Question about Coffee Makers & Espresso Machines
Cuisinart DCC-3000 leaks - Coffee Makers & Espresso Machines
  • Anonymous Oct 19, 2015
    I love these machines for the coffee they brew.I have had 2 of these machines. They can be a pain to clean, but if you are handy, they will give you many years of service. Coffee is always hot and the taste is wonderful. This is one of the best coffee makers around!
  • 19 Answers
SOURCE: Cuisinart Coffee Maker DCC 2200
The user manual is a free pdf download from the cuisinart web site.
Posted on Jan 19, 2008
SOURCE: Cuisinart DCC 2000C
We have the same intermittent problem with the on/off switch on our DCC 2000C......don't know if the switch is bad (we hear it click when turned on) or if the water pump is intermittent. Either way, the end result is no coffee and concern about a potential fire. Today, after reading a post by a DCC 1200 owner with the identical problem, I called 1-800-726-0190 and spoke with a young man who was most helpful. Although, we cannot locate our proof of purchase, we believe the serial number indicates manufacture within the warranty period. He said we will receive a replacement in 7-10 days and then we must return the malfunctioning unit in the same box along with a $10.00 check. We'll see how it goes and post again if it doesn't happen as I've described.
Posted on Oct 07, 2008
SOURCE: Cuisinart DCC-1200 BW Model leaks
Order 1 foot of 5236K73 "High-Temperature Silicone Rubber Tubing" from McMaster-Carr. Put the old check valve in the new tubing in the same location and direction as originally installed.
Posted on Feb 01, 2009
SOURCE: My cuisinart DCC-2000 leaks all over the counter
Be sure to not overfill the reservoir. Look at the back where the lid hinge is and you will see that the opening is lower then what the tank looks like it can be filled to. Had the same problem and stopped it by being a little more careful when I filled it.
Posted on Apr 21, 2009
  • 85 Answers
SOURCE: Cuisinart DCC-1150 series coffee pot how to clean reservoir
Hello dhubert14,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. This an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it, but most people don't know about this fix. I hope this is really helpful to you, dhubert14. Positive feedback is appreciated. Good luck. NormanZ
Posted on Jul 09, 2009
WHY DOES WATER LEAK OUT OF THE BOTTOM OF CUISINART COFFEE MAKER DCC-3000
Usually this is due to over-filling the machine with water or too many beans. Follow directions carefully, limit the total water to the highest mark on the the carafe and the beans to the mark in the grind basket.
Oct 06, 2016 | Cuisinart Coffee Makers & Espresso...
Coffee Maker is leaking
mine was not same make but the upper water tank was plastic and seems they fracture when getting hot too many times .Bunn would not provide a replacement tank so it was buy NEW
Jan 08, 2015 | Cuisinart DCC-3000 Coffee-on-Demand 12-Cup...
Cuisinart dcc 3000..set to self clean and nothing is happening? Both the cleaning light and power light are on. How long does the cleaning process take or is there something wrong with the coffee maker.
Press the "CLEAN" button and it will light up red. Then press the "ON/OFF" button which will light up blue. Be patient, nothing happens right away, but the cycle has begun. In a few minutes the water reservoir will begin to empty. This self-clean/decalcification process takes approximately 30 minutes. Then pour the water/white vinegar solution out of the coffee reservoir, rinse the water and coffee reservoirs and run one cycle of fresh cold water through before using to brew coffee.
Sep 17, 2013 | Conair DCC-3000 - Cuisinart Coffee on...
Leaks water from the bottom
Under warranty. Cuisinart will resolve. Thank you.
Dec 08, 2008 | Cuisinart DCC-2200 14-Cup Coffee Maker
My "Coffee on demand" maker leaks...i love the machine and this is my second and also the second one to leak
The parts to repair a problem of this magnitude are generally not available. The DCC-2000 has a thre-year warranty. I would call Cuisinart and see if you can get an in-warranty replacement. I have a high opinion of cuisinart and their products, but this particular coffeemaker, I do not personally reccomend.
-Tha Mp3 Doctorxcx
Jul 26, 2008 | Cuisinart DCC-2000
Cuisinart DCC-2000 leak
-Tha Mp3 Doctor
Jun 29, 2008 | Cuisinart DCC-2000
Dec 26, 2007 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
1,595 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
