This started as a sporadic problem, now is a nightmare. All of the sudden, programs start to pop-up. Always the same (media player, system info, compaq support). If you're in a word processing program (even notepad), characters start to be written by themselves, repeatedly.
The work-around have been many, since it has gotten worse. The first one was just press all keys on the keyboard. Then tried an external USB keyboard which worked for some time, then the problem started again. I even physically disconnected the laptop's keyboard & mouse to use only the external usb keyboard/mouse combo. Still the problem shows-up.
Any help greatly appreciated
Same problem even on a freshly formatted and reinstalled system that had no access to the internet.Same problem even on a freshly formatted and reinstalled system that had no access to the internet.
I have the exact same problem. I even tested the keyboard on another Compaq laptop I have and the keyboard is fine. I really need to fix this problem. I have the exact same problem. I even tested the keyboard on another Compaq laptop I have and the keyboard is fine. I really need to fix this problem.
AnonymousMar 04, 2009
i have the same ******* problem..
You can't post conmments that contain an email address.
As a try try a restore point as far back as possible.
Chgeck out your anivirus protection and trojan protection
Any good A/V program and trojans try www.trojanhunter.com
If all that fails it seems like a chip failure.
but I suspect an infection of some kind.
HI, the lengths of the programs should be on the lid...if not somewhere in your manual. i have an old one & it takes forever. the starts & stops are normal (i think) cuz mine has always done it.
When you start it up, go to the BIOS option and select "peripheral" settings. I don't know which column its under but you want to turn the network adapter off. If that makes your Operating System come up working (And you may have to come up in SAFE mode the first time), then you can always go back and reset the BIOS to recognize the network adapter, or install a different one.
You can use the function keys to increase the brightness. Also if you go to Start, Control Panel, Power Options you can change the settings to give you more monitor time.
The problem was that ther keyboard was encrypted for my protection. this sometimes prevents the keyboard from connecting to the receiver and therefore the computer. to stop encrypton: press the left CRTL + left ALT + F12 key at the same time. Press the connect button on the receiver (you only have a few seconds to then press the connect button on the keyboard. Press the ESC key. Now you must start the encrypton again. Install SetPoint software from www.logitech.com/downloads. after you save and run the program, then press left CTRL + left ALT + F12 keys. sometimes there is an encrytpion wizard that pops up to help you further encrypt the keyboard, but this does not always pop up. It didn't on mine. My keyboard just started working right after i re-sarted the encryption.
same deal mine does the exact same problem...how do you fix this???? i tried the suggestion yet it still kept happening
