Question about Xerox Phaser 3250D Laser - Monochrome Laser - 30 ppm Mono - 1200 dpi - USB - PC, Mac Printer
Xerox Phaser 3250 turns off Computer when printing
This printer makes computer reboot when trying to print. Tryed it on 2 different computers and same problem.
5 Suggested Answers
  • 2072 Answers
SOURCE: Xerox 4150 Multifunction Printer
From my expreiences with that product, you should reload the machine software.
If the machine is less than one year old call for service it is under warranty.
If not you can go to www.xerox.com and download the firmware,10.100.32.000.
It will resolve many software issues on that product.
You can download it to your computter then upload it to your machine.
Some of the versions of software on that product have some issues. Most are resolved with that version.
You will also need to download the 4150 printer setting utilities if you are going to do this yourself.
You may lose your LDAP settings, so be sure you print out a settings or configuration page before you do the upgrade.
Posted on Feb 25, 2008
SOURCE: Xerox Phaser 8550 Won't Print
I was having the same problem. Turns out the IP address in the printer was incorrect. Once I changed the IP address the printer works just fine through our network again. Find your IP address off your server and follow these steps:
1. Choose Info on display menu, press okay button
2. Choose Info pages, press okay
3. Configuration pages-printer info, press okay
4. IP address should read: Correct IP Address number should be displayed on screen.
If not follow these steps to change it:
1. Find printer setup on display menu, press okay
2. Go to connection setup-press okay
3. Network setup-press okay
4. TCP/IP setup-press okay
5. Auto should show as “Off”
6. TCP/IP should show as “On”
7. DHCP/Boot should show as “Off”
If any of these are not listed on display correctly press ok, reset to either On or Off and then enter correct IP address.
Press okay button and follow steps on display menu to exit back to main menu display screen.
Posted on Mar 26, 2009
  • 141 Answers
SOURCE: Xerox Phaser 8560DP shows annoying 'print completion' message
Someone installed the "Printing Scout" on this computer. You may need to uninstall or check all the settings in the printer driver. I'm not really familiar with Macs but I know the 8560 inside out, upside down, and backwards.
Posted on Aug 04, 2009
SOURCE: Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer: Hello, I have a Xerox Phaser 3300MFP and there are...
Primero , apaga el sistema y desconecta la energia
Luego hay que desconectar la bateria interna que esta debajo del panel por un momento , conectas la energia sin conectar la bateria , si todo esta bien vuelves a conectar la bateria y ya no te dara mas problemas.
Oscar M
Posted on May 04, 2011
Wont print from drawer 2
If you dont have the option to print from your computer it is a driver issue.
If the printer wont physically pull paper try replacing the Pickup rollers
Sep 20, 2013 | Xerox Printer Division Xerox Phaser...
Computer unable to find printer
There is a flaw in the system System sent to printer warranty or maintenance engineer .
Dec 02, 2012 | Xerox Phaser 8560DN Laser Printer
Red light on , not printing
What else do you see on the printer? Is there an error number or message?
Mar 14, 2011 | Xerox Phaser 3250
I have a Xerox Phaser 3250 printer. I went to print one page of a 1500 document and it got the message to print all of the pages. How do I cancel the printing? Help!!!
Quickly try to press cancel on the printer and then turn it off. Then Open the print queue and right click on the document and select "cancel" you may need to do this a number of times, and if you can't get it out of the queue, reboot the computer and delete it then if it is still in the queue.
Sep 30, 2010 | Xerox Office Equipment & Supplies
Printing from wrong tray
I suffered from the same problem for a long time. We got Xerox Phaser 8550 and 8560 here. I choose on computer "tray 2" but the printer just print from tray 1 which is empty.
Today i figured it out! It's some configuration at the printer. So go to "Paper tray setp" -> "Tray 1 mode" and "Tray 2 mode" -> change to "static".
I figure it's like this. Before it was "dynamic", it probably means the printer decides it's better to use tray 1 even though you choose tray 2 - and this decision is stupid. Changing it to "static" fixes this.
Let me know whether this works for you too!
Feb 12, 2010 | Xerox Phaser 8560MFP Laser Printer
Jun 08, 2009 | Xerox Phaser 8560DN Laser Printer
2 sided copying
You just select 2-sided printing in the print dialog box. I think it's on the finishing tab. I'm assuming you aren't trying to print on 2nd side of pre-printed stock. That would be a different issue.
Apr 09, 2009 | Xerox Phaser 8500/DN Printer
Not printing
Hi ,
There may be several causes for this problem.
I will tell you one by one, and you try it.
CAUSE: 1
The printer is not
receiving power.
SOLUTION:1
Check the power cord connections.
Check the power switch and the
power source.
CAUSE:2
The printer is not
selected as the
default printer.
SOLUTION:2
Select Xerox Phaser 6110
Series as your default printer.
CAUSE:3
Check the printer for
the following:
• The printer cover is
not closed.
• Paper is jammed.
• No paper is loaded.
• A toner cartridge is
not installed.
SOLUTION:3
After locating the problem, clear it.
If a printer system error occurs,
contact your service representative.
• Close the printer cover.
• Clear the paper jam.
• Load paper.
• Install the toner cartridge.
CAUSE:4
The printer may be in
manual feed mode
and out of paper.
SOLUTION:4
Check the message on the Status
Monitor program window, add paper
to the tray and press the
button on the control panel.
CAUSE:5
The connection cable
between the
computer and the
printer is not
connected properly.
SOLUTION:5
Disconnect the printer cable and
reconnect it.
CAUSE:6
between the
computer and the
printer is defective.
SOLUTION:6
If possible, attach the cable to
another computer that is working
properly and try to print a
document. You can also try using a
different printer cable.
CAUSE:7
The port setting is
incorrect.
SOLUTION:7
Check the Windows printer setting
to make sure that the print job is
sent to the correct port. If the
computer has more than one port,
make sure that the printer is
attached to the correct one.
CAUSE:8
The printer may be
configured
incorrectly.
SOLUTION:8
Check the printer properties to
ensure that all of the print settings
are correct.
If u still cant find the remedy, go for the support from XEROX,
www.office.xerox.com/printers/color-printers/phaser-6110/serv-enus.html
Hope my info solves your problem,
Thanx for using fixya.
Oct 01, 2008 | Xerox Phaser 7760/YDX Laser Printer
Re: Help
ok..let's try something more basic..can you do a test page on the printer, without it being connected to the computer, at all? would be nice to know that the printer is known good, eh?
May 26, 2008 | Xerox Phaser 6300N Laser Printer
Xerox Phaser 3250D Laser - Monochrome Laser - 30 ppm Mono - 1200 dpi - USB - PC, Mac Printer Logo
32 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
