Question about Campbell Hausfeld 26 - Gallon Air Compressor
HOW TO CONNECT TO BLOW OUT WATER LINES - Campbell Hausfeld 26 - Gallon Air Compressor
I have an Atwood G6A-7 water heater on my trailer. When it lights only a yellow flame burns. I can not get a good blue flame. Adjusting the air shutter has no effect...
Use a air compressor to blow the lines clean. Open the line at the heater and blow air from the line at the pro-pain tank ( don't blow through the regulator undo the line coming out of the regulator.) and see if that works.
Jun 02, 2016 | Water Water Heaters
Hot Water Pressure from taps
Hard water deposits from the water heater in the supply lines to the faucets. Sounds like your water heater needs to be cleaned out -- not just drained of water. You need to get inside and clear out the deposits in the bottom of the tank. You also need to remove the hot water supply lines to your faucets and see of you can get the lines to run free from the deposits -AFTER you clean out the water heater. Remove the drain -put on a 3/4 in. ball valve for the drain and a hose bibb on that - you can hook up a 5/8 - or 3/4 inch hose to get the particles out of the drain of the water tank. You may have to blow back the water line, from the faucets, the hot water lines- to get the deposits out of the water lines. You also may have to blow out the faucets with the water line disconnected to clear the calcium out of the hot side of the faucet.
Feb 18, 2014 | Water Heaters
Price-Pfister shower clogged after work elsewhere on water lines
remove cartridge blow out water lines be careful
Feb 09, 2013 | Price Pfister Home
'98 GMC Sierra is leaking water inside the cab on the passenger side when I have the A.C. turned on. I can see where the water is coming from, but I can't get it to stop leaking.
There is a drain under the vehicle under where the ac lines go into the vehicle cab',look directly below the ac lines,it is hard to find but it is there ,use compressed air ,like a air compressor or air tank,with a blow gun and blow the drain out,if it unclogs the drain,it will pour out like a water fall,if this was at all helpful,please rate thank you.
Sep 15, 2010 | 1998 GMC Sierra
Location of AC drain hose on 05 toyota camry
Locate,under the hood,the ac lines going into the firewall,the drain is directly below those ac lines,it will be hard to find,but use a air tank with a blow gun,and blow the drain out,it will pour out like a water fall when it is unclogged.If this was at all helpful,please rate.
Jul 18, 2010 | 2000 Toyota Camry Solara
Got a new 3800 and was using it when it quit making pressure there was water coming out the blow byit just quit ,what the heck?
Were the lines connect to the valve connection box that a 2x4 or some other type of wood (dead blow hammer is best to use) and rap on it a few times. Generally the internal valve will stick causing this problem. If it does begin to work it will be needed to be taken apart and cleaned. Have Vaseline aroujnd to relube all items before re-assembly.
Jun 18, 2010 | Dewalt 3800 PSI Pressure Washer
Cannot found drip pan, about once a day I see a pool on water on floor on freezer side
take out bottom basket,if it's frozen in melt it out with hair dryer,usually when this happens the drain is blocked and water will be outside of freezer door you have to melt out drain then blow out the drain line i use a steamer,you can try pouring hot water down drain line but alot of times slime forms in there and it has to be blown out with steamer or getting some kind of hose like the water lines used on the refridgerator wter lines and blow through it to unblock it,check it by pouring water down drain to see if it's clear
Nov 08, 2009 | Hotpoint HSS25GDMWW Side by Side...
Hhot water comes in very slow and warm water is cold
Sometimes your supply lines screens (water lines in the back) more the hot than cold, get plugged up with minerials from the water. Most supply lines have a screen in them or on the washer itself where the supply lines connect or both ends. Care has to be taken but shut off your water and remove your lines and check for any clogged screens.
Oct 20, 2009 | Washing Machines
There is oil in the air lines of our compressor how to remove the oil from the lines
I would recommend soap (Dawn) and water. Then blow the air line out to dry them. I would not recommend a flamable solvent. You can make a water eductor using a tee and a small plastic tube and some fittings from the local hardware. you attach it at the compressor outlet and put the tube into a bucket of soap water. As you blow air through you hose you will **** up soap water and send it down the hose and out with the air. That should do it.
Apr 24, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Water Dispenser of Side by Side ADMIRAL Refrigerator Not working
check water flow were water connect may be is your water valve if you have water filter change it
Apr 04, 2009 | Admiral 26 cu. ft. Side-By-Side...
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
