Question about Dometic RM2620 Refrigerator
Cant find access to thermostat om rm1303 dometic
  • dsicotte335
    dsicotte335 Oct 26, 2012
    Manual says to pull light when I do the only wires I find are power and ground to light
Can you replace Dometic 3107541.009 analog control unit with Dometic 3313192.000 digital control unit?
e-mail or call dometic support : (www.dometicusa.com) and make sure you give them the model # of your control box at ceiling assy and they will tell you if they will work together.
Jul 30, 2014 | Dometic 3107541.009 Analog Thermostat...
I have a dometic rm2820 up right fridge on bottom freezer on top. the freezer gets really cold but the fridge part stays warm.
Did you by chance recieve a recall from the manufacturer .? we got one about two years ago we had the same problem, they fixed it because there was danger of fire, i would contact them
Jan 19, 2012 | Dometic Refrigerators
I need to find a cycling thermostat for a Dometic Roof top unit
I ran across the same problem and found the kit to expensive. I gutted the parts added a transformer, contactor and thermostat. Unit worked great and cost about half the price.
Jan 04, 2010 | Dometic Rooftop RV Air Conditioner
Dometic RM 2800 Works great on AC but not on LP
Most likely cause is a blocked gas jet in the main burner its rare for the thermostat to be faulty but you cant dismiss it
Jul 27, 2009 | Dometic RM2652 Refrigerator
Dometic 57915.531 - high fan does not work
If it is a wall mounted thermostat, then you need to check the control box mounted on the inside of the unit. Remove the inner shroud to access. Check for power on the blue wire entering the control box from the thermostat, this is the high fan circuit. There should also be power on the orange(or tan) wire from the tstat. This is the fan circuit. Both these need to be hot with 12VDC for the fan to run on high. If you have power there, try removing the cover from the inside and access the squirrel cage (fan blade) inside the unit, turn the tstat to High fan and try starting the fan motor by hand. If it starts, then you have a bad fan capacitor. If not, check power to the fan on the top unit and all wiring leading to the fan. If you have power to the fan and it still does not run, you need a new fan motor.
Hope this helps,
Jeff
Jun 08, 2009 | Dometic 57915531 Air Conditioner
Dometic refrig,curcuit boards
thats normally a problem of either parts wear and tear or spiking in the the AC line ... if something like a water pump or something that turns on and then off suddenly is on the same line as the refridgerator it can cause such a problem also if the wires in the wall outlet or panel box have begun to run slack it can cause such problems as well ....
May 19, 2009 | Dometic NDR 1062 Refrigerator
Dometic RM2620 Refrigerator Logo
35 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
