Question about George Foreman GGR88DK Double Knockout Indoor Grill
No power or anything - unit is dead
I have power to the grill itself but nothing after the circuit board, obviously something is wrong here - ANY IDEAS.... for an easy fix Checked all the joints and connections etc. can't see anything obvious.
  • 883 Answers
Do this test for heating coil: connect a second ac supply cord directly to the coils wires. does it heat? if so, a fix is feasible. the problem is either the thermostat or a blown component on the board. neither are easy
Posted on May 28, 2007
SOURCE:
What could be causing the fuse to blow in my Emerson microwave oven?
a blown fuse is a dead short of the circuit
it could be a failed power board , control board , megatron, light wire anything powered by the fuse
good advice is to take it in for a proper diagnosis and quote
Sep 30, 2016 | Emerson Microwave Ovens
Why does it keep going into protection mode?
There are several circuits that can prevent start up, not the least of which is the power supply itself. Check the owners manual, it may tell you about conditions that could cause this. The next step is to open it up. There may be something obviously wrong, burnt, disconnected or stressed. Barring that, we'd be into board and component level testing. If you know what your doing, the output stages of these high power amps are a good place to start.
Mar 01, 2016 | QSC RMX 5050 5,000 Watt Power Amp
SAMSUNG SP-50L7HX DEAD FUSE BLOWN BLACK OBVIOUS SHORT CIRCUIT ANYONE KNOW ANYTHING IF BOARD REPAIRABLE O
Try shopjimmy.com who carries almost all the Samsung boards--if fuse right where power cord does come in trouble is right there.
Aug 30, 2012 | Samsung Televison & Video
Green lights on screen blank no picture no sound nothing
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 23, 2017 | Hitachi 42HDT51 42 in. Plasma SLC1551AW
After a thunder storm my roof mounted Carrier cooling/heating unit stopped working and now does nothing. Changed the time delay fuses and checked the circuit breakers and they seem fine. Is there a reset...
You may have a circuit board problem. Make sure you have power to the unit first. If you can, get on the roof take the access panel off to the electrical components. Most carrier circ boards have a flashing light display on the board itself. On the back of the panel you just took off should be a kiosk that tells you what the flashing means. If the light is dead, no color but you are sure there is power to the unit, the board is bad or there could be a fuse blown on the board. Most circ board fuses are a small 3 or 5 amp blade fuse mounted right on the circ board. I have seen many a carrier board burn out because of lightning. I hope this is not the case for you, as carrier boards are just a little expensive. Hope this helps you get some air back. Mark
Aug 01, 2011 | Heating & Cooling
Sanyo EM-710F display dead
Low voltage Tx actually OK. Restored vaporised circuit tracks on controller board, fuse and interior light globe. All working OK.
Jun 18, 2008 | Microwave Ovens
Problem
If the AC power source (outlet) is ok and the line cord and fuse are ok but the unit is completely dead, you may have a problem with the internal switching power supply.
Locate the switching power supply and see if there is a fuse on its circuit board.
Completely dead units are typically caused by a failure in the power supply section.
Please let me know if I can be of further assistance to you.
- Jim
Mar 06, 2008 | Sony SLV-D360P DVD Player/VCR
Foreman Grill GR36CB stopped working
Foreman grills have a fuse on the circuit board, have you popped that section open to visually check the fuse? It could be that simple. Fuses do wear down over time, so depending on how much wear and tear you put in, it could just have broken on its own.
Of course, if you replace the fuse and it still goes, you'll need to double-check to see what's shorting it out. The unit may be dead but I wouldn't bet on it.
Nov 08, 2007 | George Foreman GR36CB Indoor Grill
The TV just Shut off
yes we called it dead set. but this can still be fix. this symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, video if,sound if, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician
Jan 19, 2007 | RCA F25216WT TV
George Foreman GGR88DK Double Knockout Indoor Grill Logo
219 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Thomas F. Schneider
Mike
Gerry Harvey
Gerry Harvey
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
