Question about Fiesta Blue Ember Gas Grill
How do you remove the venturi tubes? - Fiesta Blue Ember Gas Grill
2 Suggested Answers
  • 4736 Answers
SOURCE: How do you remove the
The venturi tubes are part of the burner. It"s a slot on both sides of the burner tube, where it goes over the burner orifice. You will need to remove the burners to check and clean them.
Hope this helped answer your question.
Posted on Apr 18, 2011
What is the use of Venturi?
A venturi is used in many skimmers to draw air into the water flow. As water is pumped through the venturi, air is drawn into the passing water through a small inlet tube. There are many version of venturi in the outlet tube because many brands use modified version of their own.
Aug 30, 2012 | A H Fabrications Fish
How do you open venturi tubes to clean?
If you remove the burners, the Venturi Tube is part of the open end of the burner that fits over the burner orifice. It should look like a slot on each side of the burner. There's really nothing to open, once the burner is removed.
Hope this helped you and Happy Grilling!!
May 30, 2011 | Fiesta Blue Ember Gas Grill
How do you remove the venturi tubes of a Blue Ember Gas Grill? The manual explains how to clean the venturi tubes, but it doesn't say how to remove the tubes for cleaning. The manual just says...
Apr 18, 2011 | Fiesta Blue Ember Gas Grill
I just bought this grill and it wont light. they say in the manual to make sure the venturi tube is over the orifice fitting. i removed the grill top and saw that it wasnt over the fitting. does that...
I'm having the same problem. There doesn't appear to be room to adjust the venturi tubes. I tried yanking on the ends to see they would extend but the tubes appear to be fixed in place.
Nov 19, 2010 | Coleman Roadtrip Grill LXE 9949-750
I am uncertain as to why my barbeque smokes black and leaves a soot film on the whole inside of the barbeque and on the meat that I am cooking. It is certainly a cheap model but I replaced the burner and...
Can you see the smoke coming from the tip of the flame itself? Did you not have this problem before you replaced the burners? If yes to both, then the problem is with the venturi tube of the burner not providing enough air. The venturi tube is the part of the tube where the gas jet from the valve first enters it. There are some holes that control the air/gas mix by their configuration and size. Perhaps you have the wrong model replacement burner. The orifice (very small hole) out of which the gas shoots into the venturi, and the venturi tube itself are both designed slightly differently for use with Propane (bottled) or Natural (piped) gas. Perhaps your new burner has an adjustable venturi to allow more air. If so, remove the rocks so that you can see the flame and adjust by trial and error.
Jun 10, 2010 | Garden
Mtd 22" yard machine staryts and dies using prospray.
Remove the float bowl again and remove the BRASS Jet in the bottom of the venturi throat. Clean the pin hole of the Jet so that you can see through it. DO NOT force anything through it. Just clean it. Underneath the jet is the venturi tube itself. It is also unscrewed with a screw driver. Remove it and clean all ofthe holes in it. Then reassemble tube and jet in to the venturi. Check the BOWL NUT for 2 holes. If the holes are clogged your engine will suffer from a lack of fuel. Lastly check that you have FUEL flow from the tank to the carb. If the tank outlet hole is clogged you will also have a lack of fuel problem.
Apr 09, 2010 | Mtd 22" Yard Machine Push Mower
Shut off while pressure washing
Hi and welcome to FixYa. I am Kelly
Most likely the JET orfice in the bottom of the carburator venturi throat is clogged. I am assuming you have a 5.5 Hp Honda motor but even if it is not the procedure is the same.
1. Turn off the fuel supply selector
2. Remove the float bowl by taking out the mounting hardawre. The nut / cap screw on the very bottom of the float bowl has holes in it. Make sure they are clean.
3. Remove the "Brass" JET from the bottom venturi tube and clean the orifice. You should see a pinhole of light through the hole when it is clean.
4. Remove the venturi tube just above the jet that is also brass. The throat of the venturi tube and the 2 side holes must be clear.
5. Use something like a spray paint can lid to catch fuel and then briefly turn on the fuel supply. The fuel should flow at a good rate though the float needle and seat assy. GENTLY lift the float to the raised positon (level) and confirm fuel stops. Then loet it lower again noting fuel flow. TURN OFF THE FUEL selector. If you do not get any fuel at this point check the bottom of the fuel tank for obstructions at the tank outlet hole. Once you have verified fuel flow.
6. Reinstall the venturi tube
7. Reinstall the jet
8. Reinstall the float bowl making sure upper and lower gaskets are in place.
9. Turn on the fuel and wait one minute (check for leaks)
10. Start the unit.....
(Complete)
Thanks for using FixYa.
Kelly
Mar 23, 2010 | Northstar Pressure Washer 3000 PSI
Low flames
The problem may be in your regulator. About five years ago the feds required all grill regulators to have safety features which now often cause the problem you are having.
Make sure your regulator is right side up for starters Then check the venturri tubes to be sure some spider hasnt nested in there. Make sure it is clear.
Here is some additioinal info u may need to read:
Fuel Hose and Regulator: The output of a propane tank is much greater than you need for grilling so the regulator controls the amount of fuel that can flow to your grill. The regulator attaches to the tank by a flexible hose with an O-ring to create an airtight seal. Regulators are preset by the manufacturer and should not be adjusted by you. If you look at your regulator you will notice a small vent hole in the center. Common problems here are clogged vent holes, which can cause irregular fuel flow and can lead to trouble. Usually you can clear it by tapping or blowing into the vent. Other problems are fuel leakage caused by a worn or damaged hose or O-ring. To determine if there is leaking mix dish soap and water in equal parts and coat everything from the tank to the venturi tubes. The tank needs to be connected and on but the control valves off. If you find a leak replace that part. Control Valves: The controls do just that, control the flow of fuel to the burner. Some grills have one control valve and others have several. The valve consists of several components that are specifically designed on a number of factors. You cannot repair a bad control valve and if need be you should replace the whole unit. Before you do, however remove the control valve from your grill and inspect it. Like other parts of your grill, insects love to climb in here and make their homes. At the heart of this is the orifice. The orifice controls the flow of fuel and can become clogged. If it is use a thin wire to clean out. Make sure you put it all back together the way you found it. Without the orifice you cannot control the amount of gas flowing to the burner and run the risk of explosion. Venturi Tubes: The venturi tubes connect the control valve to the burner(s) and mix the fuel with air to provide flame. To mix the air into the fuel there is an open gap in the fuel line here that can easily become obstructed. Insects, especially spiders, love this space and given half a chance will move in as quickly as possible. The best solution for this is to wrap the venturi tubes with an aluminum screen that will not block the airflow but will keep the critters out. Another common problem here is a misalignment of the venturi tubes with the burner. Typically the venturi tubes are simply placed in the fuel line and can get knocked out of place. The venturi tubes typically have adjustable shutters. You may need to adjust these to regulate fuel flow.
May 18, 2009 | Grilling
Venturi tubes
The venturi tubes should go over the gas orifice. If the tubes were to drop off, you could have a fire outside of your grill and possibly an explosion.
Jul 03, 2008 | Sunbeam SG6622RP Grill
Regulator Assembly / Venturi tube
YOU'LL NEED TO GET A WRENCH R PLIERS ONTO THE PART THAT IS TURNING SO YOU CAN TIGHTEN IT UP, DON'T FORGET TO USE SILICON TAPE ON THE THREADS OR IT WILL LEAK. THE HOLE IS TO ADD AIR TO THE MIX.
Apr 07, 2008 | George Foreman GP324SS (PG) Grill
Fiesta Blue Ember Gas Grill Logo
Top Fiesta Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Fiesta Grilling Expert? Answer questions, earn points and help others
