Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
How to retime the distributor - 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Had to pull distributor while putting head gaskets on 1995 mercury sable 3.0 v6 now I don't know how to retime distributor
Get the number one cylinder to top dead center on the firing stroke. Insert the distributor so that the rotor is pointing to the #1 wire when it is in place. This should be enough to get it running again, if it will not start turn the distributor a bit one way or the other.....
Dec 03, 2016 | 1995 Mercury Sable
How do you retime a distributor on a 2005 Nissan Murano
Your vehicle doesn't have a distributor. Find another mechanic.
Oct 01, 2016 | Nissan Cars & Trucks
Intake gaskets repaced. ignition timing offset.would like some illustrations, if possible to fix this problem.
What problem? You replaced the intake gaskets and got the distributor on the wrong cam tooth? Now the check engine light is on for cam/crank correlation? So you need to know how to retime the distributor?
Feb 12, 2011 | 1998 Chevrolet Blazer
I have a 99 chevy suburban v8 vortec engine 5.7.... had to change the distributor when it broke, now I am having a hard time putting it back in timing. looking for the firing order of the spark plugs for...
You will have to find out where number one is. But the firing order is 1,8,4,3,6,5,7,2. That is the firing order. 1357 is on the driver side, 2468 is on the passenger side. Start with 1 and go clockwise on the distributor.
Oct 20, 2010 | Chevrolet Suburban Cars & Trucks
Retime distribluter on 98 chevy truck
You will need to put it into base timing mode, should be a tan and white wire on firewall near distributor, then with a timing light you can set the timing, after you have set cylinder 1 at top dead center
Apr 11, 2010 | 1999 Chevrolet Silverado 1500
Timming
yes in a way you need to get a book it will tell u what to do
Oct 18, 2008 | 1990 Nissan Maxima
Igniton timing
retime it be very very gental when timing distributor is very touchy
Aug 10, 2008 | 1995 Chevrolet S-10 CA Edition
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
41 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
