Question about Bosch 64612 Throttle Position Sensor
Wat does the throttle position sensor do
Car shakes when seating still , does not pick up speed it is a 98 plymouth breeze 2.0
  • 3 Answers
Throttle position sensor its a sensor that reads where the throttle pedal are to give the car "brain" the information about how much gas+air mixture need to be used.
Posted on Oct 26, 2012
Today my car started 2 cutout i jerks back an forthbut wen im up 2 speed it dosent do it
It's a 98. But the first things to check and do are. Check for vacuum leaks, I would replace all the lines if I found one. Next is to clean the throttle body, idle air control motor, and replace the air filter.
Aug 25, 2015 | 1998 Plymouth Breeze
Need obd trouble codes & meanings
here r your trouble code meanings:
1) p0123-throttle position sensor circuit, high input.
2)p0117-engine coolant temperature circuit, low input.
3)p0118-engine coolant temperature ciurcuit , high input.
Jun 18, 2012 | 1997 Plymouth Breeze
Where the temperature sensor on a 98 Plymouth breeze
2.0L is here---
Jul 02, 2011 | 1998 Plymouth Breeze
98 plymouth breeze wont start turn key to start nothing just seat belt light
make sure battery connections are clean and tight . make sure battery is good and fully charged, chek all fuses.
Mar 22, 2011 | 1998 Plymouth Breeze
How to find speed sensors to install, 1997 Plymouth Breeze, automatic, 2.0. Car won't shift out of first gear.
If your tachometer and speedometer are working , then it is not likely the shaft output speed sensor that is not working. Your car is in limp home mode , and more often than not it is the transmission computer that is dead. It is usualy mounted just behind the radiator on the drivers side of the car. It has cooling fins on it and looks somewhat like a stereo amplifier.
I recently replaced several sensors on a 2.5 L cirrus with no luck , picked up a computer at the auto wrecker and all is good now. Be sure to disconnect the battery , and touch the positive wire to the negative post to de-energize everything before unpluging the computer.
Feb 04, 2011 | 1997 Plymouth Breeze
Where is the throttle position sensor located on 1998 plymouth breeze 2.0 ltr.
The throttle position sensor should be located right on the throttle body, just opposite where the throttle cable linkage is. It's a black sensor, probably around an inch and a half wide.
I hope this helps! Let me know if you have any other questions. :)
Mar 05, 2010 | 1999 Plymouth Breeze
Where's the crankshaft position sensor located in 98 plymouth voy
Guessing it's a 6 cyl, 3.0L, but should be located on transaxle housing above vehicle speed sensor.c937fe4.jpg
Aug 31, 2009 | 1998 Plymouth Voyager
Loud knocking in my engine?????
It sound like you dropped valve seat on the head. Did you recently over heat your engine .
May 12, 2009 | 1998 Plymouth Breeze
Camshft position
Bank one is commonly known as the O2 sensor. You seem to having a issue with it.
Jun 24, 2008 | 1998 Plymouth Breeze
Bosch 64612 Throttle Position Sensor Logo
80 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
