Question about Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3 EA 13610498
Parts for Speedy Green Spreader SG1 - Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3 EA 13610498
5 Suggested Answers
SOURCE: lost manual
I have a Scotts speedy green 3000. Got it $5 used. I just called Scotts, and they are sending me a manual. But, they told me how to calibrate it. First, you need to know if you have the same "version" as I do. Apparently they made the same model more than one way. I'm told I have a newer one. The way the Scotts rep differentiated was by the wheels. I have all black wheels with orange hubcaps. Older models have orange wheels. If you have the model I have, then do this to calibrate the spreader:
1. On the black slide that comes up when the handle is pulled to open the spreader and releasing product you will find a curved line about 1/2 and inch from the top.
2. Set the spreader to a setting of 2 on the handle.
3. When you pull the lever as if you were releasing product, the indented black line should line up with the curved part of the green hopper at the top of the opening.
4. If it does not align, then you need to adjust the cable that run from the handle down to the hopper door. This is done using pliers of wrench by turning the square nut at the bottom of the cable. It's trial and error at this point.
Mine was off by 30%.
Good luck
Posted on Aug 02, 2010
  • 4 Answers
SOURCE: I have Speed Green 1000
Email their website at consumer.services@scotts.com for free delivered replacement parts. Take a photo and post it with a request for parts...Don
Posted on Oct 05, 2010
vincob
  • 718 Answers
SOURCE: I have a speedy green
It's all is dependent on your square footage i can't believe it's not on your bag but maybe try Scotts website. or call your local home center.
Posted on Apr 03, 2011
  • 65 Answers
SOURCE: I have a Scotts speedy
Hey, please give Scotts a call at 877-465-5160, and we can see if we have a spreader setting for you.
Hilary @Scotts
Posted on Sep 17, 2011
I have a speedy green 1000 and the drop chute will not close is there a repair kit for this machine?
Phil, Check the attached links,instruction and guides contact Scotts if you have to. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Help Center Contact Lawn and Grass Experts Scotts
Scotts Speedygreen 1000 law spreader spring repair
Replacing Rusted Axle on Scotts Speedy Green Spreader
scotts speedy green 1000 parts diagram Google Search
Apr 15, 2015 | Scotts Company Scotts& Accugreeen 2000...
Need a setting for Scott's Speedy Green EdgeGuard mini
First, I went to the products website, in this case Lesco and looked up the spreader settings:
https://www.johndeerelandscapes.com/home/spreader-settings.aspx
Then, I went to Scotts website and looked up spreader settings:
http://www.scotts.com/smg/node2/SCOTTSCOM/lawn-care/lookup-spreader-settings/7800015-24900013-s
I cross referenced a product on the Scotts website that uses the same settings as one of those listed on the Lesco website and I found my settings that way.
In my case I was using Lesco Pre-M 0.86% 0-0-7 and wanted to apply 5.3 lbs/1000ft. My spreader was a Scotts Turf Builder EdgeGuard Mini with settings from 0-15. I found out by cross referencing that the Scotts Speedy Green 1000 and my spreader used the same settings. So I ended up using the recommended setting of 5.5, as listed on the Lesco website for the Scotts Speedy Green 1000, to apply 5.3 lbs/1000ft of pre emergent using my Scotts EdgeGuard Mini.
Hope this helps!
Mar 30, 2013 | Scotts Company Garden
I HAVE A 10 YEAR OLD SPEEDY GREEN SPREADER. THE BALCK SPINNING WHEEL NO LONGER SPINS. WHAT DO I DO TO FIX?
I am sorry for the problem you are experiencing with your SpeedyGreen spreader. Sometimes we have replacement parts available. Please call Scotts at 800-543-8873 to check part availability. Hilary @Scotts.
Jul 02, 2011 | Scotts Company Garden
Where do I get a part for scotts speedy green spreader? A plastic part broke which controls the fertilizer shut off spout.
Scotts does have some replacement parts available, depending on the SpeedyGreen model you have. Please give Scotts a call at 800-543-8873 and we'll be happy to assist you with replacement parts. Hilary @ Scotts
May 19, 2011 | Scotts Accugreen 3950 Spreader Green 73730
Need Part #14455 for a Scotts Speedy Green Model SG-1A Rotary Spreader
That is not going to be easy. Most equipment that is under $100 is considered disposable and replacement parts are not easy to find.
The best option is to track another spreader down on www.Craigslist.org. Pull off the parts you need (or use the replacement spreader as purchased if it is better than the one you own.
Good luck and sorry I don't have a parts source for you.
-Mark
May 14, 2011 | Scotts Company Garden
I have a scotts standard spreader what setting should i set for using xl 2g specialty herbicide
If the product you are planning on applying has a spreader setting for a Scotts Speedy Green, or specifically for the Speedy Green 2000; you can use that recommendation in your Scotts Standard Spreader. If they do not have a suggested spreader setting for the SpeedyGreen, or SpeedyGreen 2000 settings then this question would best be answered by calling Scotts directly @ 1-800-543-8873. One of our associates would be happy to assist you further.
Feb 19, 2011 | Garden
Speedy Green Parts
Replacement parts for your model can be found at amazon, click here and take a look: Amazon com scotts lawn parts. I hope this was helpful. Cheers
Mar 18, 2010 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Need spreader settings for Scotts Speedy Green 3000
I found this:
For 18-24-12 %50 PPSCU
Product Application Rate:
*LBS PER 1000 SQFT 4
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
LESCO Rotary (80# & 100#) 15
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's Accu Green 7.25
Scott's Easy Green 26.25
Scott's R7- X F.5
Scott's R8-A J.5
Scott's Speedy Green 1000 6
Scott's Speedy Green 2000 7
Scott's Speedy Green 3000 6
Spyker 4.5
True Temper 1500 \ 5000 5.5
Vicon 28
Jul 21, 2009 | Scotts Company Garden
Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3 EA 13610498 Logo
368 people viewed this question
Top Scotts Lawn Garden Experts
Dennis Key
Dennis Key
john h
Are you a Scotts Lawn Garden Expert? Answer questions, earn points and help others
