Question about Aquabot Pool Rover Above Ground Robotic Pool Cleaner
Went to use pool rover jr, there was a sticky oily substance under it, it won't run. What do I need.
Appeared to be oil, a 1/2 cup or so under it, it is about 2yrs old, is there a seal that needs replacing or what?
    Top Expert:
  • Aquabot Master
  • 5,922 Answers
Bad motor
Posted on Oct 26, 2017
3 Suggested Answers
SOURCE: pool rover JR running slow
This has happened to me several times. Hair can get caught on the impeller. This causes the flap inside the jet to not close completely. Unplug the unit, remove two screws off the jet exhaust and gently remove the hair.
Posted on Aug 28, 2009
  • 623 Answers
SOURCE: How deep does the water have to be for the pool rover jr.?
If this is the type of cleaner that runs with a long hose connected and has one end stuck in the skimmer, the pool will need to be completely filled to normal level. The pool is filled with crud right? Use a long extension pole with a leaf net on the end to get out all the stuff you can. There is no way around the hard work. Don't be surprised if you need to use quite a few bags of powdered chlorine or jugs of liquid chlorine to clear the water up. Don't give up, it's gonna be hot this summer.
Posted on May 24, 2010
I have a 2005 ford territory and there seems to be oil in the water.I run it for about 1 min and a oily dark pinkish substance oozes out from the cap in the water resiviour?
That is transmission fluid . Transmission cooler line's go into radiator .Oil in water would have a white or brownish color .
Feb 22, 2017 | Ford Cars & Trucks
Looks similar to meely bug leaves a powdery substance and an oily sticky goo on leaves what could it be and how do I treat it
A general insecticide will probably drive it away. If you don't want to use poisons, try dish soap in a windex sprayer, diluted a lot. Bugs hate Ivory liquid, I think that's the one used to kill fleas in dog shampoo.
Nov 30, 2013 | Pool & Spa
An oily substance is leaking through my floor
ac has a oil charge sprinkler systems do not
Oct 16, 2017 | Cars & Trucks
Anti shift gear car wont come out of park
follow the steps . God bless you
Instructions
    • 1 Start the engine. Press firmly on the brake while wiggling the shifter from side to side.
    • 2 Remove the console surrounding the shifter. It is usually very easy although you may need to use the screwdriver to lift an edge or remove a clip
    • 3 Look inside the shifter mechanism for any sticky substance. Often when drinks are spilled on the console they seep down into the shifter mechanism and make the interlock solenoid sticky, meaning that it sticks closed when you press the brake and the car won't come out of park.
    • 4 Remove any sticky substance with the alcohol. Start the engine, press the brake and try to move the shifter out of park. If it still does not move then there may be another issue with the interlock.
    • 5 Examine the shifter for a release button that will allow you to move the vehicle out of park so it can be taken to a repair shop. It is usually hidden under a small flap or cover that will have to be lifted with a small screwdriver.
Oct 05, 2012 | 2005 Nissan Frontier
1995 saturn! new water pump, and coolant. Changed alternator, and battery, changed oil, oil filter. noticed oily substance in overflow container. did a radiator flush, still has red, rusty color somet
Coolant is oil based. The oily mess in the overflow could be very old coolant. Or it could be engine oil from a leaking head gasket.
The rusty stuff on the floor inside the car could be from a leaking heater core.
Jul 03, 2012 | Cars & Trucks
What is the oily substance leaking from beneath the right hand door of my kenmoore side by side refrigerator and what could be the source of this oily substance?
The compressor uses oil for its lubrication and part of the oil is entrained with the freon in the condenser/evaporator circuit. Could it be a leak in the system? If the system is still working properly, that is very puzzling. You may need to have it checked by a repairman who can help you locate and verify the source of the oil.
Dec 12, 2010 | Kenmore Refrigerators
May 23, 2010 | Aquabot Pool Rover Above Ground Robotic...
Pool rover JR running slow
Mar 13, 2009 | Aquabot Pool Rover Above Ground Robotic...
PAC L90 leaking oily substance
it leaked all the freon and oil out .
it needs to be vacuumed and oil replenished.
filled with freon.
should only cost you bout 50.give or take
as they use very little freon.
a shrader valve port has to be added to introduce the freon. takes just a few seconds.
May 23, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Aquabot Pool Rover Above Ground Robotic Pool Cleaner Logo
154 people viewed this question
Top Aquabot Pool & Spa Experts
Robco Water
Robco Water
The Cover Guy
The Cover Guy
David Spradling
David Spradling
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
