Question about Ammco Combination Disc/Drum Brake Lathe
How to chage brake shoes on ford focus 2000 - Ammco Combination Disc/Drum Brake Lathe
    New Friend:
    Problem Solver:
  • 7 Answers
A simple you tube search should provide plenty of information. But as a ford focus owner my self I highly suggest becoming failure with a website known as fordfanatics- Google them . Their is tons of useful information from other owners and specialist on this sit including diagrams, videos, and much more. Also for the job wear gloves. Nothing will slow you down more than smashing your finger that one good time.
Posted on Nov 05, 2013
Brakes squeal even when I'm not push the pedal.
It could be something caught in the brake pads or rear shoes. It could be a broken rear drum component if you have rear drum brakes.
Nov 05, 2012 | 2000 Ford Focus
2000 ford focus rear brakes
with a small flat head screw driver at the back of brakes there should be a adjusment nut turn one and half turns and it should bring in the shoes if the drum to loose turn it the other way the drum shold just slide on when the drum is on try spinning the drum if spins freely adjust untill you feel binding and just slacking off a bit
Jun 22, 2009 | 2000 Ford Focus
Parking brake not funtioining
Need more info on chassis.
Which e-brake system, Trans brake?
Trans brake should always have some tension on cable. If no tension there could be internal problems (shoes worn).
If rear e-brake it function same as light truck setup.
Jun 19, 2009 | 2000 Ford Focus
Replace rear brakes adjust handbrake
The hand brake hardly ever needs ajusting. See your hand brake mechanincly spreads your rear brake shose inside the drum. Therefore just replace your rear shoes and make sure there ajusted right and you should have no more problems with that part of your car. PS make sure you put some 3M paste on the contact points on your backing plate to avoid a squeak in the near future.
May 16, 2009 | 2001 Ford Focus
Rear brakes 2000 ford focus zts
emergancy brake cable is froze holding the brake on
Mar 20, 2009 | 2000 Ford Focus
Diagram ford focus 2001 brake shoes
If this is for the rear here you go.
http://www.google.com/search?hl=en&client=firefox-a&rls=org.mozilla:en-US:official&hs=2rX&ei=CtiNSdOoLZmktQPLvaWDCQ&sa=X&oi=spell&resnum=0&ct=result&cd=1&q=Ford+Focus+rear+brake+diagram&spell=1
Feb 07, 2009 | 2002 Ford SVT Focus
How do i adjust the hand break system on focus 1999
hi there, you will need to slacken of the cable adjuster just next to the handbrake lever under its gaiter, jack up the vheicle and remove the rear wheels, remove the rear brake drums, clean and adjust the brake shoes also remove any dust from the drum, if the shoes are worn out they will need replacing, with the drums removed check everything is working freely by getting someone to operate the handbrake lever as you visually inspect the shoes you should see them moving backwards and forwards, if not then strip down and free off, i would advice doing one side at a time so you always have a point of referance to work from. check the wheel cylinder is free and not leaking, if so replace. adjust the brake shoes and refit the drums, once this is done readjust your hanbrake cable so it comes up 3-4 clicks, if this seems a little dawnting your local garage should be able to do you this job for a small fee, hope this helps
Oct 24, 2008 | 2000 Ford Focus
Open Questions:
See all Ammco Combination Disc/Drum Brake Lathe Questions
Ammco Combination Disc/Drum Brake Lathe Logo
61 people viewed this question
Top Ammco Tools & Hardware - Others Experts
ray gallant
Are you an Ammco Tool and Hardware - Other Expert? Answer questions, earn points and help others
