Question about Balance CM2019 19" LCD Monitor
I have a IC Power 19" LCD Monitor I ran over the power Supply and I need a nother one. However the label on the power supply was damaged to the point the information is un-readable The M/N is L1952 and the Model Name is CM2019 I have not been able to find a power supply using these numbers from thr monetor. Can you help find a power supply for this Monitor? Thank you Bob
  • 3 Answers
It's not a standard cord it has an adapter and a tiny three prong input into the monitor. Hard to find.
Not on Ebay at this time. Here is what you need. 15V 4A power adapter for
Balance monitor product # CM2019 F192 monitor (miniIEC 3-prong plug) part number - LAD6019AC3
This site had them but are out know lcdpayless.com Ebay doesn't have one right now.either!
Let me know if you find one! nicheguy1@gmail.com
Dan
Posted on Mar 20, 2009
  • 827 Answers
It uses a 100-240volts AC adaptor:
Just ask for that at your nearest electrical store.
Hope this helps
Chris (ziraffa)
Posted on Jan 03, 2009
Hi, I have a Polyview V293 LCD Monitor with a power supply output of 19v 3.42A. The power supply has failed. Most i have found being offered as direct replacement for this monitor have an output of 19v...
If the power adapter is a separate from the monitor then check the monitor's label on the back of the screen for the power rating.If the rating on the label is greater than 3.16A then I would not purchase this adapter.
I suggest you purchase an adapter with a current rating greater than what is stated on the monitor's label.
Check out this WEB site for power adapters - a 19Volt 90 watt = 4.7A power supply is suitable.
http://www.cheaperoz.com/z/result.jsp?ga=sc1&q=19v+power+adapter
Apr 01, 2011 | Amptron POLYVIEW 19" Monitor
Takes awhile for the monitor to turn on
This is common with this model. The switch mode power supply is not starting up when it is switched on. This supply creates 12VDC to operate the monitor. It could be the IC, a resistor or a capacitor in the start up circuit.
Monitor Miike
Apr 12, 2010 | ViewSonic VP191b 19" LCD Monitor
110v lcd tv was plugged to 22ov outlet
Hello nik286, hi, check first the label at the back of the TV, look for a voltage input something like a 90V-240V, if you see this, its an autovolt system, this type of power supply input is standard nowadays. Assuming your asking what would be damage, this could be anything from the fuse, thermal resistor, rectifier diodes, and the regulator IC of the power supply board.
Apr 12, 2010 | Sansui 19 in. LCD TV
Xerox XG-19D LCD monitor goes black in 5 seconds
You may also have to check the IC/Transistors Inverter transfomer drivers, also should Ohm out the resistance of the transformers.
Mar 18, 2010 | Xerox XG-91D 19" LCD Monitor
My Dell 1905FP 19 monitor went black & green power light flickers
It sound like a short circuit. I had this problem with 1907FP model. It had an USB port on the monitor which got damaged and it was shortening to the groung. In your case it might be a bad internal power supply board.
Nov 20, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
No sign of power
have the switching power supply checked or might need a replacement
Aug 10, 2009 | Gateway 19" Flat Panel LCD Monitor
DELL LCD 1901FP PlZ Find IC Number
The 8 pin IC is UC3843A, SMPS controller. The 14 pin IC is TEA1533AT.
Monitor Mike
Jan 28, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
Gateway FPD1975W black 19 inch LCD
most likely is the power supply in the monitor.
gateway LCD has a building power supply in the monitor. it supplies 38W to the lamp.
since there is no display, it tells me that there is no power to the monitor.
if try another monitor and it works fine. then the problem is the monitor. (dispaly lamp is good for 17 Years- according to the tech spec.) but the power supply is pushing too much power.
other vendors max power is apporximately 30W.
make sure there is nothing behind the monitor and has good air flow. Since there is no fan in the unit. it need to vent the hot air natually.
Oct 18, 2008 | Gateway FPD1975W 19" LCD Monitor
X2gen 19" monitor
open the monitor there is a vertical ic which has small alluminium heat sink ckeck 12v supply to ic if present then remove ic & check 12v at same point if present then replace ic if absent then check 12v regulator ic if faulty replace it
Jul 20, 2008 | X2Gen MG19MY 19" LCD Monitor
Balance CM2019 19" LCD Monitor Logo
651 people viewed this question
Top Balance Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
