My tv panasonic 14 inch theproblem is line horizontal black&white .the stand by light show on& off.
    Top Expert:
  • Televison & ... Master
  • 73,698 Answers
There is some loose solder terminals at it vertical output section, or vertical output IC itself has failed. Check it. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Posted on Oct 27, 2012
4 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: Horizontal White line across TV
Hello, This is an indication that the vertical stage of your TV has failed. This can either be caused by the Vertical coupling capacitor malfunctioning, the vertical output transistor and or amplifier stages or a failure in the yoke transformer. I would suggest that you get this repaired by a qualified TV repair technician. Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 11, 2009
SOURCE: Sony Trinitron 21 inch KV-G21M1
what is the securet code of this tv. No picutre, sound but video mode is good. how to solve this probles.
Posted on Feb 18, 2010
SOURCE: Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Posted on May 23, 2010
Tip
TV shows either: black screen with: white vertical or, horizontal line
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, find the too hot transistor or, chip; using component coolant; spray the too hot component with the component cooler until the screen comes back to normal. To fix: apply white coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Televison & Video
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
My panasonic tv started displaying white lines
some capacitors are faulty in the vertical section of ur tv,, they must be replaced ,calla service pro to replce it 100mfd 50v capacitor
Mar 18, 2010 | Televison & Video
RCA 27 in has white horizontal line going through the middle
this symptons is caused by a breakdown in the vertical deflection circuit. hence, the trouble may be in the vertical oscillator, amplifier or output circuit. in most modern tv the vertical ic is usually composed of these said circuit inside. the ic have many pins, standing on a heat sink and smaller in size. try to check also the capacitors surrounding it. sometimes leaky capacitor may cause this problem. good luck!
Aug 16, 2009 | RCA TruFlat 27F520T 27" TV
Dec 30, 2008 | Panasonic TC-14KM30R 14" TV
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Black line in a 42 inch panasonic plasma tv
I have a 2 black lines. One goes horizontal and one runs vertical. Is this something I can fix?
Jan 22, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Grey screen, white lines
adjust your screen at the back of tv flyback down you see the fucos and screen adjust the sreen ok
Nov 06, 2006 | Panasonic CT-36G34 36" TV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
