartridge.
clean them using a coffee filter with little alcohol.
Dec 03, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark x3430 need ink cartriage
This is the only information I could find. Didn't your printer come with a black and color ink cartridge? If it did, all you need to do is take the ink cartridge out and write down the numbers written on the cartridge. The only ink cartridge I could positively confirm was the #24 color ink cartridge. The Lexmark website does not list any black ink cartridges for this model. This information was obtained from Officemax.com.
Lexmark - 24 Ink Cartridge - Color
Compatible with Lexmark Z1400 series, X3500 series and X4500 series printers;
Lexmark - 23 Ink Cartridge - Black
Compatible with Z1400 series, X3500 series and X4500 series printers;
Sep 15, 2008 | Computers & Internet
Lexmark 4428-001 X2500 Inkjet Printer P/N: 4428-001 - Original Logo
207 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
