Question about Grilling
UniFlame grill not burning correctly. What do I need to replace?
  • Grilling Master
  • 7,482 Answers
Hi este3banjpere
Check your gas regulator, it could be faulty
Gas regulators are notorious for doing just what yours is doing.
After sitting in the same position for a length of time they freeze in that position, then along comes a grain of sand, or other debris and blocks the gas flow.
Remove the regulator if possible, if not try it in place with the tank removed.
Get a plastic headed hammer and gently but firmly tap on the regulator, your trying to free up the diaghram inside.
After tapping and freeing the regulator diaphram reinstall and you will be good to go.
If this does not work, the replace the regulator as it is defective.
Some regulators are ajustable, if you have one of those then try to adjust the regulator, you will see a cap on top of the regulator, that is where the adjustment screw is located.
Please take time to rate me
Bud
Posted on Oct 30, 2012
4 Suggested Answers
  • 4736 Answers
SOURCE: I am looking for replacement burners (4) for a
You don't see brass burners much any more, because of the iron content. However, stainless steel replacement burners are available for your model. Check them out at the link below.
http://www.clagrills.com/grillparts/uniflame/uniflame-grill-parts-home.htm
I hope this helps you and Happy Grilling!!
Posted on Jul 19, 2011
cadesertmax
  • 274 Answers
SOURCE: On my Ducaine 30400040 grill the middle igniter is
You can go to Weber.com and there you can find your model and they have exploded views to help you find the correct part.
Posted on Jul 13, 2010
  • 57 Answers
SOURCE: Center part of burner on Uniflame Gas Grill is
yes you can each burner has a air vent close that air vent a little bit or till it has a blue flame
Posted on Aug 23, 2009
I need a manual for this product.
Helloo there,
Well here are a few
http://outdoorcooking.manualsonline.com/manuals/mfg/uniflame/uniflame_gas_grill_product_list.html
You REALLY need to get the exact model number and search online for it or try here for a start to your quest
http://www.grill-parts.com/uniflame/models/uniflame-grills-main.htm
Sep 16, 2014 | Uniflame Grilling
I need a heat plate for my Grand Gourmet Gas Grill #HBT250 and can't find it. The suggested www.grillstuff.com doesn't list Grand Gourmet which was purchased at Meijer in 2006
Grand Gourmet grills usually take UniFlame replacement parts. You shouldn't have much trouble if you look around at UniFlame parts. good luck!
Jul 06, 2012 | Barbeques Galore Grilling
I am looking for replacement burners (4) for a uniflame grill model gbc772w-c. The original ones were brass.
Jul 19, 2011 | Grilling
NEW Uniflame LP Model GBC1134W Gas Grill won't go over 300o in an hour? What is wrong?
The problem may lie with the grill's regulator and the way the tank was turned ON.
To solve this problem, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 14, 2011 | Uniflame FG2204C Grill
Bbq burner flame too high
If you got water down inside the burner(s), this condition should eventually clear up.
Dec 29, 2009 | Grilling
Cannot adjust flame
This could be a regulator or manifold issue. If the unit has a side burner check to see if it is burning at a correct flame height. If it is then the regulator is not the problem there is an issue with the manifold. For further assistance please get the model number and call Uniflame at 1-800-732-1142 we are here 7 days a week to help.
Jun 19, 2008 | Uniflame Grilling
Need new burners
Unfortunately this grill and parts are no longer being made. Uniflame has completely sold out of all spare parts. This grill was discontinued over 5 years ago.
May 25, 2008 | Uniflame FG2204C Grill
Have a unaflame grill 3 burner and need new burner,can't find replacement in store. Help
Please call Uniflame @ 1-800-762-1142 All parts are available for replacement.
Apr 12, 2008 | Uniflame NPE1605
Grilling Logo
313 people viewed this question
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
