Question about Intel Dell Poweredge 860 Server 1-socket 1u Rack Server
Install linux I have been given a server which has windows server 2003 pre-loaded but I need to install Linux. When I put the Linux installation CD and reboot the server, it still boots in Windows. I checked the boot sequence in BIOS settings and it is configured to boot from CD first.
  • Intel Master
  • 27,725 Answers
Did you save it to cmos before restarting your computer ? F10
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load
failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
otherwise it will keep booting from the cd /dvd drive
hope this helps
Posted on Nov 02, 2012
Boot from usb
Introduction UNetbootin allows you to create bootable Live USB drives for Ubuntu, Fedora, and other Linux distributions without burning a CD. It runs on Windows, Linux, and Mac OS X. You can either let UNetbootin download one of the many distributions supported out-of-the-box for you, or supply your own Linux .iso file if you've already downloaded one or your preferred distribution isn't on the list.
Requirements
  • Microsoft Windows 2000/XP/Vista/7, or Linux, or Mac OS X 10.5+. Note that resulting USB drives are bootable only on PCs (not on Macs).
  • Internet access for downloading a distro to install, or a pre-downloaded ISO file
Features UNetbootin can create a bootable Live USB drive, or it can make a "frugal install" on your local hard disk if you don't have a USB drive. It loads distributions either by downloading a ISO (CD image) files for you, or by using an ISO file you've already downloaded.
The current version has built-in support for automatically downloading and loading the following distributions, though installing other distributions is also supported:
Oct 15, 2011 | Microsoft Computers & Internet
Tip
Run Linux from a USB Hard Drive
Running linux from a USB hard drive is a great way to install Linux without affecting your Windows hard drive that is already on your computer!
First of all you will need to download the Linux operating system of choice. For me, I use Ubuntu Linux. You can download the ISO from the Ubuntu website.
Once you download the ISO image, you will need to burn it to a CD. Once this is done it is time to start installing!
*NOTE - I would remove the windows hard drive prior to installing. That was I can make sure I don't accidentally overwrite my Windows partition! You can put your hard drive back in the computer when you are done installing.
Place the CD/DVD into your drive and shut down your computer. Plug in your portable USB hard drive and turn the computer on. If your computer doesn't say "please press any key to boot from CD" then you will need to change your BIOS settings to boot from CD before booting from Hard drive.
Once the CD drive boots up you will be given the option to run Linux or to install it. Choose install, follow the prompts for networking/computer name etc and make sure you don't install it on your Windows hard drive partition!
Once Linux is installed on the portable hard drive all you will need to do is make sure you can boot your computer from a USB hard drive. This is done in the BIOS settings to choose your boot order.
on Sep 26, 2011 | Computers & Internet
Problem with the Dell PowerEdge 2650 Server Can't detect Hard drive
First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. The hard drive needs to bereplaces in the laptop and Windows installed and the laptop's device driversand your programs etc to get a functioning laptop again.
Mar 23, 2011 | Dell PowerEdge 2650 Server
I am unable to instal windows server 2003 on HP Proliant ML150 G5 because it gives me message no hard drive found
Option 1 (HIGLY Recommended): HP servers should come with an install disk that prepares the windows installer for you. Boot from that disk,tell it your OS, and pop in the disk for the OS when prompted. It will come up fine and have all the HP monitoring agents installed.
Option 2: Load the driver the old fashioned way. Unless you have a floppy drive the standard "Press F6 to load drivers" trick won't work. If you do, then you'll need to put the RAID driver on the disk.
Option 3: Use an installation customizer like nLite to pre-add the RAID driver to the Windows 2003 installer.
Good luck.
Feb 26, 2011 | HP ProLiant ML150 G5 Server
What can window does it take
I have loaded windows 2003 server on this but the following OS are supported:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3279705&lang=en&cc=us&prodTypeId=15351&prodSeriesId=316537&taskId=135
Microsoft Windows NT 4.0
Microsoft Windows Server 2003
Novell NetWare 5.1
Novell NetWare 6.0
Novell NetWare 6.5
OS/2
Red Hat Enterprise Linux 2.1 (x86)
Red Hat Enterprise Linux 3 (x86)
Red Hat Enterprise Linux 4 (x86)
Red Hat Enterprise Linux 5 Server (x86)
Red Hat Linux 7.2
Red Hat Linux 7.3
Red Hat Linux 8.0
SCO Open UNIX 8
SCO OpenServer 5
SCO OpenServer 6
SCO UnixWare 7
SUSE Linux Enterprise Server 7
SUSE Linux Enterprise Server 8
SUSE Linux Enterprise Server 9 (x86)
Dec 25, 2010 | HP Compaq ProLiant ML350 G3 Server
I have an Ml 110 G5 Server, But i could not find the VGA driver for the Win Xp , kindly assist thanks Justin
Hi, I m really sorry to say that but you have a Server Product and its built to run Windows Server Series on it (or Linux / Novell Netware).
This is the list of compatible Server list
Microsoft Windows Server 2003 Microsoft Windows Server 2003 for 64-bit Extended Systems Microsoft Windows Server 2008 Essential Business Microsoft Windows Server 2008 Foundation Edition Microsoft Windows Server 2008 R2 Microsoft Windows Server 2008 Small Business Microsoft Windows Server 2008 W32 Microsoft Windows Server 2008 x64 Novell NetWare 6.5 Red Hat Enterprise Linux 4 (AMD64/EM64T) Red Hat Enterprise Linux 4 (x86) Red Hat Enterprise Linux 5 Server (x86) Red Hat Enterprise Linux 5 Server (x86-64) SUSE Linux Enterprise Server 10 (AMD64/EM64T) SUSE Linux Enterprise Server 10 (x86) SUSE Linux Enterprise Server 9 (AMD64/EM64T) SUSE Linux Enterprise Server 9 (x86)
Here is the link for Drivers
Try to use the Driver for Windows 2003.
It has a Matrox VGA as I know. If you know which Matrox series you have, then Browse here for the Drives: Matrox Graphics Support. Make sure that you choose the Exact Driver software which suites the System.
Note: Not every product has the Driver Software for Windows XP.
Please rate the answer! Thanks for contacting Fixya!
Jun 19, 2010 | HP Compaq ProLiant ML110 G4 Server
How to install windows server2003in ibm server x3400
The install is fairly easy. Before you begin make sure if you have SCSI adaptors installed have the drivers for them on hand. If you do not have these drivers you should download them to a 1.4MB floppy disk. When you are ready, put the Windows Server disk in the cd/dvd and reboot the IBM. Follow the instructions on screen and you shoud be fine. From start to finish it should take you about 1 1/2 hours to complete everything.
Good Luck
Franklin
C2Solutions
Jul 21, 2009 | IBM x3400 Server
Hard disk no detect in installtion of window server 2003 32 bit oprating system how to install windows server 2003 (32bit) in ibm server x3400
You need to give windows installation the drivers for your Sata-Bus by pressing F6 while the installation load the drivers (like when we want to install on RAID drive). or do the following method follow the links in that page for Slipstreaming VIA Serial ATA drivers and the other link to create a boot CD Creating a bootable Windows CD with Nero.
it's all in the following link: http://weblogs.asp.net/jkey/archive/2005/08/28/423901.aspx
Apr 12, 2009 | IBM x3400 Server
Intel Dell Poweredge 860 Server 1-socket 1u Rack Server Logo
100 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
