Question about Microsoft LIVE ONECARE 2.0 XP/Vista for PC
My xbox live doesnt work
My ip adress says failed but it has worked before
  • Rabid Feb 19, 2009
    XBL wont work! can you help me?
  • sharkfish Mar 12, 2009
    well iv put my wire in the bk of the xbox then put in the bk of the internet hub thing n then i preesed join xbox live and its says theres a problem with the x box live connection
    Problem Solver:
  • 19 Answers
The reason for this part to fail differs along with the difference of the type of connection you are using to connect your Xbox 360 console as follows:
a. Direct connection to modem:
1. Make sure first no other devices connected to the modem at the same time as some modems has an Ethernet port along with a USB port so, you might think you can use both at the same time & connect the PC through USB with the console through Ethernet & that's incorrect so, we need to disconnect the PC first.
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live". 3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Edit Settings” then “Additional Settings” tab then select “Advanced settings” & put the Physical Address of your PC without the dashes on the “Alternate MAC Address” part and select "Done", when it asks you to Apply Settings choose “Test Xbox Live”.
b. Wired connection to router:
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
c. Wireless connection to router:
2. Go on the Dashboard of your Xbox 360 console to the "system" area then "Network Settings" then "Edit Settings" then select your wireless settings part down there "Wireless Mode, Network Name,..." the console will automatically then search for your wireless network and when it find it and you select it, it will ask you to enter your wireless key which is called WEP or WPA key - you can find it written on your wireless router or then you need to contact your ISP (Internet Service Provider) to get it from them - when it ask you to apply settings select "Test Xbox Live".
3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you’ll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can put the Xbox 360 console - as a trial - in a closer position to the router to see wither it's going to pick up an IP address or not.
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
d. ICS (Internet Connection Sharing):
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore to Factory Default" when it asks you to Apply Settings choose “Test Xbox Live”.
2. Allow the ICS option on the PC as mentioned before, then test Xbox Live.
3. If it's still not working, set the IP Settings manually to be:
IP Address: 192.168.0.2
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.1
Then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose “Test Xbox Live”.
If you faced any other kind of troubles with this part failing even after you tried these steps please check me man
Posted on Jan 09, 2009
My xbox 360's connection with xbox live stopped
download the next update to a usb stick via pc and install it on your game system-I had the same problem with an update a while back and had to wait for them to create another update with the patch
Apr 07, 2010 | Microsoft Xbox 360 Console
Ip adress failed
u should try ringing ur internet server and u dont connect it to ur laptop u connect it to ur modem and router and btw for some reason xbox live doesnt work for everyone it weird but no one knows why
May 09, 2009 | Microsoft Xbox 360 Elite Console
Failed Ip adress for xbox live
First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
Here are some steps that you need to try:
1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
2. Go to your network settings
3. Select restore to factory defaults and test your xbox live connection
Apr 03, 2009 | Microsoft Xbox 360 Console
Ip adress keeps failing...?
Are you sure nothing else on the network your using has the Same IP Adress. If anything does, This IP will not work.
Jan 04, 2009 | Microsoft Xbox 360 Console
Right ip adress in xbox360 but it keeps failing..?
You don't set the IP address (You can but that's a whole nother story, IP address' have to be unique to the device), you need to let your router assign one automatically. Two devices on the same network can't have the same IP address or it will fail to function completely.
Dec 30, 2008 | Microsoft Xbox 360 Console
Xbox live is not working
How are you connecting Your Xbox console upto your Internet ? if your Connecting Via WiFi, Make sure you have the Xbox compatible WiFi adaptor, if you are connecting Via a Local Area network, Ensure that your Console is hooked up Directly to Your Router, and if your connecting Via a Shared internet connection thru a PC, Ensure it is Hooked up correctly and also that your computer is set up to allow sharing the internet connection, That sometimes makes Xbox live faulty.
Also another problem for IP addresses not working is Due to your Internet service provider, Some broadband companies constantly renew IP addresses changing them every so often which the Xbox doesnt like. I would suggest contacting your Service provider and seeing if they have any Technical Support !
Oct 27, 2008 | Microsoft Xbox 360 Console
Xbox live failed
This site has good information relating to connecting your xbox 360 to xbox live wirelessly with laptop or modified router and improving xbox live NAT rating:
How to connect to xbox live wirelessly
Aug 19, 2008 | Microsoft Xbox 360 Console
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Get go to xbox live
For some reason everyone has the same problem buy the Xbox 360 wireless kit and should work but for now you might as well just wait untill get its fixed
Dec 30, 2007 | Microsoft Xbox 360 Console
Ip adress all messed up
is the ip adress set on DHCP?
if not, set it on that
Dec 08, 2007 | Microsoft Xbox 360 Console
Microsoft LIVE ONECARE 2.0 XP/Vista for PC Logo
281 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
