Question about Teac AG-V3050 Receiver
Seems to only play in Mono
When listening to the FM tuner it will only play in Mono. If I use the mode button and put it in what I assume is stereo mode, there is no sound, well actually if I turn it ALL THE WAY UP, I can hear a faint trace of the music playing but that's it, if I put it back to mono it plays fine. AT the moment I only have 4 speakers connected. 2 in the front and 2 in the back, both on the A connectors. Why won't it play in stereo? Thanks for any help. Karen
Karen - Is it only the FM section that is giging you trouble? Does Stereo work for the other inputs - VCR/DVD/Turntable?
Is that stereo button ONLY for the FM section?
Posted on Jun 17, 2008
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
Marantz 2220b does not play in stereo in fm mode. i doxed all pots, & knobs, adjusted pot 304 but no dice. fm light is good, lites up on aux settings
Do you have an antenna attached to the receiver? If you don't, it might not be getting a powerful enough signal to pull in stereo. Also make sure that the mono button is not pressed or faulty.
Aug 26, 2013 | Marantz Vintage Model 2220b Stereophonic...
No stereo signal from FM? I have had this receiver for several years. I have tried several times to get a stereo FM signal. I have tried a "T" shaped antenna, an "S" shaped antenna...
Appears that your multiplex circuit in receiver is fubar. Also make sure that your receiver is set to the Stereo mode since the mono mode will also turn off the tuner stereo section.
Jun 17, 2017 | Pioneer VSX-D811S Receiver
With the Marantz SR 440/640 receiver, there is a Mono/Stereo push button. What position should the button be in to listen to a stereo broadcast? jefferj16@hotmail.com
I can't find the manual or a good picture of the front panel but I'll chime in anyway.
Are you sure the button applies to FM? It may be for overall stereo vs mono listening.
If it IS for FM choose Stereo. Mono if the station is so weak that it won't tune in stereo. Usually a receiver will have an Auto function that will do it automatically.
Dec 28, 2010 | Audio Players & Recorders
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
Auto muting on when on am/fm and no sounds come out. everything else is fine.
That's normal.
The Auto Muting mode mutes the audio output of the tuner if the station is not sufficciently strong to be accurately tuned. Otherwise you would hear all that interstation hash noise.
Press the FM Mode button to change it to Mono if you want to manually tune a hard-to-reach station. It will be in Mono.
Page 26:
AUTO MUTING
Normally select this.
When a program is broadcast in stereo, you will hear stereo sound; when in monaural, you will hear monaural sound.
This mode is also useful to suppress static noise between stations. The AUTO MUTING indicator lights up on the display.
Mar 31, 2010 | JVC RX-D205 7.1 Channels Receiver
When listening to the fm tuner on my yamaha htr 6060, will all 7 speakers still make sound? i' having trouble getting sound from the other speaker connections other than the L and R front connection.
analog fm is broadcast in stereo you would need to use a simulated surround setting to have sound come out of your rear and mid surround speakers.
your manual says the default setting for fm broadcast is:
Radio Listening TUNER MUSIC ENHANCER
7ch Enhancer
Select this SCENE template when you enjoy FM or AM
radio programs.
make sure you unit is not in straight mode try pushing the straight button on the front of the receiver let us know if more troubleshooting is needed.
Cheers!
Feb 15, 2010 | Yamaha HTR-6060
LXI tuner not working
Unfortunately without the make and model, there is little that we can do to assist you. There are too many tuner designs to be able to give you any useful information. Please try the unit in mono mode and with any "muting" turned off. If you receive stations with the muting and stereo modes turned off, the problem is with an I.F. amp stage. If you receive nothing, that is informative as well.
Please investigate a bit more and post the make and model and I should be able to assist.
Thanks,
Dan
Mar 13, 2009 | Audio Players & Recorders
Onkyo receiver playing in mono only
sounds like a reception problem. Is there a visual meter for the reception? Check your antenna.
Feb 02, 2007 | Onkyo TX-8210 Receiver
263 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
