Question about Sound Logic 4 in 1 Wireless Headphones
The headphones is not conecting with the reciver
Connecting earphones to the tv
Use the headphone connector if there is one.
Oct 25, 2016 | Televison & Video
Speakers do not work. Headphones do. Tried adjusting volume but nothing changes
Possible causes are:
faulty conections on speaker cables, check all conections.
cable damaged, replace cable
speakers faulty, replace speakers
Feb 03, 2016 | Dragon Touch Touch7 Blue Dual Core Y88...
I cannot connect my iPod nano with Bluetooth to my Denon AH-W150 bluetooth headphones. Help!
that is because the ipod nano can not connect to bluetooth it does not have a bluetooth reciver
Sep 07, 2013 | Denon AH-W150 Exercise Freaktm Bluetooth...
My reciver keeps shuting off and saying protect when nothing conected to the reciver and it was playing music perfectly at low volume setting and then cut off
The Amplifier has a Fault and is shutting down to protect itself. Repeated cycling of this will cause a total failure in the Amplifier.
If you haven't got the Technical ability to have a look at it yourself then I suggest you take it to a service engineer or wait for a total failure and scrap it.
Jun 04, 2011 | Sony STR-DG520 Receiver
The conection plug broke.
See if my tip on headphones will help you with this problem.
Apr 05, 2010 | Denon AH-C751K Headphones
Can't get on line
first of disable you wireless internet security. sometimes the internet reciver cant pick up signals on secure networks. and then try to conect it then. if that dosen work get in close range to your router to see if its a signal range issue. and agian if still nothing try to type in the ip address manually.
if none of that works then you mite have oten a defective internet reciver for your consel
Dec 17, 2009 | Microsoft Xbox 360 Console
Sp.off
ON the str-de485 the sp.off lights up when the headphone jack is enabled, do you have the headphones inserted?
Feb 13, 2009 | Sony STR-DE485 Receiver
No sond from speakers but with headphone jack
there is no problem with the amplifier audio,check some resistors or disconections near the spkr terminals.
Oct 21, 2008 | Sony STR-DE605 Receiver
Sound Logic 4 in 1 Wireless Headphones Logo
50 people viewed this question
Top Sound Logic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sound Logic Audio Player and Recorder Expert? Answer questions, earn points and help others
