Question about Samsung LN46D630 LCD TV
Samsung LN46D630 Wont turn on
I changed out the power supply board and it still wont turn on. It is only showing the red light on front of panel over the power button, but nothing else. So I know its getting power just wont turn on. If anyone could help I would greatly appreciate it.
    New Friend:
LN40C530F1FXZA LCD Plug-in:redlight in front is ON (stend-by mode).
Press on/off on remote to turn TV on:red-light comes OFFand ON 5 times
and stays OFF.Press again remote button:red-light comes ON and then OFF.I changed power supply board and it still doesn't come on.
Posted on Mar 02, 2013
  • 4 Answers
Http://www.tvrepairdoctor.com
Posted on Nov 24, 2012
SOURCE: my samsung tv wont turn on, red light keeps flashing on the front.
i had this with my samsung and my mums instead of pressing red power button press either switch from analog tv to digital button or just press a number
Posted on Sep 03, 2008
SOURCE: Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Posted on Oct 29, 2008
  • 257 Answers
SOURCE: wont turn on
The power supply board has been defected. Replace it with a new one.
Posted on Aug 18, 2009
toddthetvmd
  • 101 Answers
SOURCE: my samsung plasma tv went out and it just makes a
It was not your power board, Thought the same on several repairs.Found out it was the main board. The clicking was the tuner relay. I bet you own a SP-R4232. If so,The part you need is BN41-00574A. Also might be under BN94-00669A. Hard to find. Try Shop Jimmy/Or Encompass Parts. Not cheep tho. Hope this info helps.
Have a happy new year. Todd
Posted on Jan 01, 2010
  • 6 Answers
SOURCE: No Video on Samsung HPT5054
It's a pretty common problem. The no picture but sound problem is usually the y board. I've replaced 2 on mine now. The 680uf 35V capacitors usually are bulging because one of the power transistors went and took them out. This has happened to both of the y boards I had. One time the failing y board took out the buffer boards too, and once it did not. The fix is super simple and anyone with even the most rudimentary knowledge of computers or electronics can do the labor yourself. You should do the simple stuff first by just doing a quick test with a multimeter. Just check the power coming to the y board. After that you can just remove the y board by removing 3 cables and like 3 screws. Plug in the new board and it's done! You can source the parts from a place like shopjimmy or discount merchant. 3 boards were like 200 bucks. 1 board is like 100 bucks. Labor took me 15min. Think about that the next time an electronics repair place charges you 1000 dollars. Of course they check everything (Yeah right) and warranty their work (I don't) but if you check the service manual it states that this is the most common repair. Look for the Canadian manual online. Hope this helps!
Posted on Feb 23, 2010
Replaced power supply board but tv still wont turn on
Hi, You might also look at the capacitors on the main power board they are the first to go (Bad) Look for bulged caps and or leaking.
Replace them with same ratings. Good luck
Jan 30, 2016 | Sony KDL-70R550A 70" 3D LED TV 1920x1080,...
My LG 37LG50 TV wont turn on ?
Are you certain the replacement power supply is good? A defective main board or power supply can cause this problem.
May 04, 2013 | LG 37LG50 37 in. LCD HDTV
I have a 50" lg tv wont turn on red light will
The tv power supply board is dying.That the board,where the power a/c acord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 02, 2011 | LG 42LC2D 42 in. LCD HDTV
Wont turn on the red light shows its getting power but it wont turn on with the button or the remote
Samsung had some problems with capacitors in the power supply if you take the back off you will see that the tops of the bad caps have bubbled up.
Jan 12, 2011 | Samsung Televison & Video
T v wont turn on. red light continually blinks
Tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacemnt.
Dec 16, 2010 | Samsung LE40R74BDX 40 in. LCD Television
The tv wont turn on
Does it show a red LED on the front panel? If so, visually inspect your caps on the power supply for bulginess. Specially the 2200uf 10v ones. Replace the ones bulging out and you should be back on business. It is a known problem with some of the Samsung power supplies.
Nov 02, 2010 | Samsung LN32C450 32 in TV
32" samsung tv wont turn on standby light stays red but it wont change with remote or by preesing it
Tries unplug,replug the tv back like an hour later.The tv,now will reset itself back to the factory setting.The tv should work now.If not,this problems,usally the cause it by the power supply board not responing and giving the the right voltages to the tv anymore.Tries websites like Shopjimy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 22, 2010 | Samsung LN32A330 32 in. LCD TV
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Samsung LN46D630 LCD TV Logo
1,091 people viewed this question
Jerry Greenberg
Jerry Greenberg
