Question about Dell Dimension 3000 PC Desktop
Getting virtual memory low & needing to get to the control panel
After removing & replacing the jumper on th mothers board, i power on & all my icons on my desktop do not display and all i get is an hourglass
  • Howard Lester May 11, 2010
    What was the jumper you removed?
  • 67 Answers
If you think that you cant able to fix your problem yourself and need remote support by experts at cheap rates so contact us—
Posted on Jan 07, 2009
    Problem Solver:
  • 11 Answers
frankmartin90@gmail.com
Note:
1) Its a remote support so, the experts come in to your computer and fix your problem.
2) We solve only computer problems by remote support.
3) The other problem is not remotely supported but answered by experts so; feel free to ask any question on any problem.
4) Did not need to pay in advance pay when you get solution.
  SO WHY YOU ARE WAITING ASK YOUR QUESTION TODAY
Posted on Jan 03, 2009
I removed my HDD from my PC and put it into another old pc. Then I replaced it again in the original. Now the mouse won't work
in this case,when you put your hdd in dell optiplex you must reinstall your windows,because the dell optiplex is a build up computer.
if you want more clearly detail you can contact me to my email
Dec 27, 2013 | Computers & Internet
I cant find where do i connect power switch there no slot indecated on the board help me pls.
Hello Friends,
If you are ask mother board power option. There are two power option every mother board, one option is SMPS power and sec option is Power Jumper. SMPS two power socket indicate 24 Pin and 4 pin also same option 24 pin and 4 pin socket available in mother board. Second option is 9 pin jumper socket hear connect to HDD power, reset power, cabinet power, power LED, and +5v DC. So you open PC and see all section and solved you problem.
Thanks.
Aug 22, 2013 | Gateway Computers & Internet
Failed to unlock HDD System Locked
What you need to do is unplug pc, open up the door panel to your pc and remomo cell battery from mother board then find the jump pins on the mother board they look just like the one in back of the hard drive. The jump pins are connected with a jumper similar to the pins jumper that sets up your hard drive to master, cable select, or slave. You need to reset the mother board the way you do that is by removing that pin jumper and replacing the cell baterry then the pin jumper. If done correctly you will reset your motherboard password setting and bios allowing you to boot your operating system. If you need help google your pc manufacture and model number and search mother board jump pins. Or email me with your pc info to andreioneluv@yahoo.com , and I will try to help you find it. Please rate if this was helpful...
Jun 08, 2010 | Seagate (9W2892-337) 80 GB Hard Drive
My pc monitor is blackout and no beeps whaen i start up even my hdd is not spinningmy cpu fan is working what is the problem tell me what can i do pls , As done by me----- 1. Clean the RAM memory and try...
If do not hear any beep then it means that the mother board is dead you can try clear the BIOS by removing the battery of the mother board for 5 mins or by shorting the jumper for clearing the BIOS if that didn't help then you have to repair the board or replace it.
Feb 09, 2010 | Asrock P4I45GV R5 Motherboard
I have a problem of motherboard Motherboard has power but cant come display. My friend suggest me in the motherboard jumper move it but i cant know which jumper to remove?
Jumper is a on cornor side of motherboard and is used to reset bios.....
trying to move jumper may not solve your problem .....
if u hear a tone continuesly then it will be ur ram problem..check your ram and try to fit it properly.
if there is no tone then it will be your display adapter problem..check your monitor cable..whether is properly connected with your cpu...if u have discrete graphic solution i.e. u have a graphic card on motherboard then check it if properly fitted..
if this will solve ur problem then ok..
otherwise u have to replace ur mother board..
Sep 12, 2009 | Computers & Internet
I just asked about removein the startup password wat do mean with the jumper i am new with computers so could u explain a lil more
3ac542afbc4ff40fe47b72448dec8cca.png they look like this and can be any color... Most motherboards can have the BIOS password reset by moving the jumper to the correct pin position. Many motherboards have small print by the jumper to indicate the correct positions. For example you might see some pins on the mother board, with a jumper like the one above, with the words PSWD RST or something similar wrote on the mother board. If the jumper is on pins 1 and 2 move it over to pins 2 and 3, then reboot your computer. Then shut down the computer down and put the jumper back where it was and it should have reset the pass word.
I would advise you to compare my instructions to that of *********** boards manual which you can download form the mother boards manufacturers website.
Sep 11, 2009 | Compaq (283983-001) Motherboard
When power on th green light on for a few sacond and off. The monitor is on but there is no signel from the cpu.So I couldnt work on computer.
Try clearing CMOS . remove Ram and reinsert. then check. if not working try these rams in other pc.or display of Mother board is gone.
Aug 08, 2009 | Computers & Internet
Turn off power and reinstall the jumper in normal mode position
Try to clean the pins on the board, check the connection inside th jumper. (with multimeter or else). Try to clear the bios .
Feb 27, 2009 | Intel D945GCL Motherboard
Regarding intel desktop mother board no 865
Remove all drives connection from Motherboard.
Check the PSU..(Power Supply)
If PSU ok, Then problem with RAM / Mobo
Clear CMOS memory by removing the jumper & then puttting it again=> Check MOBO's manual for this.
Try Replacing RAM ..
Best luck.
Jun 23, 2008 | Intel Motherboard
I can't access my BIOS in my toshiba computer
Assuming this is a desktop and when you say you can't access it because of a password, there is a solution.
-Unplug your computer
-Press the power button to release all power in the capacitors
-Open up the case
-Ground yourself by touching the metal case but not the board.
-Look towards the edge of the mother board, there is usually a button or a jumper (a set of two pins with a black piece of plastic across them)
-Press the button or remove the jumper
-Plug the computer in and start it
You should be able to access the BIOS now. Once you finish, replace the jumper if needed and you are clear. You might want to reset the password in the BIOS while you are in there though.
Apr 30, 2008 | Computers & Internet
Dell Dimension 3000 PC Desktop Logo
88 people viewed this question
Alun Cox
