Question about Plantronics Discovery 925 Bluetooth Headset
Plantronics Discovery 925 keeps blinking purple light
My 925 was paired with two devices. One day when charged in the case, it started to blink purple. If I pressed the talk button, it'd stop. However there's no way to get into pairing mode any more. Is there any way to reset this? Thanks,
  • 3 more comments
  • Anonymous Feb 02, 2009
    I have the same proplem and i still search to fix it
  • bethkunz Feb 04, 2009
    I had mine paired to just one device.  After charging, it didn't connect to the phone.  I turned the pairing "off" on my phone to try from scratch again. Now the headpiece just blicks purple and I can't get it into pairing mode!
  • Gavi de Gavi Feb 18, 2009
    I am on my second 925 Discovery earpiece for this same reason. First one stopped pairing with my phone after about 4-5 weeks. Got replacement from plantronics, have used the replacement for about 2-3 weeks, and same thing- won't pair back up with same phone.
  • lunker1 Feb 27, 2009
    I used it for 1/2 day, turned it off and later back on; headset was not pairing so i tried to turn it off, heard descending tones, but now it only blinks purple when i push the button; no off, no on, nothing but purple and a short beep when i hold the button.
  • ohovers Apr 03, 2009
    Same problem here
SOURCE: I need to know how
set your phone to discovery mode. press and hold the button inside of the diamond until it flashes blue and red. once you do that, your phone should see it. Pair it to your phone by putting in code. 0000.
Happy Calling :)
Posted on Dec 23, 2008
randomgirl7
SOURCE: 925 Plantronics will not pair with cell phone.
To force start the pair press the + volume and the talk button in the middle simultaneously.
Finally found the solution after 20 minutes of searching, and I was about to tell my boss his bluetooth didnt work anymore
google <3
Posted on Jul 23, 2009
SOURCE: how to connect the LG Voyager - plantronics discovery 925?
From all my research in the past few days (1-11 March 2010) I have found out that bluetooth hands free via bluetooth is not possible with the Motorola Droid or the Eris Droid. The problem is with the Google android operating system not your bluetooth device. After calling Motorola and Verizon tech support, both say that "They are working on it." I really hope they update/fix their os because I really want to buy a couple of their phones. They said to wait until 31 March 2010. Hopefully they will get their act together.
Posted on Mar 11, 2010
SOURCE: plantronics discovery 925 will not stay on after a full charge
I'm having this same exact problem man!!
Posted on Mar 17, 2010
stilljolly
  • 8 Answers
SOURCE: plantronics discovery 925 ps3 pairing problem
When you turn it on do you go to the settings on the ps3 XMB and check to make sure it is connected, if it is connected when you test what it sounds like can you hear yourself? Sometimes your ps3 won't sync to the bluetooth automatically and you have to manually do it in the XMB, go to settings then accessory settings and then bluetooth. Hope this helps.
Posted on Jul 25, 2010
I have palntronic bluetooth but when i connet to other device like iphone it will never charge at all and the lights dont blink anymore when i plugg the thru my charger.
You need to use the charger that comes with the headset. It will not charge through any other device. Please follow carefully the instructions on this link for the Plantronics Discovery 925 User's Guide.
Good luck from Headsets Direct!
Sep 05, 2011 | Plantronics Discovery 925 Bluetooth...
Problems with dicovery 925 keep blinking purple light and can't pair with the phone help
Something you may want to try is start from the beginning. Check to make sure there are no other bluetooth devices loaded onto your phone that might interfere with the process. Turn off your phone. Disconnecting the battery of your mobile for 30 seconds and reconnecting helps to reset the phone. The instructions for turning off the headset and re-pairing the two devices are located in the following link for the Plantronics Discovery 925 User's Guide.
Sep 03, 2011 | Plantronics Discovery 925 Bluetooth...
I have a pantech ease phone and I received a plantronics 925 bluetooth and having difficulties pairing it/ setting it up. please help
1. Tap Menu > Settings > Bluetooth > Search.
2. The available devices will display.3. Tap to select the desired device.4. Tap Pair to pair the device.5. Enter password > OK. (should be 0000)
Jun 28, 2011 | Plantronics Discovery 925 Bluetooth...
When I make a call using the bluetooth, I can hear who I am talking to through the bluetooth, but they can't hear me?????
Make sure both devices are fully charged. Turn off your phone and disconnect the battery for about 30 seconds (this helps to reset the phone). Make sure there are no other bluetooth devices interfering with the connection. Turn off your headset and carefully follow the pairing instructions on the link below for the Plantronics Discovery 925.
May 12, 2011 | Plantronics Discovery 925 Bluetooth...
Plantronics 925 Discovery won't connect with Droid 2
  • Turn on Bluetooth within your phone - Consult phone instruction booklet
  • Put phone into pairing mode - Consult phone instruction booklet
  • Put headset into pairing mode - With headset off, press and hold Call Control Button
    until the headset begins to flash red and blue.
  • Select "Add new device" on your phone.
  • Select the Plantronics headset when prompted. Enter "0000" as passcode.
  • Your 925 headset will now have a continuous blue light blinking.
  • Choose "Yes" if your phones asks if you want to bond to the 925 headset.
  • Your phone is now paired with the Plantronics 925 headset and ready for use.
  • Please leave me a good rating!
    Sep 04, 2010 | Plantronics Discovery 925 Bluetooth...
    Lg lotus does not locate plantronics 925. have been using motorola h700 with no issues. have turned off phone and 925 and retried several times. lotus does not see any other devices.
    Once you make your LG Lotus discoverable, then put the Plantronics Discovery 925 into pairing mode by holding the call control button until the headset flashes red and blue. Here is the link below for the Discovery 925 pairing instructions.
    Plantronics Discovery Pairing Instructions
    Apr 27, 2010 | Plantronics Explorer 330 Headset
    It will not turn on after a full charge
    Sounds like you have a bum unit.  Plantronics gives a 1 year warranty with every wireless product, I'd send it back.
    Have you made sure that you're turning it on correctly?  You push the call answer button and hold it down for about 3 - 5 seconds before it turns on, until the blue light turns on.  Make sure that you don't hold it longer than that or it will go into pairing mode.
    Apr 26, 2009 | Plantronics Discovery 925 Bluetooth...
    Cannot get my 925 to work on my computer as an audio unit for use with Skype. Cannot find a driver that will work on VISTA 32bit
    Have you placed the 925 into discovery mode?  It will be flashing red and blue rapidly if you did.  Here's how to do it: Turn the headset off by holding the main button down until a red light comes on Turn it back on by holding that same button and keep holding it after you see the blue light come on.  Eventually it will start flashing red and blue.  This is now in pairing mode.  Set your computer (if it is bluetooth enabled) to find all bluetooth devices.  It should be listed as Plantronics 9xx.  If you need a passcode it's 0000.
    Apr 20, 2009 | Plantronics Discovery 925 Bluetooth...
    Switching on discovery 925
    Switch the bluetooth function on your phone, search for devices and then pair with your headset once it finds it. Allow it to connect without confirmation and leave your bluetooth switched on on your phone. Everytime you turn on your headset it should connect automatically.
    Apr 10, 2009 | Plantronics Discovery 925 Bluetooth...
    Plantronics Discovery 925 Bluetooth Headset Logo
    965 people viewed this question
    Top Plantronics Radio Communications Experts
    LeAnna Mathews
    LeAnna Mathews
    Level 1 Expert
    shaun taylor
    Michael Vincent Cruz
    Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
