Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
My thin twin dryer goes on but does not spin
The dryer motor goes on and makes a winding sound.  It is working and has power, but it does not rotate.  We opened the back, but found there is no belt.  What can we do?
  • katie739 Jan 03, 2009
    Thanks so much, but really quick is it front panel or back panel access because we didn't see it in the back.  Thanks!
    Sergeant:
  • 311 Answers
Your dryer has a belt! if you hear the motor going thats good.you will have to investagate further.the belt goes around the drum thru an idler pully then on to the motor
Posted on Jan 03, 2009
  • Thomas Malailua
    Thomas Malailua Jan 03, 2009
    i think there is a way to put the belt on from the back if its all ready there[on the drum]you could not install new from back.try there its eazyer.if not youll have to go thru frount but can be a juglling act.also if i went on a call and the belt was off i would inspect to find why.somtimes happened and couldnt see any reason,but most times there was a reason.God bless ,tom
Whirlpool ite6234d thin twin could someone tell me in detail where the belt is located in the washer?
I can not find your model number that you posted.
I can tell you that all whirpool thin twins up to last year were direct drive with no belt except for the dryer section. Whirlpool stackers from the early eighties did have a washer belt if yours is this old replace the entire machine.
Jun 22, 2017 | Whirlpool LTE6234D Top Load Stacked...
My dryer will only run for 5-10 minutes
sounds like you have a bad motor,when it heats up it's stalling and when you go to restart it there are start windings and run windings in the motor it's not switching over to the run windings so when you hold the start switch in you're sending constant power to the motor,all it does is when you push the button it's a momentary switch power goes to the motor and hits the start winding in the motor should be just for a moment,then it switches over to the run winding and this keeps the motor running,your motor isn't doing this,
Dec 23, 2017 | Whirlpool Dryers
I have miele gas dryer t9820 is not rotating inside although it make a sound...
The problem is likely with the centrifugal switch on the dryer motor. This switch connects the start winding of the motor which provides additional torque at startup. Once the dryer is up to speed, the switch disconnects the start winding. If it malfunctions, the dryer will not turn and the motor will hum. By spinning the drum, you are providing enough torque for the start winding to be able to take over and bring the dryer up to speed.
You may be able to correct this by simply lubricating the centrifugal switch which may be sticking. I am not sure if the centrifugal switch is replacable, or if a new motor is necessary if lubricating does not solve your problem
Nov 28, 2010 | Miele Dryers
Whirlpool thin twin stacked,won't agitate or spin
whirlpool washers have a drive coupling in between the motor and the transmission to replace this remove the top and disconnect the lid switch set it aside remove the front panel then remove the 2 clips that hold the pump on then push it out of the way then remove the 2 screws that hold the motor clamps on and then remove the upper and lower motor clamps remove the motor then replace the three piece "motor coupling" one piece goes on the motor the other three pronged plastic piece goes on the transmission and the rubber isolator goes between them and now just put every thing back together
Mar 31, 2010 | Whirlpool LTE5243D Top Load Stacked...
Dryer not working
the button you push is a momentary start switch.whats suppose to happen is the power passes thru the push to start switch for a moment till the motor centrifugal switch goes to the run winding.what i have found happening is a lint buildup in the motor switch area dose not allow the motor centrifugal switch to reset to the start winding when the dryer has finished the last load.so its trying too start on the run winding and it could only do that if you helped by spinning the drum while hold the start switch.soooooo.... unplug unit .get to the motor and vacuum it out.inspect your wiring for burnt/loose connections.if all is well and vacuuming did not solve problem.your motor may have an open start winding which you could check with an ohm meter.if you need any more help you can make an request thru fixya email. God bless ,tom
Jan 22, 2009 | Hotpoint TDC32 Electric Dryer
Whirlpool thin twin problem
First be sure you're getting power to the motor this could cause both problems. If getting power then
sounds like you have 2 problems.
Dryer
On the heating problem be sure you have 220 volts at the power block, check the heating element , thermostats & high temp cutoff with an ohmmeter. Also check the centrifical switch on the motor it keeps the heat off for safety till the motor is up to speed so the fan is working.
Washer
Check lid switch some machines won't do anything but fill with the lid open . To check lid switch push the the switch down with a small screwdriver. If switch is ok check the coupler between the motor & transmission it can cause no agitate or spin. If all these are ok you may have a transmission problem. Last resort may be timer or wireing.
Nov 20, 2017 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
109 people viewed this question
Dan Webster
Dan Webster
Sal De
