Question about HP Expresscard TV Tuner For Windows Vista (RM436AA#ABA)
Quickplay on HP crashes
Every time I try to play my quickplay through my tuner express card - the program (quickplay) crashes. I'm running on Windows Vista. I have a new laptop - HP Pavilion Entertainment PC. My tuner express card is a HP external card - RM436AA. Quickplay seems to crash specifically when I'm searching for digital channels through my antenna.
Please help - Thanks! JoAnn
  • 1 more comment
  • Kelly LaFrenier Feb 02, 2009
    I'm having the same problem. I updated my quickplay from 3.2 to 3.7, and now when i scan for digital channels, the program stops working after 55% done. I've called HP and they told me that because my warranty has expired, I have to pay for tech support on this issue. My HP notebook is a DV9500 and was custom built for me from HP a little over a year ago. I got the quickplay 3.7 from an update that was suggested to me when I opened my quickplay. 3.2 was working fine, but, i wanted the newer one.
  • jhicok Feb 14, 2009
    ditto for me! Now I'm sad I uninstalled the previous version of quick play...at least that one worked!
  • janesatelier Mar 10, 2009
    Same here!
    I have a dv9650us and an external HP expresscard tv tuner. I've had this thing on the road from Seattle to San Diego many times inn the past year and it worked just fine - great actually.
    As of a week or so ago, I can no longer scan for channels, it gets to 41% and just sticks there - and then Quickplay freezes - I have to reboot to close Quickplay. So now it's just a useless piece of junk.
Quickplay not work in win7 64!
Hello esamili, I'm sorry to say that Quickplay doesn't seem to be compatible in the 64 bit version of win7. you can try running the program in compatibility mode.
  • Right Click on the HP Quickplay Icon.
  • Left Click on properties.
  • Left click on Compatibility Tab.
  • In The compatibility mode Section click on the check box stating "Run this program in compatibility mode for:"
  • Left click on drop list.
  • Left Click on Windows Vista (Service Pack 2).
  • Aug 14, 2011 | HP ProBook 4510s Notebook
    Tip
    HP Express Card Digital / Analog not working
    First thing I tried to do was to install the drivers that came into the CD didn't work, just using mydvd9 the import/aqcuire option I could have some noise signal, but couldn't find a way to select channels and hanged after a while. This is too trickier, I thought, it should be a way to used quickplay and other applications.
    I couldn't get anything from HP site so investigating I found the following.
    1) Had to upgrade quickplay to latest version (is pretty cool btw)
    2) The card internally is a Hauppage and found that is actually the HVR1500 http://www.hauppauge.com/site/products/data_hvr1500.html.
    Drivers + application can be downloaded at http://www.hauppauge.com/site/support/support_hvr1250.html
    3) After upgrading quickplay and installing drivers and application from hauppage, Quick play had additionally an hp digital tv tuner entry, but here in canada there is no digital signal transmitted through antenna.
    4) I have reinstalled manually the drivers that came in the CD, but from the c:\swsetup\HP Digital tv tuner folder
    5) After this I had at quickplay a second source "Hp Analog Tv tuner" which allowed me to caputure the regular air signal and wintv worked as well
    I'm sure that I did some redundant steps, but it worked and now can I have everything working (quickplay, wintv, digital, analog signals)
    Hope this helps and btw I haev uploaded the manuals for thouse who can't get it, since HP doesn't have them in the website.
    Cheers
    Alejandro
    on Feb 08, 2008 | HP Expresscard TV Tuner For Windows Vista...
    How to get back my web cam drivers for hp dv9000au windows 7.... i used quickplay till i had windows vista... but nw since i have installed windows 7... i cannot access my web camera.... so pls help me...
    Hi, Quick play would not work in Windows 7. When upgrading from Vista to Windows 7, some media programs are no longer compatible and will not be found in your Start menu. HP provides replacement programs for QuickPlay and other media programs with Windows 7 MediaSmart software. Plz go to below link and you will get all appropriate software?s of HP Mediasmart. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01929858&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN In this link you need to download the drivers used in HP mediasmart webcam and all other stuffs. If you find this helpful then Plz vote for me..Dreamkam
    May 23, 2010 | HP Pavilion dv9000z Notebook
    I can't play DVDs on my HP laptop even though I could in the past
    May I suggest that you try other programs to play your DVD's. Such as VLC media player. This program can play any meida file and is free. Also you could try gom player. Both of these are available off http://download.cnet.com/windows/ As to why your DVD's aren't playing. It may be bcause you have changed regions or because the DVD file is not recognized by the players because they don't have the ability to play certain fornats.
    Jun 19, 2009 | Intervideo WinDVD 5 for PC
    ATI RADEON x1650 PRO 512 Crash...
    Their is a reason that it crashes and it is not because of the game if  it crashes at other times too. Toom much HEAT is usually the problem. Look for slow or stopped fans. Dust on the heatsink.Run the antivirus. After that clean and defrag the hard drive. Let me knw that that did not take care of the problem.
    Jan 18, 2009 | ATI RADEON X1650 Pro, (512 MB) PCI...
    Can't run a quick play
    Quick play is a funny animal, first go to add and remove programs.
    Remove quickplay. Reboot unit.
    Next, google quickplay 3.7 and download the program.
    Next open the quickplay program and allow it to my a new folder.
    After quickplay has finished you will have a updated quickplay 3.7 or better and should run with no problems.
    Hope this has helped you.
    Jan 06, 2009 | HP Pavilion DV6700Z Notebook
    TV TUNER DRIVER
    One. did you call microsoft to help with that problem.
    two. http://www.hp.com/country/us/en/welcome_acc_supp.html#Support,
    three. Did you try reinstall vista ultimate again.
    four. or install the card in another slot.
    good luck....
    Nov 04, 2008 | HP Expresscard TV Tuner For Windows Vista...
    Hp express card digital/analog TV tuner
    u may try this....i once have the same problem,around nov 2007 this was after vista updated some driver(keytouch,audio),my tuner stop working,so i go to the hp webpage and i downloaded the drivers for my laptop,after i reinstall the drivers my tv tuner start working again,and it is still working,got 13 digital channels working +22 analog all broadcast,i configure the vista update not to autoupdate but to tellme updates are available,then install the available updates except the ones that are drivers,u may try with the original drivers that are on the Hp/drivers folder.YMMV.
    Nov 25, 2007 | HP Expresscard TV Tuner For Windows Vista...
    HP Expresscard TV Tuner For Windows Vista (RM436AA#ABA) Logo
    442 people viewed this question
    Top HP Televison & Video Experts
    Tony
    Computer Links
    vbalag
    Level 1 Expert
    Are you a HP Televison and Video Expert? Answer questions, earn points and help others
