Question about Nikon N55 35mm Film Camera
My nikon n55 is flashing err after installing new film
After changing to new roll of film , and installing new batteries its still flashing err and willdo nothing else, please help, thanks!
    Champion:
  • 216 Answers
It could be that your camera doesn't know it's rewound the film already. With the camera turned on, push and hold BOTH manual rewind buttons simultaneously - one near the release button ( +/- ) and the other toward the front of the camera at the lens release button. Try the release button again.
Posted on Jan 03, 2009
  • 667 Answers
Make sure your lens is set on the highest number, i.e. minimum f-stop, usually in orange
Nikon N55 Won't take picture in Auto Focus Mode?
There was a recall on the N55 due to auto focus problems. You can do a google search or nikon.com email the support team and they will send you the paper. This is what I did, I wasn't charged since I had the correct papers. I, however, used one roll of film and my focus went out again! Mine doesn't even work on manual... If you want to try that maybe you will hae better luck than me. GOOD LUCK!
Apr 28, 2008 | Nikon N55 35mm SLR Camera
N55 Shutter Problem
If the shutter blades get bent they are hard to straighten out. Better to find a local repairman or you could do more damage to the shutter. Sorry to be the bearer of bad news.
Jun 11, 2017 | Nikon N55 35mm Film Camera
Nikon n55 film camera
You must have your lens set to the minimum aperture setting for this camera to function. I.E. f22,f32. The aperture ring moves a small tab on the outside of the mount ring when in that position.
Jan 13, 2008 | Nikon N55 35mm SLR Camera
FILM REVERSAL
does anybody know a freakin solution????
Jan 09, 2008 | Nikon N55 35mm SLR Camera
My camera won't do anything but flash the Err message
Make sure the lens you are using on the camera is set to the minimum aperture setting. i.e. f22,f32 (highest f stop number)
Dec 28, 2007 | Nikon N55 35mm SLR Camera
Fee to error
Remove the batteries for 5 or 10 minutes. Remove the lens from the body and replace it. Make sure the lens is on f22 before you put the batteries back in and turn on the camera. If this doesn't solve it, try rewinding the film you have in the camera and try a new roll. The other thing to check if none of the above works is to remove the lens and check the small tab just on the outside of the mount ring at about 7:00. The tab is spring loaded and you should be able to push it with your finger and it will snap back. If it doesn't, the tab plate will need repaired or replaced
Dec 25, 2007 | Nikon N55 35mm SLR Camera
Flashing Err and E/Error Problem
You might want to check the position of the aperture ring on the lens. If it is not set at the highest number, ( IE smallest aperture, f22,f32 ), then the camera will display that error message
Dec 17, 2007 | Nikon N55 35mm SLR Camera
Bad picture developing
Since this happened on two seperate rolls of film, the problem may be that the shutter blades have been bent out of place.  This can cause the symptoms you describe.  Have a qualified technician look at the shutter.  Usually the blades can be reset.  In bad cases the blades may be bent or creased. If this is the case, the shutter may need to be replaced.
Oct 23, 2007 | Nikon N55 35mm SLR Camera
Camera Rewinds New Roll of Film
Check the camera and the manual to see if there is a control to override the auto rewind; it may be set to rewind. Other than that, check Mikon's website for support info.
Jun 16, 2007 | Nikon N55 35mm SLR Camera
Nikon N55 35mm Film Camera Logo
355 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
