Question about Whirlpool Duet WFW9250WW 4.0 Cu. Ft. Front Load Washer
My washer wfw9250ww is flashing error code E1
During the rinse cycle the washer stopped and started to flash error code e1 and f1. It also has a smell to it like something is hot. What is wrong with it? It also wont unlock the door. i shut it off and put it on extra rinse and it wont do anything.
SOURCE: stopped during rinse/spin cycle
try removing the bottom front panel and see if there is something blocking the drain.
Posted on Nov 02, 2008
SOURCE: Washer stops with an F1 Code during rinse cycles.
Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
Posted on Dec 08, 2008
SOURCE: Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Posted on Jan 21, 2009
jsrock516
  • 5911 Answers
SOURCE: Error Codes"5ud" and "02" and "F"
The two error codes together indicate you have something restricting the drainage system. "F02"is a Long Drain error code, "SUDS" occurs when too much air is sensed in the drainage system. In most cases, the drain pump reservoir needs to be cleaned out. The following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you check the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, first and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage this small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Mar 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Cabrio Washer Error message code F1
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&%$#
Posted on Sep 21, 2010
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Sep 21, 2017 | Bosch Washing Machines
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
What is the error mean f1 E1 on my may tag front loader washing machine
Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
have E1 and F1 error code fleshing and wate Sears PartsDirect
http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
Appliance Repair Forums
Error code F1E1 null ShopYourWay
Central Control Unit CCU Maytag MHW6000XW Washer
Mar 07, 2016 | Washing Machines
Duet. What does F8E1 code indicate needs to be done to restore operation?
Check out the Link and the info below.
Question: Front Load Washer - Error Code - F8 E1 or LO FL Answer Product Symptom:
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. The washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Whirlpool recommends that appliances be direct connected to the water supply for optimum machine performance.
If a "flood saver" device is being considered:
  • Check with the manufacturer of the device to ensure it will not affect the performance of the appliance.
  • Whirlpool has experienced that "flood safety" devices can interfere with the performance of the appliance. Whirlpool typically does not recommend these devices.
Two types of "flood-saver" devices, hoses and valves are illustrated below. anti%20flood%20hose%202.jpeg floodsafe%203.jpeg Whirlpool Duet Washer F8 Code Appliance Repair Forum
Jan 19, 2016 | Whirlpool Washing Machines
F&P GWL11 Washer Stops at rinse - Error Code 37
I hate to say it but it sounds like the controller. I used to have one that had a similar problem that was fixed with a diverter and a controller. Another year or two later it was doing the same thing, so we just replaced it. Just a warning.
Jul 08, 2012 | Fisher and Paykel Washing Machines
Model number wfw9250ww error code e1 and f6
How to fix a error code of E2F3 on a whirlpool duet model # wfw9250ww00
May 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
The oven does not work it says turn off when i turn it on and flashes F1 and E1 codes
The E1-F1 error code means per the service manual "safety flip flop" what that means that a internal component of the control board has failed and thusly the control board would need to be replaced
GENE
Oct 25, 2011 | Ovens
Oven flashing F and E1 codes when i turn oven on it ays to turn oven off and flashes F1 nd E1 codes
If this is a Kitchenaid, Roper or Whirlpool range, this error indicates an EEPROM error in the control board. Ifthe F1 E1 trouble code continues after you've disconnected the power for over 30 seconds, you need to replace the electronic control board (clock). You can often find parts online with the model number of the unit. (Try partselect.com or searspartsdirect.com (if Sears sold the model).)
I hope this helps.
Oct 25, 2011 | Kitchen Ranges
F1 flashes on my maytag bravo washer
This is an inherent problem with this Whirlpool-made top load washer and at first it is believed to be a machine/motor control fault. But it was found later that it can be due issues associated with the pressure transducer/switch system. Air leaks and moisture in the pressure hose including lints or flashing in the air dome can lead to signal error being sent to the machine/motor control assembly and it is interpreted as a machine/motor control fault. You may also observe that the fault code F1 appears usually during water filling at the start of the wash cycle and/or at the start of the rinse cycles.
Check the pressure hose for air leaks and moisture including the air dome. Replace the machine/motor control assembly if no issue is found with the pressure hose and the air dome. Click on the link below for the troubleshooting and repair instruction details.
Troubleshooting Fault Code F1 on Whirlpool Cabrio, Kenmore Elite Oasis, and Maytag Bravos Top Load Washers
Jun 17, 2011 | Washing Machines
Whirlpool Duet washer, during the wash cycle, get H F error code
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Washing Machines
Whirlpool Duet WFW9250WW 4.0 Cu. Ft. Front Load Washer Logo
111 people viewed this question
Dan Webster
Dan Webster
Sal De
