Question about John Deere 24HP VTwin Hydrostatic 48" Riding Mower
John Deere LA165 won't charge. Changed the voltage regulator, alternator, battery and still won't charge.
Tried a voltage regulator and battery from a known good mower and still won't charge. Put on a new Briggs and Stratton alternator and still have the problem.
SOURCE: I have a john deere L120 riding mower with about
have a john deere zero turn that will not turn all the way over
Posted on Aug 16, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
  • 146 Answers
SOURCE: my john deere rideing mower idles up and down at
The motor has a governor that controls its speed, and if one of the pivoting parts or linkages is sticking this would happen. Look for the throttle linkage on the engine carburetor (move your throttle up and down, watch what moves). The governor will be a second linkage attached to the throttle arm. Squirt some WD-40 on any rotating parts and make sure a foreign object isn't stuck in there. It could also be the part of the governor that's internal to the engine -- harder to get at, but not expensive to fix.
Posted on Jul 04, 2010
  • 10 Answers
SOURCE: Have John Deere 165 riding mower. Strong crank,
Has it been outside? May be water in the fuel.
Posted on Jul 25, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
New battery on F525 John Deere mower won't stay charged-battery connections are good-is voltage regulator bad?
Either the alternator is not charging properly or the diodes in it are defective and discharging the battery when the ignition is off.
Sep 06, 2017 | John Deere Garden
John Deere 4100 compact tractor will not keep a charge. Has a magnet alternator,new battery ,and new voltage regulator. If you external charge battery, will start & run till useup charge. Then tractor...
If you hold a wrench against the back of most alternators when it's running the wrench should be attracted to the alternator which would indicate that its charging. If it isnt' charging then the regulator inside the alternator is burnt (typically) if it is charging then check the wires to & from the alternator.
Nov 24, 2017 | Cell Phones
Battery good, alternator good, starter good but my 1966 oldsmobile the alternator isn't charging the battery
Have you replaced the voltage regulator?
Unless you have changed the charging system and eliminated it, the alternator does not have a built-in voltage regulator like the newer ones do.
Be blessed.
Feb 06, 2013 | Cars & Trucks
My 316 john deere alternator is not charging the bat. Where can I get a electrical dia. to trouble shoot. Bob
there are three wires at the regulator two from the alternator and one that goes to the battery see if there is voltage at the two from the alternator if so the regulator is bad
Sep 11, 2012 | John Deere 300 / 316 Hydrostatic Tractors...
My daughter 2004 Kia won't hold a battery charge.
voltage regulator. it may be in the alternator, or remote mounted. ((the alternator can be charging, but if voltage regulator is'nt working then it won't allow voltage to get back to the battery to keep it charged
Sep 07, 2012 | Cars & Trucks
I've changed the alternater,starter, voltages
Troubleshoot first and then change parts! What was the original problem? It just won't crank over? The alternator just charges the battery the voltage regulator keeps from putting too much of a charge into the battery. Was the battery going dead? Did the vehicle start when jumping it with jumper cables? Too many unanswered questions to offer help, sorry.
Feb 26, 2012 | 2007 Ford Van E-350
Changed alternator,battery and still won't keep battery charged
CHECK ALTERNATOR 175 AMP MEGA FUSE. AND CHECK ALTERNATOR 20 AMP INLINE FUSE.IF FUSES OKAY.REPLACE BATTERY CABLES AND CHECK ALTERNATOR BATTERY FEED WIRE AND VOLTAGE REGULATOR WIRES FOR DAMAGE.AND CHECK DRIVE TENSION.MAKE SURE DRIVE BELT NOT DAMAGE OR SLIPPING.
May 30, 2011 | 2003 Ford Expedition
2001 john deere 445 will not charge any common problems? How do you test the voltage regulator?
Voltage regulators will keep the voltage at around 13.5 to 14 volts with the vehicle running. This is what keeps your battery charged while driving the vehicle. If is lower than battery voltage (usually around 12.3 to 12.8) then it is probably bad.
Jul 16, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 185 Hydro won't stay charged
I had the same problem on my lx176. Check all your connections first. If they are all ok and fuse and fuse link are ok, unplug your magneto connector. Mine is a 2 prong plug by the dipstick tube. Connect a voltmeter to the engine side of the magneto and set it to AC VOLTAGE SETTING.. With the engine running I think I remember it should be putting out about 30 volts AC. If you have close to this voltage there it is probably your voltage regulator. Mine was. Hope this helps
Apr 24, 2009 | Garden
John Deere 24HP VTwin Hydrostatic 48" Riding Mower Logo
249 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
