Question about Minolta Office Equipment & Supplies
Di5510 service code sc 29-05
No toner to paper with brand new toner bottle
  • Minolta Master
  • 6,161 Answers
You need to have the developer and drum replaced. Make sure that the proper tests are run after the new develop is replaced. Also COUNTERS must be cleared the machine works off the counters if you reset counters without replacing the parts the machine will set certain voltages to those that you say are new when in reality they are old and you get bad images and codes. also check that when the drum is remove to clean the senor DO NOT USE A VACUUM CLEANER to clean the developer or toner The static electricity from the vacuum cleaner will destroy the sensors and circuit board. NEW TONER bottle will do nothing GET a qualified Konica Minolta Technician out to do this right to much to tell you to do via this web site. Have Complete PM none. That way you get the job done right, That will include the drum cleaning blade the Toner collection roller, Charge wires, etc.
Posted on Feb 08, 2015
Bubbabear64
  • 2794 Answers
SOURCE: Error Code SC 367
What error code did you get?
Posted on Aug 22, 2008
  • 86 Answers
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
SOURCE: cannot change toner bottle
Usually if you turn the machine off then back on and let the
toner stop cycling it will be in the correct position to remove the bottle
Posted on Feb 24, 2009
  • 4 Answers
SOURCE: Sharp SF-2116 Analog Copier . The red Service Man sign is on
Emptying the waste toner won't turn the service light off,
you require simulation codes to enter into the machine and actually reset the service man itself.
to enter into this you need to do a series of commands which are
"Start(unsure if you actually need to press start) Clear, Interrupt, Zero, Interrupt"
Then all the lamps and idicators on the operation panel go off then you will need to type in "20" and hit start which will reset the maintenance counter.
Posted on Sep 29, 2009
SOURCE: Having constant issue with paper
YES. ALSO YOU COULD SET THE PRINTER ON ECONOMICAL MODE.....
Posted on Mar 26, 2011
Howe do i fix ricoh 2060 code sc342?
there are more possible solutions and cause of this error. First of all the sc code and the sign for no toner are connected. The sc code mean that is there is no toner in the developer hopper. First of all if this code appeared after you replaced the developer, you will need did you connected the two connectors that connect the developer unit with the machine, and also check do the developer unit is properly inserted into the machine. But if this problem ocured before you replaced the developer, than the problem is with the toner holder. Open the front door and check the white hook that pulls out the toner bottle cap when the bottle is home position. This white hook is located on the back of the toner bottle holder. you will notice it when you pull the bottle from 90 degrees angle into home position how it slides on the metal rail located next to the toner bottle holder on the right corner of the machine. If it is broken or out of position than that is the problem. If this part is ok that open the front door and put something like a screwdriver in the upper taster that detects do the front door is closed its located above the red main switch, you will notice a hole with a bronze colored plate inside. The other switch is located on the front right bottom corner next to the third paper tray, you will notice a hole in the olive-brown color plastic. When you will insert something into this two holes the machine will think that the front door is closed and it start the toner loading process. While the machine run, with the door open notice do the toner bottle rotates.If does not rotate than the motor that rotate the bottle is not working. If non of this help than tell me and i will tell you other possible solutions.
Mar 06, 2015 | Ricoh Toner for Aficio 1060, 1075, 2051,...
Error Code SC 367
can you say what is the brand and model of the device so I can find out the meaning of the code.
Jul 30, 2008 | Office Equipment & Supplies
How i change the developper of konica di5510 plus the code of it
I would recommended you get a konicaminolta tech to that it not simple in will require developer, knowing the service mode 36. Clearing counters in mode 25. Try a web site that sell the old Konica Minolta service manual. follow step by step.
Feb 04, 2015 | Konica Minolta Minolta Dialta Di5510 Laser...
Sc 28-03
Code deals with Speration wire which is the second wire on the lower assemble if you replaced them did you replace the whole assemble if then, next is the High Voltage circuit board. also there is a connection to the H V board via a connector at the back of the transfer /seperation assemble should see a red wire check the copper connection might be paper stuck in the connector preventing electrical connection.
Mar 09, 2014 | Konica Minolta Genuine Di650 Di551 Di5510...
SC23-03 minotlta di551
SC 23 -03 M2 Drum motor abnormality.Verify the drum drive transmission mechanism and the drum gears and collars,and the main motor drive transmission mechanism it is an mechanical blocated problem.
SC 23-01 M13 toner bottle motor
SC 23-02 M3 developing motor abnormality
Feb 13, 2013 | Konica Minolta Genuine Di650 Di551 Di5510...
I have a konica 7075 and the service report code is SC23-01
Sir, check the toner bottle! SC-23-01, is a toner bottle motor issue
Aug 18, 2009 | Konica Minolta Office Equipment & Supplies
My Ricoh Afficio 2232C doesn't print and it gives me this message: "Functional problems within your computer. Turn operation on then off. If the error appears again, call service. SC 440-01."Several times...
A 440-1 is a black drum motor lock. The waste toner in the black pcu is backed up, more then likley. It is not easy to fix. You could replace the black pcu but it will happen again. The usual problem is oil in the main waste toner system. It clumps up the toner and clogs the part where all the waste toner comes together for entry into the waste toner bottle.
May 26, 2009 | Ricoh Aficio CL7200 Laser Printer
Is there a reset button, asking for service
What is the error code? Is it a C0070 code? If so that means that the toner bottle can not find home potion. Take the toner bottle out and let the copier come to ready and reinstall the toner bottle.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
67 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
