MAYTAG ATLANTIS MAV6200AWW WILL NOT COME ON AT ALL.
WASHED CLOTHES ONE DAY, THE NEXT DAY MACHINE WILL NOT COME ON. I HAVE CHECKED FUSE, THE OUTLETS, THE HOSES, AND EVERY THING IS OK. HOW OLD IS THIS MACHINE ANYWAY?
I did not know there was a fuse inside the machine. How do you get to it? It is expensive to call a repairman for this problem? Does anybody know what the going rate is for a repair?I did not know there was a fuse inside the machine. How do you get to it? It is expensive to call a repairman for this problem? Does anybody know what the going rate is for a repair?
You can't post conmments that contain an email address.
I found a ground wire connector broken. replaced the crimp connector to join the two ground wires and put it under the bolt where it was supposed to go and the machine worked. Prior to this it was intermittant due to the ground touching sometimes and sometimes not.I found a ground wire connector broken. replaced the crimp connector to join the two ground wires and put it under the bolt where it was supposed to go and the machine worked. Prior to this it was intermittant due to the ground touching sometimes and sometimes not.
CHECK TO MAKE SURE ALL THE SUSPENSION SPRINGS ARE CONNECTED INSIDE THE WASHER. IF SO, THERE IS A SNUBBER UNDER THE WASHER MILKSTOOL THAT IS MADE OUT OF PLASTIC THAT CAN WEAR AND NOT ALLOW THE SUSPENSION TO GLIDE LIKE IT IS SUPPOSED TO. NOT THE EASIEST FIX DUE TO THE BRAKE BEING UNDER HEAVY SPRING PRESSURE. USE CAUTION
Check whether the power plug of machine is good,
connections, fuse, etc. All good, then try below:
Plug off the wall socket. Open up the machine. Remove, reseat and
reconnect every connector
at
least 3
times. Remove the motor control board, spray it down with electronic
cleaner
along with all connections by disconnecting them, spraying them down.
Disconnect and connect a few times to ensure good contact.. This
normally works.
Pl give me a ‘very helpful’ rating for the free
help,
thanks.
hi thanks for the question sometimes a lot of suds in tub will cause this cause lint and suds stick to the outer tub and is difficult to remove try filling the tub with hot water and use vinegar in the water half bottle let stand for 4or 5 hrs . now drain the tub should work thanks for the question the appliance doc
Check and make sure the seal at the bottom of the washer is not wore out. Alot of times you will get grease from the bearins and drum assembly if this wears out.
its not a fuse its a mains capacitor/filter it is located next to your motor if this is faulty machine wont work it will either be a plastic cyclinder/a metal 1 about 4inches long with writing and numbers on it
